11/22/2024 7:59am Edited Date/Time 11/22/2024 7:59am
I think the different material of pistons could be more to handle heat differently Say a ceramic piston vs a stainless vs ergalWouldn’t know which one is...
Wouldn’t know which one is better
For example Billet factory in Italy is making some 7075 ergal pistons for the hope v4 that are a tad longer to accommodate better the use of thinner rotors
I’m not sure how that would change the brakes given the stock pistons are steel with a sort f resin insert.
Also, why would you wish they were ( the Maven ) Dot vs a better Mineral then maxima? Like Bionol, gold hydraulic or Pluto line
DOT can be left unattended for longer. I think it would be cool to have brakes that are as reliable and low maintenance as car brakes and that would require DOT.
In regards to heat, ceramic and phenolic pistons are superior. Stainless with an insert is decent too if the insert material insulates well. Straight metal pistons have a noticeable negative impact on brake fluid temp even on trails that aren’t too crazy. Stainless pistons result in the brake fluid getting 10% hotter pretty much instantly.
NicoZesty96
portogruaro, VE IT
11/22/2024 10:35am Edited Date/Time 11/22/2024 10:37am
DOT can be left unattended for longer. I think it would be cool to have brakes that are as reliable and low maintenance as car brakes...
any thoughts a piston like this one compared like before to the other options? it's 7075 with a magnet.
442510545 3259119401063876 991579911500287995 n 0
also curious if the bare stainless are getting the fluid hotter than others why Trickstuff and Intend and Radic use them vs hope style with the phenolic insert to fill it or ceramic insert like Lewis.
11/22/2024 10:44am
One possible reason is they are cheaper and easier to achieve tolerances with.
1llumA
550th
11/22/2024 11:04am
Since there is only a small edge of the stainless piston that is touching the brake pad that mean heat transfer is mostly from the air pocket between the brake pad and the bottom of the stainless piston ? A solid stainless piston would fare much worse in terms of heat capacity and transfer ?
11/22/2024 11:18am
1llumA wrote:
Since there is only a small edge of the stainless piston that is touching the brake pad that mean heat transfer is mostly from the air...
Even with a thin piston wall in contact with the pad there is still significantly more heat transfer than other materials. Hard to get convection to out weigh conduction when it comes to heat transfer. When we were developing brake calipers, we really wanted to do stainless pistons because it's much easier to make stainless pistons, but the numbers just don't agree. This was testing comparing the temperature of the caliper body with stainless pistons similar to what you've described and phenolic pistons. The track was up on Chuckanut so nothing crazy. Piston material comp 2.png?VersionId=2onMykPiC
11/22/2024 11:23am Edited Date/Time 11/22/2024 11:24am
any thoughts a piston like this one compared like before to the other options? it's 7075 with a magnet. also curious if the bare stainless are getting...
I would avoid aluminum pistons like the plague. The thermal conductivity of aluminum is very high. I want to say like 4x that of stainless at least. Not what you want in a brake caliper.
Stainless with a phenolic insert works well too. Stainless pistons are just easier to make or source. Phenolic pistons are a very specific resin that is molded at rather high pressures and then ground to the right dimension. Requires specific machinery whereas a stainless piston can be made on any mill or lathe.
11/22/2024 11:42am
What about a double walled piston where an internal cylinder interfaces with the pad, the outer with the seal and the only link between them is the back face of the piston. So you do not heat the oil via the cylinder sleeve, only via transfer along the inner wall into the inner face.
It'd be a PITA to make though.
sprungmass
Calgary, AB CA
11/22/2024 11:52am
How about filling stainless steel pistons with a high temp epoxy and inset a neodymium magnet before it cures? That way you can have ease of manufacturing, good thermals and magnetic pistons Smile
TheKaiser
Storrs, CT US
11/22/2024 11:53am
I see what you mean if we are actually comparing brake maintenance requirements of a DOT car vs. a mineral oil bike but that is an apples and oranges comparison because...
The car is an open system, and the air space at the top of the reservoir can self adjust to accommodate for fluid volume growth due to moisture absorption.
In our bike brakes, which have a membrane sealed reservoir, with very little room to accommodate for fluid volume growth, my experience is that a DOT bike left unattended in garage or shed in a humid environment for a year or 2 will absorb enough moisture to exhibit signs of overfilling, and will either leak out the reservoir cap (causing corrosion of the controls) or not leak but auto-apply the brake. Either way, it is a real PITA if you have a bunch of bikes that see little use, and you want to grab one on short notice as a loaner, or because your primary ride is out of commission, as you basically need to do a mini bleed before each time you use the bike. In my experience, the equivalent mineral oil brake would still be working fine after sitting in that same environment for the same period of time.
You really know your stuff though, and it sounds like you are attuned to some issues associated with long term use of mineral oil that I am not, possibly related to more intense use cases, so what's the deal? What specific problems occur to mineral oil brakes that a switch to DOT would remedy?
11/22/2024 12:09pm
TheKaiser wrote:
I see what you mean if we are actually comparing brake maintenance requirements of a DOT car vs. a mineral oil bike but that is an...
With the assumption that brakes have to be bled often, which is the case for 90% of MTB brakes, the cons of mineral oil go away. That said, I've found mineral oils break down with heat much more readily. This is obviously tied to more extreme use cases like bike park of course. The other issue is actually moisture related. If you do get water in your brake lines somehow, DOT absorbs it and the boiling point drops a little. Meanwhile mineral oil does not absorb it and, with water being denser, it settles in the caliper and the boiling point is essentially converted to that of water. But the brakes should be sealed well enough that water doesn't really get in there. I've seen a Shimano brake where the caliper was entirely full of water due to a hole in the membrane, though.
11/22/2024 12:12pm
There are a lot of possible ways to add a layer of insulation to brake pistons. In theory you could come up with an insert with low thermal conductivity and high contact resistance between it and the piston body. The latter being a little more difficult since pressure on an interface decreases contact resistance and brake pressures are fairly extreme.
Nobble
Santa Cruz, CA US
11/22/2024 1:08pm Edited Date/Time 11/22/2024 1:08pm
There are a lot of possible ways to add a layer of insulation to brake pistons. In theory you could come up with an insert with...
Couldn’t you build the heat break into your pad backing?
A thin G10 strip or something.
Or do you need the airflow on the back of the pad?
11/22/2024 1:17pm
Adding a strip would certainly help, however the heat flux is inversely proportional to the thickness of the material so thinner buys you less. Finned pads really are a good idea cost aside.
NicoZesty96
portogruaro, VE IT
11/22/2024 6:07pm
sprungmass wrote:
How about filling stainless steel pistons with a high temp epoxy and inset a neodymium magnet before it cures? That way you can have ease of...
i could actually get some spare hopes piston and attempt something like that, i feel one of the best things on Magura's are the pistons, the magnet is just genius and i have no idea why others don't do it
NicoZesty96
portogruaro, VE IT
11/22/2024 6:08pm
I would avoid aluminum pistons like the plague. The thermal conductivity of aluminum is very high. I want to say like 4x that of stainless at...
i had that feeling but don't have either the knowledge on the subject or have done testing of some sort, cheers for the tip and explanation
NicoZesty96
portogruaro, VE IT
11/22/2024 6:08pm
11/22/2024 6:13pm Edited Date/Time 11/22/2024 6:19pm
Maven bronze “tune” update:
2.3 TRP rotors and MTX pads feel great and are a quiet combo. Shortened the deadband while making the bite point and power management feel more refined.
I have used galfer greens in the past to make brakes more powerful and have a stronger bite point, I wouldn’t want those for mavens.
11/22/2024 6:16pm
i could actually get some spare hopes piston and attempt something like that, i feel one of the best things on Magura's are the pistons, the...
I’ve always wondered if they have a patent on it, but haven’t dug around enough to find one.
11/22/2024 10:04pm
What temperature do the pads get up to? Magnets get very unhappy above 200°C. You have to glue them to the piston. You have to have the surface for it, which means more contact area for the pad and more heat transfer. You have to have steel back plates for the pads (finned pads are thus a no go). There are probably some more reasons why magnets aren't the bees knees.
NicoZesty96
portogruaro, VE IT
11/23/2024 12:47am
What temperature do the pads get up to? Magnets get very unhappy above 200°C. You have to glue them to the piston. You have to have...
bombing down some steep and loose fire roads in the dolomites i managed to turn my storm rotors blue, so quite hot, on trickstuff power pads, nothing happened to the magnets so i'm not sure, the brakes were smelling really bad but i think if you get to the point where the magnets start having problems you'll have way more to care bout first
HexonJuan
WI US
11/25/2024 6:07am
Seen mechanical calipers using magnetic pad retention lose their magnetism under heavy, heavy use. Think Pike's Peak or Highway to the Sun in HI. It requires deep and heavy heat cycling, but it can happen.
11/25/2024 11:18am Edited Date/Time 11/25/2024 11:19am
people in this thread want rube goldberg pistons with magnets and insulation but still say brakes are too expensive
NicoZesty96
portogruaro, VE IT
11/25/2024 11:20am
HexonJuan wrote:
Seen mechanical calipers using magnetic pad retention lose their magnetism under heavy, heavy use. Think Pike's Peak or Highway to the Sun in HI. It requires...
Again, if Magura users never had anissue with it, me included, i think it's solid enough that other manufacturers could use it if done the same way.
11/25/2024 1:15pm
Well Magura also uses plastic master cylinders with wood screws...
Nobble
Santa Cruz, CA US
11/25/2024 2:50pm
My MT7s had a 66% failure rate in less than two rides and Magura USA were a royal pain in the ass about it.
Awful brakes and customer service, wouldn’t even run them if they were free.
ballz
Ouagadougou EH
11/25/2024 5:06pm
Nobble wrote:
My MT7s had a 66% failure rate in less than two rides and Magura USA were a royal pain in the ass about it.Awful brakes and...
The calipers are solid. The levers - not so much. My two pairs of Saintguras are well past their expected shelf life and they just keep on trucking.
NicoZesty96
portogruaro, VE IT
11/25/2024 9:14pm
we're talking magnets here
NicoZesty96
portogruaro, VE IT
11/25/2024 10:07pm
i call that bullshit, 66% come on, the brake itself is great in terms of performance, serviceability and material of choice for the master sucks, i had one master leaking after 4 years of ownership and countless brake pads, never had bleeding issues, it rarely requires bleeding, it got replaced under warranty no question asked in decent times, i honestly have not many things to complain, the stock levers are poorly designed with that dumb spring to keep them in place, hc3 is the way to go if keeping stock, Oak otherwise.
The fact that you cannot rebuild the brakes sucks, and they could definitely  ditch the carbotexture in favor  of some nice 7075 alloy.
That being said my experience with warranty was in NZ and was smooth as, even if the brakes were bought in Italy from Germany.
Nobble
Santa Cruz, CA US
11/26/2024 6:39am Edited Date/Time 11/26/2024 6:43am
i call that bullshit, 66% come on, the brake itself is great in terms of performance, serviceability and material of choice for the master sucks, i...
I bought 4 brakes because they were on sale.
Installed the first two, bled up fine, got to the trailhead. Lever main seal failed while riding around to bed in the pads. It would slowly lose pressure and pull to the bar.
Took it to the one local shop I trust, he did a quick lever bleed and then agreed it was a failed lever.
Called Magura, and they told me the brake couldn’t have failed the way it did and that if the main seal was bad it would be leaking out of the brake. Which is wrong. The warranty guy said “It’s a bleed issue, but if you want to throw parts at it I guess I’ll send you a brake.”
Took another one of the brakes I bought to replace the failed one and mounted it. Half way into the first ride on that brake it failed in the exact same way. Called up Magura again. Told the guy I had the exact same problem. He told me “It may need to be bled properly”. Before I said something I’d regret, I told him he’d be hearing from my LBS. I took it to my LBS and had him check my work again and then process the warranty. They gave him a horrible time with it too.
Took the warranty brake they sent me and returned the two unused ones.
In summary, my 66% is accurate. I installed three brakes on my bike and two failed. I Had the LBS check my work every time. After the second one failed on a steep trail I decided they weren’t worth trusting with my safety. If they’d been super apologetic and helpful, maybe I’d feel different about it. But they were dicks and basically insisted that if there was a problem, I must be doing something wrong.
