lickmycrinkle
Beverly Hills, CA US
9/11/2024 2:06pm
kingsleyrh wrote:
Finally Finally! Specialized giving the people what they want!
The people want a €3.6k metal bike with deore and xfusion?
gonza.s.m. wrote:
3.5k you get Fox suspensions...but not that cool as S
https://images2.giant-bicycles.com/b_white%2Cc_pad%2Ch_2000%2Cq_80/jii1…
You can afford to spec (shitty) Fox when you haven't spent a dime on R+D since 2011.
Ernst_
9/11/2024 3:34pm
Glad to see in frame storage not being locked behind the carbon model like every other brand does (except Trek).
gonza.s.m. wrote:
This?
What bike?
9/11/2024 3:36pm
gonza.s.m. wrote:
This?
But we’re not supporting Giant 😉 Also forgot Marin has storage on an alloy frame too.
9/11/2024 4:01pm
OK, we're fully derailing this, but let's conclude the discussion anyway 😀The pivot is NEVER going to be above the line between the CoG and the...
The pivot is NEVER going to be above the line between the CoG and the rear axle. Imagine what that bike would like like.
Here are some crude drawings I made to illustrate how anti-squat works. First, we have to understand what causes the bike the squat. The force introduced by pedaling makes the rear wheel turn, pushing backwards against the ground (blue arrow below). This causes the bike to accelerate (red arrow at the wheel). Because this force is applied way below the center of mass (the circle with the X in it), the mass effectively gets "left behind" during the acceleration, thus shifting the weight back over the rear wheel, causing the suspension to compress. This is extra annoying on a pedal bike, because the acceleration force is not constant, it ebbs and flows with every pedal stroke. If left unchecked, this bobbing causes a lot of energy loss.
phase 1
OK, so onto anti-squat. In a linkage layout designed to combat squat (such as the Horst link depicted below), the force of the chain (which caused the bike to accelerate) is ALSO used to counteract the force caused by the rearward shift of the mass. This is achieved by placing the pivots of the rear triangle in such a way as to cause chain growth when the suspension compresses (i.e. the distance between the top of the chainring and the top of the cassette cog upon which the chain is resting becomes longer when the suspension compresses). When you then introduce a force vector along the chain, it causes the suspension to extend (the reverse action of chain growth). This is a mechanical movement that occurs in the linkage itself, it has nothing to do with a force being applied above the line from CoG to rear axle. Note that the main pivot point in this design (whether actual or virtual) is usually found somewhere on the same level or slightly above the rear axle. Anti-squat is measured as a number, 100 is basically when the force compressing the suspension (caused by the rearward movement of the mass) is equal to the force extending the suspension (generated in this case by the chain pulling on the linkages, causing the swingarm to move downwards).
linkage
And to conclude, the high-pivot with idler. Here, the anti-squat force is generated by the placement of the forward pivot at a point well above the rear axle. This means that any force applied to the rear axle in the forward direction below the main pivot will cause the connecting member (the swingarm) to want to rotate downwards, thus counteracting the squat-inducing force caused by the forward acceleration. This can be achieved without any chain growth if the idler is placed exactly inline with the main pivot. You can also play with the placement of the idler to add or subtract some "extra" anti-squat properties.
high-pivot
I'm sorry, you are simply incorrect in your analysis. Virtually all antisquat comes from chain tension, and without it every vehicle with pivot-based suspension squats under acceleration.
You are right, a design with a pivot above the imaginary line between your CoG and the rear axle would be ridiculous and impractical, which is why every design relies on chain growth for antisquat.
image 53
Here are three pivot locations, the rear axle, and CoG. Both the low and the high solid red pivots are below that before mentioned imaginary line. You can see with the force arrows, if the rear wheel accelerates the bike+rider forward, the force vector between the forward acceleration and downward gravity acceleration drives forwards and downwards. The only way for the suspension to extend is for the pivot location to be above this line. This is the source of acceleration squat. The pink pivot location is the only one that will extend (but its in an impractical location).
Again, this is without a chain. The whole point of chaingrowth is to generate chain tension to overcome this. Again, if this were not so, where is the point where a high pivot is high enough to generate antiquat on its own without a chain?
Sorry for the delayed response, it was a while until I could watch the World Cup so I had to stay off Vital to avoid spoilers
9/11/2024 4:40pm
phase 1
linkage
high-pivot
I'm sorry, you are simply incorrect in your analysis. Virtually all antisquat comes from chain tension, and without it every vehicle with pivot-based suspension squats under...
image 53
I'm struggling to work out who is less wrong here - but yes a bike absolutely has anti squat (and anti rise) without a chain on it. The bike is being pushed by the swingarm which can pivot, so the response of the rider weight means it will likely try to tip one way or the other. The chain is just a second torque being added to the equation which can offset that moment. I think this needs its own thread
gmancillag
Providencia, Región Metropolitana CL
2671st
9/11/2024 9:36pm Edited Date/Time 9/11/2024 9:39pm
In the webpage that shows the new stumpjumper alloy it also appears the "2025 demo", but I'm pretty sure that's the 2024 color scheme, does that means they are just going to try to push that model into 2025 and then release the updated one next year? After all the time that they've been testing the new one with ubb kinda sucks they went that road (if they did), same with the "new" enduro with just the udh upgrade and the thrilling new Matte black color 🥱IMG 9197 0
896th
9/11/2024 11:06pm Edited Date/Time 9/11/2024 11:09pm
phase 1
linkage
high-pivot
image 53
"I'm sorry, you are simply incorrect in your analysis. Virtually all antisquat comes from chain tension, and without it every vehicle with pivot-based suspension squats under acceleration."
No. At least not necessarily or not in all cases.
It's very well known that Red Bull has anti dive suspension geometry in the front (for braking) and anti squat geometry in the rear on their F1 car. At least they fine tuned it better than everyone else in the previous years, all the teams probably have it to some extent.
https://suspensionsecrets.co.uk/anti-squat-dive-and-lift-geometry/
Antisquat (and antidive) geometry comes from cars, what bikes use is just an additional component due to chain drive that is very rarely used with cars. It's not something that was developed for bikes specifically. It comes from the motorcycle world. If anything, it's just so much more important than with other vehicles due to the nature of power delivery.
Jakub_G
SK
9/11/2024 11:40pm
"I'm sorry, you are simply incorrect in your analysis. Virtually all antisquat comes from chain tension, and without it every vehicle with pivot-based suspension squats...
Primoz, we are talking about bikes here 😁 so the question stands, does any bike out there has any antisquat with chain removed? If yes, how is the force generated?
896th
9/12/2024 12:31am Edited Date/Time 9/12/2024 12:35am
All of them to some extent. Maybe even a negative one. The only problem is how to apply torque to the rear wheel without the chain to see this effect. One way is to use an electric hub motor for example, an ebike with a hub motor would have to be evaluated in both modes.
The response is generated because of the longitudinal force applied to the rear axle (reaction force because of the force in the contact patch) that is not in line with the virtual pivot of the axle member.
If the virtual pivot is above the rear axle, the response will be antisquat. Of it is below, it will be pro squat. How much response will occur depends on the height of the CoG, wheelbase, etc.
The chain tension is just another layer on top of this behaviour, specific to chain driven vehicles (motorcycles and bikes).
iceman2058
IL
149th
9/12/2024 2:36am
All of them to some extent. Maybe even a negative one. The only problem is how to apply torque to the rear wheel without the chain...
Yep, that's what I said.
iceman2058
IL
149th
9/12/2024 2:41am
image 53
No, I am correct in my analysis. You need to look at the rear triangle as an isolated system in its own right, it can absolutely produce anti-squat in response to acceleration-inducing forces being applied to the rear axle, without needing to be above the line between the rear axle and the CoG. A high-pivot bike with an idler can certainly produce anti-squat even with the idler placed directly on the main pivot.
9/12/2024 2:42am
Jakub_G wrote:
Primoz, we are talking about bikes here 😁 so the question stands, does any bike out there has any antisquat with chain removed? If yes, how...
Anti squat is just representation of how much the bike responds to acceleration, which there won't be much of without a chain but its a proportion, nor a magnitude. you could put the chain straight through the centre of a single pivot bike, and if that had a high enough pivot there would still be much greater than 100% anti squat. That's why very high pivot bikes put the chain above the pivot  and still get around 120% AS
gonza.s.m.
dallas, TX US
1786th
9/12/2024 2:57am
who said that??
Anyway, then go for the Xfusion(much better) and super R+D system 😄😄
gonza.s.m.
dallas, TX US
1786th
9/12/2024 3:00am
Sorry, I don't get the point about "supporting" bike brands. This a discussion about bike features...then each one will decide what to buy.
Grave
Marquette Heights, IL US
9/12/2024 7:53am
You guys are so serious about mountain bikes. I'm getting a good laugh this morning. 😄
Grave
9/12/2024 7:54am
I experience accelerative phenomena with no chain all the time. Allow me a few minutes to generate some graphs.
Ginger_SPICE
B, NC US
668th
9/12/2024 9:22am Edited Date/Time 9/12/2024 9:27am
PisgahGnar wrote:
From the other site. Mechanical Transmission spotted.
One can only hope that this makes it to production at the X0 level. That said, IMO the most overlooked flaw with the Transmission design is how rigid the direct mount design is and how that transfers forces into the cage. The rigitity of direct mount in conjuction with the stronger "clutch" means standard impacts to the cage are much more severe, resulting in a number of bent alloy cages and broken carbon cages. I have observed this among a group of friends I ride with and to date the damaged cage count is up to 7 or 8 among 4 people. This also seems to be an issue with other users based on some feedback I've read online.
Keeping this in mind:
1) What makes mechanical T-Type 'better' than the existing mechanical X01? Maybe the ability to quickly change the cage/clutch assembly?
2) Does the ability to withstand severe side impacts really matter, and is this ability lost in the mechanical design? IMO the cage will take the brunt of impacts on any derailleur.
The last piece of this that I've tried to figure out is how the mechanical version will 'slow' down shifts like the electronic version does in order to shift cleaner under load. Would this be designed into the derailleur, the shifter, or both?
Nobble
Santa Cruz, CA US
9/12/2024 10:44am
Of the 7-8 cages your group has broken, do you know the distribution of what levels they were?
For the aluminum cages, I have a theory that the GX is the strongest, followed by XX, and the X0 is weakest.
The XX and X0 seem to bend at the big cutout. The XX looks like it’s forged while the X0 looks stamped.
The GX doesn’t have the cutout and seems to hold up better.
Ginger_SPICE
B, NC US
668th
9/12/2024 11:06am Edited Date/Time 9/12/2024 11:06am
Nobble wrote:
Of the 7-8 cages your group has broken, do you know the distribution of what levels they were?For the aluminum cages, I have a theory that...
Distribution is 3 X0 alloy cages and 4/5 XX cages.
I can't confirm exactly where the alloy cages are bending but in one instance the cage broke around the bottom pully and bent as a whole.
As for the carbon cages the majority have broken at the hole used to mount the upper pulley. One cage completely lost the lower 'guard' around the lower pulley.
At this point the distribution of derailleur levels being used among my friends is now 1 X0 and 3 XX SL. Any original XX cages were replaced with the XX SL carbon cage/clutch assembly.
smol lizard
Hurricane, UT US
1300th
9/12/2024 12:25pm
One can only hope that this makes it to production at the X0 level. That said, IMO the most overlooked flaw with the Transmission design is...
Regarding slowing down the shifts I’m guessing they’ll restrict the shifter to one click at a time like their ebike shifters, but beyond that I’m not so sure how they could slow down the shifts on a cable system.
9/12/2024 12:28pm
crazy, I've only ever broken 1 Sram Derailleur and that was when gx 12spd first came out. since that time ive owned prob 50% of each brand (big S)
and ive broken a heck of alot of Shimano derailleurs.
Same with chains actually, never broken a Sram one but i've broken a few shimano ones.
I've got 2 Transmission GX and they've seen some heavy abuse and shift awesome still.
Like i said im pretty 50/50 split with what brand i get so more certainly not fanboying anyone.
9/12/2024 12:36pm
Distribution is 3 X0 alloy cages and 4/5 XX cages.I can't confirm exactly where the alloy cages are bending but in one instance the cage broke...
Have you checked the chain length? If you are in the smallest cog there should be daylight above the chain to the top pulley. I see a lot sram bikes with a chain that's 1 link too long which puts huge strain on the cage as well as poor shifting. In the lower gears the chain is pulling straight through that top pulley so the cage cant rotate and will instead try to bend. It also be at the wrong angle to the cassette for smooth shifting. Check if there's room to take a link out.
lloyd506
213th
9/12/2024 12:39pm
Broke/bent an XO knuckle. At the time a replacement XO wasn’t available in Canada, and was 3 months out. Found one XX replacement.  Shits expensive, I think it was $230.
sprungmass
Calgary, AB CA
9/12/2024 12:54pm
I have yet to bend my XX cage but it is really flimsy. It appears that SRAM has moved the sacrificial part from hanger to cage. There is a solution however: https://cascadecomponents.bike/products/transmission-derailleur-cage
This cascade cage appears to be pretty burly and costs slightly more than OEM. Your friends should try going this route when they break the next one.
9/12/2024 1:30pm
image 53
No, I am correct in my analysis. You need to look at the rear triangle as an isolated system in its own right, it can absolutely...
When I read this (welcomed) derailment I wonder if I even know bikes, I thought it was as simple as this; bike has two wheels, is funner with gravity, unless gravity is opposing direction of movement. Buttt it appears they are a little more complex than that.
gibbon
9/12/2024 1:33pm
Regarding slowing down the shifts I’m guessing they’ll restrict the shifter to one click at a time like their ebike shifters, but beyond that I’m not...
I guess you could have a spring somewhere between the cable clamp and the mech. You push the shifter, it stretches the spring until the cassette rotates to a shift point and then the tension in the spring moves the mech.
SteveClimber
Perth, WA AU
2245th
9/12/2024 2:02pm
This has been discussed previously but the TLDR is that T-type doesn't slow the shifts down or know when to shift, it's just a byproduct of where the ramps are in the cassette.
Smashing through gears on a mechanical T-type won't shift faster or slower, as the cassette is the same and there are only so many ramps to engage the shift.
