3/10/2022 5:56am
Surprised no one has noticed some tweaks to the session the TFR team is on. The idler is now in plain sight, and no longer has...
Surprised no one has noticed some tweaks to the session the TFR team is on. The idler is now in plain sight, and no longer has the chain stay on both sides. Hopefully this will fix some of the chain drop issues!
Speaking of chains dropping, apparently under hard riding, the Jekyll is horrible in the chain retention department. Mitch dropped a chain at the Ironton BME resulting in a DNF. Wonder if anyone has thought to put a full lower guide on?
Some are already ahead of the curve with regards to the lower guide...
https://p.vitalmtb.com/photos/users/44569/photos/149607/s1600_Neko_Mulally_s_custom_rig.jpg
3/10/2022 6:02am
seth sherlock's prototype intense from windrock today. [img]https://p.vitalmtb.com/photos/forums/2022/03/09/12150/s1200_B0E2937A_AF78_4310_AEB7_3C6FFEF27D7F.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2022/03/09/12149/s1200_02B798E7_A427_4081_9E6A_90FB6D40A21C.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2022/03/09/12147/s1200_FBB9BEC5_252D_4734_8F22_88A095CFF682.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2022/03/09/12148/s1200_1E45E505_8053_42F7_8C64_18B22FC324E1.jpg[/img]
Can someone push on the seat and make a video please. I feel if Ellsworth made a DH bike it would look similar.
I'm guessing the long front part of that rocker link is to reduce the leverage ratio and allow the use of a longer stroke shock for more control over the damping? That upper shock eyelet will see a lot of pivot rotation though...
610th
3/10/2022 6:35am
Instant Center Tracking Silly
3/10/2022 6:37am Edited Date/Time 3/10/2022 6:43am
Wonder if Jeff is going with non-ideal super high pivot so he can avoid patents? Where Neko is running the I-track pivot since he's not a...
Wonder if Jeff is going with non-ideal super high pivot so he can avoid patents? Where Neko is running the I-track pivot since he's not a retail company they let him borrow the design. Jeff has to play by different rules and probably doesn't want to license anything so he's stuck with a too-high high-pivot with a 8" long rocker haha.
Also, scary that this is still a 'work in progress' frame this far along. Jeff's instagram post said "this project making good progress". Not something you really want to be saying a couple weeks before the world cup season. That's something you post in November or December. haha.
I-track does not deal with pivot height. The I-track patent covers having the idler on a suspension member that is not the front triangle or the...
I-track does not deal with pivot height. The I-track patent covers having the idler on a suspension member that is not the front triangle or the swingarm in the case of a single pivot design. So it covers link mounted idlers on 4 and 6-bar suspension designs.
Having the idler concentric to one of the pivots on the front triangle if I recall correctly means it's 'frame mounted', as is the case with the Range.
Krispy wrote:
It looks like the idler on the Intense is attached to the swing arm so it would be I Track?
As noted regarding the Range, not if it's concentric to the pivot. It's hard to determine if it is or if it's not from the images we have.
As for the rocker, I'm guessing the rocker will be basically perpendicular to the shock and more or less to the chainstay too at full squish (or quite near perpendicular for all intents and purposes). Add to that peak load of a bottom out and you're loading the rocker immensely, with all that load (in tension) going through what appears to be very little material under the bolt.
Hopefully there's more material than there appears to be, but like I mentioned, I wouldn't be surprised if there were some failures down the line...
And all it would need to improve things would be to draw a straight line over the pivot area and not have it S-shaped...
Norristown, PA US
747th
3/10/2022 7:31am
mntnmrtn wrote:
Is that a proto TRP or E Thirteen drivetrain too ? I don't recall seeing those cranks anywhere yet.
my guess would be TRP, derailleur looks like it has the hall lock lever. i've heard they're working on cranks too.
mixmastamikal
Salt Lake City, UT US
2979th
3/10/2022 8:14am
Shout out to PHcross for the rendering. Not bad at all given what you had to work with.
Zuestman
Seattle, WA US
464th
3/10/2022 8:15am
Is that a new E13 crank?
3/10/2022 10:40am
I'm no engineer, but that top shock mount on the rocker link looks like it will see a ton of rotation. I wonder if they have needle bearings or something to help with friction during rotation. I've run RWC needle bearings on a few bikes and in my experience, there is a tangible benefit.
3/10/2022 11:33am
aenema wrote:
That rocker link has to be the longest ever and I'm sure won't cause any flex/stress on shock or bolts. Plus it is pretty hideous.
Agree, holy long rocker link batman! the hardware needs fine tuning as well it appears. but at least it is better looking than the M29. Now let's hope the team is fast on them and actually like them, as I got the impression none were really getting along with the previous proto's
3/10/2022 12:07pm
I can see why Gwin covers his up. Not exactly a looker. Shame, since that Cero m29 was one of the best looking bikes of the last 10 years.
3/10/2022 12:59pm
I just love how no matter what INTENSE does you all have some negative comments!!! How about this? How about we wait and see what happens?? What a novel idea!! If INTENSE did nothing you we say "great, another season same bike". If INTENSE creates something new "that thing is hideous and will be shit". How about we at the very least applaud the brand for trying something new? It takes a bold person to step out with a different approach AND this is DH racing, not like DH racing sells bikes? Unless AG, Seth or DAK do really well this weekend, then some of you keyboard warriors will be saying "I knew it would be awesome"......
Krispy
1878th
3/10/2022 1:07pm
As noted regarding the Range, not if it's concentric to the pivot. It's hard to determine if it is or if it's not from the images...
You can see that the idler is bolted to the swingarm. Not concentric.
66th
3/10/2022 1:11pm
in the pits today, confirmed it is i-Track. they're waiting on i-Track stickers to arrive, but they'll be on the bikes tonight it sounds like
3/10/2022 1:47pm
Awesome they've ditched the vpp, could be the return of great results on Intense again
3/10/2022 2:04pm
Literally two posts apart:
"but at least it is better looking than the M29."
"Shame, since that Cero m29 was one of the best looking bikes of the last 10 years"
Beauty is in the eye of the bee holder, or something like that I guess.
3/10/2022 2:08pm Edited Date/Time 3/10/2022 2:15pm
Anybody else wondering how the intense team accesses the shock for adjustments? Would be a pain if you have to take the shock off or remove the bottom cover every time you want to fiddle with a rebound knob.
nskerb
Kelso, WA US
3/10/2022 2:31pm
I just love how no matter what INTENSE does you all have some negative comments!!! How about this? How about we wait and see what happens...
Found Jeff's burner account
Stewyeww
3/10/2022 3:28pm
Expect to see some new frames for Neko in the next couple days!
Brisbane AU
308th
3/10/2022 4:15pm
Brook looks like his liking the idler still
3/10/2022 4:34pm
First post.
Somebody mentioned "I'm not an engineer but"
I are engineer, and our FEA says
Stewyeww
3/10/2022 4:48pm Edited Date/Time 3/10/2022 5:09pm
Tim Horton wrote:
First post. Somebody mentioned "I'm not an engineer but" I are engineer, and our FEA says [img]https://p.vitalmtb.com/photos/forums/2022/03/10/12162/s1200_Image16.jpg[/img]
First post.
The rocker is actually made out of an old hockey stick
3/10/2022 7:56pm Edited Date/Time 3/10/2022 7:59pm
I can see why Gwin covers his up. Not exactly a looker. Shame, since that Cero m29 was one of the best looking bikes of the...
I think its cool looking! It would be neat if it stays alloy. Intense carbon (other then the Sniper)is gimmicky.
3/11/2022 2:11am
Karabuka wrote:
[img]https://p.vitalmtb.com/photos/forums/2022/03/11/12163/s1200_Screenshot_20220311_065352_Instagram.jpg[/img]
Topaz2 with new graphics?
Brisbane AU
308th
3/11/2022 2:44am Edited Date/Time 3/11/2022 1:14pm
How big are nekos rotors ? Look bigger than 220mm surely ?
3/11/2022 3:15am Edited Date/Time 3/11/2022 3:24am
What a typo with the name :D
I think he mentioned in one of the episodes that it's 240? Or somewhere else maybe? Can't find it to be honest.
gibbon
3/11/2022 4:00am
How big are nekos rotors ? Look bigger than 220mm surely ? [img]https://p.vitalmtb.com/photos/forums/2022/03/11/12164/s1200_86EFD9A6_3ED0_484A_B69E_C8EA9E560AB2.jpg[/img]
They are and don't call me Shirley.
3/11/2022 5:32am
They’re the 246mm Galfer rotors.
