Similar product, spotted at the Snow Summit National last weekend behind someone's van. Asked and he said they work great, exactly as intended. We compared notes...
Similar product, spotted at the Snow Summit National last weekend behind someone's van. Asked and he said they work great, exactly as intended. We compared notes about how blown away we both were the first time riding a heavy ebike through choppy rough stuff. The front one is apparently an off-the-shelf moto product that fits a Dorado upper leg without modifications. And yes, these are definitely suspended mass dampers. Sadly, this bike needed a steering damper and hand guards to win bike tech bingo.
Why would Mondraker want the mass damper on the end of the swingarm though, on the unsprung mass. Wouldnt you want it on the sprung mass...
Why would Mondraker want the mass damper on the end of the swingarm though, on the unsprung mass. Wouldnt you want it on the sprung mass? (Like on carlinojoevideos setup above)
Hey, yes these are from CounterShox. the blue one on the fork is straight off the moto bike. I tested on my Yamaha 450 first and...
Hey, yes these are from CounterShox. the blue one on the fork is straight off the moto bike. I tested on my Yamaha 450 first and then had to try on DH bike. I knew it would have a bigger effect.
The mount is off a 85cc dirt bike, they have the same diameter clamp as dorado.
The one mounted to the seattube is lighter, about 1lb. I 3D printed a mount so it doesn’t rub again the frame.
These TMD are not adjustable, from talking to the folks at CounterShox, they have put so much R&D into weights, springs and bumpers, I trust their knowledge about frequencies over me tinkering with it.
I did have to adjust my suspension slightly, I tested with data acquisition and there is a difference in numbers with and without for sure. With the weights on the Atherton it’s still around 41lb, coming from dirt bikes and e-bikes, anything sub 40lb feels like it deflects too much and isn’t planted. For DH and bike park, I don’t see a reason not to run these mass dampers.
Was there a type of bump/frequency range where it was more noticeable?
I found that sharp high frequency bumps were deadened. Like washboard bumps, or sharp square edge braking bumps.
So this let me run my HSC a few clicks stiffer. Then in return my bike handled big compressions better. I used to sacrifice large high speed hits because I was looking for comfort in other areas of the trail that have more chatter.
What patents does countershox have on this? Can we spin up a competitor where it mounts inside your steer tube, or an ebike where the battery is mass damp(en)enened?
EDIT: actually, mounting it in the steerer tube is a bad idea- if no one can see your product then how will you be able to market it
What patents does countershox have on this? Can we spin up a competitor where it mounts inside your steer tube, or an ebike where the battery...
Are thet the cnc headtube version like the latest dh bike?
Yes. Looks like the cnc head tube and bb. Also the new rear triangle. The only thing that im not sure about is the float x instead of the coil shock. I was expecting a dhx2 but guess ill be giving the float x a try
Couldn't help but notice they're using a different oil for Shimano brakes, i'm wondering if that's something already in the market and will be stock on the new lineup or if it's a new Shimano recipe
Couldn't help but notice they're using a different oil for Shimano brakes, i'm wondering if that's something already in the market and will be stock on...
I found that sharp high frequency bumps were deadened. Like washboard bumps, or sharp square edge braking bumps. So this let me run my HSC a few...
That kinda sounds like an effect one would get by jumping to coil forks instead of air-sprung ones. Interesting!
And without some of the issues found on a coil fork. I have a z1 coil with a grip 2 in it and its great on stuff like that but i do find it sometimes easy to blow through the travel a bit more than i would like
It doesn't appear to be dampened, just sprung. They claim their data shows less vibration, but their "control" is unweighted. I would love to see data with just the equal weight, the tungsten weight sprung, and then a true unwieghted control. Maybe throw in a dampened sprung weight, but that gets more complicated as you'd have to decide how much dampening to add. You could even go crazy and have different compression/rebound!
I'd think that'd be better controlled with the lighter stock triangle and proper suspension. Add the weight around the bb
In theory the tyres bounce at their own natural frequency so on small, fast chattery bumps they can start to hop and lose traction. These inputs are usually too short for the suspension to respond in time so a mass damper could cancel out the vibration which keeps a more consistent force on the tyre.
In theory the tyres bounce at their own natural frequency so on small, fast chattery bumps they can start to hop and lose traction. These inputs...
So we need two small ones on our dropouts for front and back, unsuspended, two larger ones for the fork and seat tube, and then two more at the end of our handlebars to reduce hand buzz, making the bike look like a 90s bar setup with bull horns?
It doesn't appear to be dampened, just sprung. They claim their data shows less vibration, but their "control" is unweighted. I would love to see data...
A mass damper inside of a frame instead of shocks with be pretty cool in my opinion. Or apart of fork crowns. Does anyone know, do these mass dampers help more with short or long travel bikes? I would throw one on my all mountain bike to help with smoothing out vibrations. Weight does not scare me. Since its my all mountain bike the suspension is set up quite stiff to be ready for the rough. This has me very intrigued.
Ah i see. So would a internal geared hub(maybe a 3x3 hub) work well for that app?
Dot fluid.... watch all the shimano fanboys say how good dot is all of a sudden.
also, why are we still having to strap levers to bars to get a good purge and solid feel..... I've done it with shimano brakes for ages as it makes them feel even better, downside is you've gotten do it often to keep them feeling good.
Front end felt like a bigger change on the entire track, mostly because it was directly calming down feedback to the hands.
Maybe it helps with rear end bucking?
Can we get a review?
world champs pit bits photos 1 - https://www.vitalmtb.com/features/pit-bits-1-2024-world-championships
on instagram, countershox commented that they're launching a version for bikes in loudenvielle next week.
New saint looking good.
Also, canyon really goin all out on their frames. Lol.
pit bits photos 2 - https://www.vitalmtb.com/features/pit-bits-2-2024-world-championships
Frameworks Enduro frames available for pre-sale for newsletter subscribers. Starting at $4K for frame and shock (Fox Float X).
Steerer tube version is already in development.
https://bikerumor.com/rimpact-is-developing-a-tuned-mass-damper-for-mou…
Or if it's Putoline HPX R. 😄
Maybe rebranded Pütoline HPX R but it seems to be the new OEM shimano oil as this picture in the pit bit part 2 seems to indicate
Yeah, looks dry in the images...
Those new TRP brakes look ready to be released.
What are those grooves near the end of the reservoir (below the tape)?
Is this some kind of adjuster? Like on some SRAM stuff?
