How big are nekos rotors ? Look bigger than 220mm surely ? [img]https://p.vitalmtb.com/photos/forums/2022/03/11/12164/s1200_86EFD9A6_3ED0_484A_B69E_C8EA9E560AB2.jpg[/img]
Looks like a Galfer. Weren’t they prototyping a 246mm rotor last year? Or in 2020? The wave design which i think is the one on the photo, prior to last year’s 223mm proto with the cooling fins/blades/thingys.
Looks more than just that - different can, not only trunnion, and what seems like bb-tool cuts above the seal, I guess thats for dissasembly?
[img]https://dvosuspension.com/2020/wp-content/uploads/2020/09/topaz-2-top-gallery4.jpg[/img]
its the same reservoir in the JadeX, probaly they are ditching previous one for good
I'm no engineer, but that top shock mount on the rocker link looks like it will see a ton of rotation. I wonder if they have...
I'm no engineer, but that top shock mount on the rocker link looks like it will see a ton of rotation. I wonder if they have needle bearings or something to help with friction during rotation. I've run RWC needle bearings on a few bikes and in my experience, there is a tangible benefit.
the turner dw dhr had some extreme angle/rotation as well. i didn't follow but did it have any issues?
Not sure about the DHR, but I know that Scott made a big deal about their previous generation Gambler having minimal shock rotation. It was mentioned in nearly every article about the frame.
"The floating link creates a progressive feeling suspension with an almost direct compression of the shock, minimizing DU bushing rotation. This increases shock bushing life and improves small bump sensitivity.”
"The linkage system is designed to minimize shock hardware rotation; this reduces wear and Scott reckon helps keep the initial stroke nice and supple (more relevant when running an air shock). "
This doesn't seem to be something that gets mentioned by many (any?) companies nowadays. Maybe it's one of those mythical things, like pedal kickback
I would say this is a very long time coming. They got their 27.5 TX spot on but always make the 29ers so dull.
[img]https://p.vitalmtb.com/photos/forums/2022/03/11/12166/s1200_2e19e48ab56cf3e0bac8a56a03beba3c.jpg[/img]
I had heard rumblings the DW link Design has some limitations when it comes to long travel and big wheels.
Maybe They are doing the whole figuring out if they should move to a new suspension layout type thing before they update everything. Giant hangs onto designs and what not far longer than most companies so if there is a plan to update these bikes my guess is they want to creat another "future proof" platform to work from.
Or maybe they kinda don't actually care about being in every segment of MTB and or leading in any of them because manufacturing for other companies and making city bikes and e-bikes yields far more profit...
Not sure about the DHR, but I know that Scott made a big deal about their previous generation Gambler having minimal shock rotation. It was mentioned...
It was definitely a problem for me on the DW DHR. I went through countless linkage-side DU bushings. For example I started with brand new bushing/hardware on the first day of a rainy whistler trip and there was visible slop in the bushing by the end of the day. By the end of the trip I was wrapping the aluminum spacers in teflon tape each morning and each lunch break to minimize the movement haha.
Maybe They are doing the...
It was definitely a problem for me on the DW DHR. I went through countless linkage-side DU bushings. For example I started with brand new bushing/hardware...
Sounds like your rear shock was fkd
I had multiple different shocks on my DW-DHR and it stayed tight for years
It's a replacement 'bushing'. With RS the bearing mount is a whole different part number - either the top eyelet part (where the reservoir on the Super Deluxe attaches) or the damper body (or damper shaft/eyelet assy on the Coil Super Deluxe).
With Fox you can go either way. With RS you're 'stuck' with the given variant.
If you mean this: https://www.foxracingshox.de/media/image/cb/9a/b8/812-06-096-KIT-Kit-Mounting-Hardware-Bearing-Assy-Roller-Full-Complement-30mm-Wide-8mm-Diam-1.jpg
It's a replacement 'bushing'. With RS the bearing mount is a whole different part number - either the top eyelet part...
These Fox roller bearings are terrible about creaking/clicking. I had to replace them on both of my Santa Cruzes. I went with RWC needle bearings and haven't had any problems.
Closeup shots of the covered up prototype. The idler area is Session/Neko HP like. And it's a Horst link, so it's possible it was Neko's bike. Or a Session with a different seatstay maybe? o.O
Something new on the way from Michelin? Or is it another brand+ sharpie? Seems weird if it's a sharpie job as Michelin make awesome tyres so surely they wouldn't feel the need for this
Something new on the way from Michelin? Or is it another brand+ sharpie? Seems weird if it's a sharpie job as Michelin make awesome tyres so...
Maybe they don’t do hot patches on protos? Rear tire looks to have logos and I would imagine they would go full sharpie on both if that’s what they were doing
https://www.youtube.com/watch?v=ADXu2hPmRbE
Closeup shots of the covered up prototype. The idler area is Session/Neko HP like. And it's a Horst link, so it's possible it was Neko's...
one thing I noticed was the e-mtb style magnet on his front spokes, wheel speed sensor or something?
The image that post is referring to seems to have been deleted.
I sent my axs reverb back under warranty and it took over 12 months to get a replacement in my hands.
The replacement now has the same issue as the one that was sent back.
Would be curious as to what changes they have made?
Regarding shock bushing rotation, bearing mounts anyone?
I was thinking about upgrading the shock on my wife‘s Bronson v3 but it‘s somehow hard to find shocks with that mount.
