8/27/2024 9:46pm
saskskier wrote:
Finally swapped pads on my Lewis LH4's after a pretty solid summer (Swansea, Revelstoke, Golden (including a couple runs down Dead Dog/Psychosis DH course), Sun Peaks...
Finally swapped pads on my Lewis LH4's after a pretty solid summer (Swansea, Revelstoke, Golden (including a couple runs down Dead Dog/Psychosis DH course), Sun Peaks, Squamish and a whole bunch of shuttling) and things are still running and feeling great. I'm switching from the stock pads to Galfer green's and am super interested to see what kind of a difference they make over stock. I think I'll also swap the front rotor to a 220mm in the future, but only because I'm 123kg and want all the help I can get, not because I feel like they're lacking power.
So far, no regrets experimenting with them.
As a precaution, I was told organic pads on 220 mm rotors on Ultimates is too much to have any control. Your mileage may vary. As for...
As for wandering bite point of the Mavens, when I had similar effects on my Codes, I had to do a proper bleed on them to remove any air. Might not be the same in this case, just saying. It usually occurred on new brakes  (factory bleed) or after a full piston rebuild, master and slave, so I a complete cleaning of the system was involved.
I'd say leaving the cup open overnight will be a far cry from vacuuming the syringe. I always pull the bubbles out of my syringes, both when bleeding brakes and when bleeding suspension dampers. And lately doing a lot of the bleeding by vacuuming the system (pulling the oil through the brake from both sides). It can pull some air past the outer master cylinder seal and though the fittings if they are not perfect though...
Too much to have any control? What do you mean by that?
Honestly, everything has been an experiment with the Lewis brakes and I'm willing to keep experimenting. I'm not in a rush to go larger, but open to giving it a try down the road. Ha ha
8/27/2024 10:01pm
The power was coming on too fast and too much of it, it was basically like throwing out an anker behind you. That's what I've been told. Granted, it was a much lighter rider, but a very, VERY fast rider.
8/28/2024 1:54am
Nobble wrote:
Aren’t Hope Green and Galfer Green literally the same thing? I’m 90% sure my Hope pads said “Galfer” on the back, and the Hope coloring matches...
Aren’t Hope Green and Galfer Green literally the same thing? I’m 90% sure my Hope pads said “Galfer” on the back, and the Hope coloring matches the Galfer color system.
Close, but not identical (even though yes, Galfer does make the green Hope pads). There are some differences in how they look and feel.
nope, Galfer makes green pads, however they don't make Hope Green pads, it's the only hope pad not made by Galfer https://open.spotify.com/episode/3PILqAiTXFRvbVHVckhjY9?si=ldC5v_MnRRaXI40Y9O9JGAThey talk about pads...
They talk about pads at 43 min into the podcast Claim about brake pads at 47 they say that the green ones are not by Galfer
Interesting, I did not know that. 👍
DServy
Jackson, WY US
8/28/2024 5:41am
So, for what its anecdotally worth, the overnight bleed cup has fixed wandering bite points on multiple sets of shimanos that have rolled through my garage, and provided actual consistent magura bleeds after wiggling the caliper around a bit. I've done it on pretty much every mineral oil brake I've seen on a bike build, or owned (shimano, magura, TRP, mavens) to great success. I now make it a mandatory part of all the bikes I build a season (which could be upwards of 25). I wouldn't dare try with dot fluid due to its habit of absorbing water from the atmosphere, but mineral oil doesn't have that problem.
As for the exact mechanism for why it tends to work--outgassing or over bleed. It's worked well enough for me that it might be worth a try if you have the means.
Also wanted to give Pinner machine shop a shout out, their bleed cups are awesome.
https://pinnermachineshop.com/en-us/collections/bleed-cups
8/28/2024 8:37am
The power was coming on too fast and too much of it, it was basically like throwing out an anker behind you. That's what I've been...
Not going to lie, this intrigues me. Ha ha
TheKaiser
Storrs, CT US
8/28/2024 1:14pm
DServy wrote:
I think I've figured out how to get the wandering bite point, and also how to solve it when you get it. I do think the...
I think I've figured out how to get the wandering bite point, and also how to solve it when you get it. I do think the wandering bite point is caused by not bleeding (lever bleed or full bleed) without the contact adjustment fully wound out. Even a couple clicks wound in will cause some wandering bite point issues. So I'd start by making sure that whoever is bleeding them winds those fully out (and also pulls levers to bar during the bleed process at least a couple times). The couple time's I've bled mavens I've always gotten the wandering bite point when I haven't properly winded the contact adjustment out.
Though, to be safe now I wind them out, then back in, then back out during the bleed process.
The other thing that seems to have helped me on every mineral oil brake I've ever dealt with is leaving a bleed cup on the caliper overnight with the levers rubberbanded down. I recently got a set of pinner machine shop cup adaptors to fit some mavens, but I'm pretty sure if you're clever you could rig something up with a stick, some electrical tape and a maven syringe. This seems to help degass the mineral oil, andi s kinda similar to the suction method they mention with their syringes.
Wait a tic, are you leaving the bleed cup overnight on the caliper or the lever? I'm guessing you meant lever, but said caliper, unless Mavens have a reversed procedure from most other brakes. Assuming that is the case, and you also have the levers rubber banded, it seems like it could be accomplishing 2 things. The lever compression could be dissolving any remaining bubbles in the active pressurized part of the brake system, and/or the bleed cup could be allowing micro bubbles in the inactive unpressurized reservoir to filter up slowly. Tertiarily, when you release the lever the next day, any undissolved air in the pressurized portion of the brake may have made it's way up to the lever (aided by the smaller size of the pressurized bubbles allowing freer movement in the oil column) and can then be released up into the reservoir and bleed cup when you release the lever.
AnttiH
Tampere FI
8/28/2024 1:19pm Edited Date/Time 8/28/2024 1:22pm
AnttiH wrote:
I hate how much free throw is in my Trickstuff Maximas despite them being bled perfectly. After reading this and other threads it seems that's just...
I hate how much free throw is in my Trickstuff Maximas despite them being bled perfectly. After reading this and other threads it seems that's just how they are.
But I refuse to accept that I couldn't get an adjustable bite point for my overpriced anchors. By half accident I bumped into a guy who had the infamous Lewis LH4's on his bike and convinced him to lend me his front brake for a bit of testing. To no suprise the lever blade of the lh4 is a near identical copy of the Direttissima lever. Just a tad bit longer. This means that the lever blade and pushrod of the LH4 fits on the Direttissima/Maxima master housing!
This also means that the patented bite point adjuster can be retrofitted to trickstuff brakes with pretty much no modifications. I quickly measured how much difference the bite point adjuster makes and there's a good 15mm of actual change.
As the Lewis brake wasn't mine I just quickly tried it and switched it back. I'll try to order the lever blade and pushrod from lewis and report back.IMG 0345 0IMG 0344.jpg?VersionId=KcBdjlyBwIMG 0347.jpg?VersionId=tgnL1cprvOaeG0
Update on the Lewis levers. I contacted all Lewis dealers and none were able to offer parts. I sent an email to the Lewis factory in China and they're willing to sell the parts. All of the small parts combined for both brakes cost 108$+30$ express shipping to Finland. I have no clue how long the actual shipping time will be but hopefully I can test the setup soon.
Since the Lewis levers have the same size bearings as TS, the bite point adjuster can be retrofitted to Trickstuff levers by either swapping the part that the pushrod screws into for the lewis one or tapping the TS part for a M5x0.5mm thread (original pushrod is M4x0.7mm). I plan to first put the complete Lewis lever blades on since they seem to be a good middle ground between the Maxima and Direttissima lever.
The LH4 lever blade has a similar length to the Maxima lever but also has the same pivot point geometry of the Direttissima lever. The Maxima pivot placement gives more power than the Direttissima but also makes the lever feel spongier. This is also due to the longer overall lever blade length of course.
TheKaiser
Storrs, CT US
8/28/2024 1:45pm
Nobble wrote:
I’m bleeding them, and yes, the Sram manual tells you to wind out the adjuster.To clarify, my bite point doesn’t wander. They pump up on rapid...
To clarify, my bite point doesn’t wander. They pump up on rapid lever pulls.
If they are pumping up on rapid pulls but work consistently otherwise, as a general rule, it could be due to 2 different causes.
1. If the pumping up is taking you from an excessively long lever throw to a normal one, that is usually due to a poorly maintained brake that is low on fluid and/or has excessively worn pads, and/or has stick caliper pistons. Basically, the system is at a point where a single lever pull can barely generate enough fluid volume to activate the brake fully, so you need to "stack" multiple pulls on top of each other to get enough flow to get you to a normal bite point. You're working with a newish brake and sound like you're on top of maintenance so I DON'T think this is what you're dealing with, but am just including it for general diagnostic info purposes for other thread users.
2. If the pumping up is taking you from a normal lever throw to an excessively short one, that is nearly always due to a mismatch in fluid viscosity and hose/port sizes. If the fluid is too viscous relative to the hose or ports then, after a lever squeeze, it can't flow back from the caliper fast enough to sufficiently fill the depressurized master cylinder, so as soon as the M/C piston seal crosses the timing/equalization port to the reservoir the system will draw in extra fluid from the reservoir. This would normally work itself out and the fluid would go right back to the reservoir as soon as the flow back from the caliper catches up, but in a rapid repeat pulling scenario you will be closing off the timing/equalization port and reactivating the brake before the system can catch up and return to homeostasis, so the pulls "stack" on top of each other and create what is effectively an overfilled active portion of the brake. If you have a hose or fitting that has some manufacturing defect (a piece of metal flash partially occluding the fitting, a hose with a crushed liner, etc...) then replacing it should remedy the problem, but if you are having on both front and rear brakes then it sounds like more systemic. If other Mavens behave differently, it could be you have a bad batch of fluid, but if they are all like that, and you are comfortable using a 3rd party oil, then switching to one of the thinner mineral oil options like Redline Likewater or Putoline would quite possibly resolve the problem and give you a less damped feeling lever action to boot. Many people with wandering bite point issues on Shimano brakes swear by them, so they're pretty well tried and true in mineral oil brakes.
DServy
Jackson, WY US
8/28/2024 3:39pm
TheKaiser wrote:
Wait a tic, are you leaving the bleed cup overnight on the caliper or the lever? I'm guessing you meant lever, but said caliper, unless Mavens...
You're totally right, I meant levers. Updating
8/28/2024 10:37pm
AnttiH wrote:
Update on the Lewis levers. I contacted all Lewis dealers and none were able to offer parts. I sent an email to the Lewis factory in...
Drilling out an M4 to an M5 thread will probably not work, I don't think there's enough material. But making a new axle-nut shouldn't be that much of a problem? You'd just have to source the pushrods Smile
8/28/2024 10:39pm
TheKaiser wrote:
If they are pumping up on rapid pulls but work consistently otherwise, as a general rule, it could be due to 2 different causes.1. If the...
Like I mentioned, I experienced the same issue after a full rebuild or on the factory bleed on my Code RSCs. A proper bleed helped things and the lever was then consistent.
There is a third option - air in the system. The first pull compresses it and the second pull adds fluid. When you release the lever, the air can expand and pushes the fluid back.
AnttiH
Tampere FI
8/28/2024 10:49pm
Drilling out an M4 to an M5 thread will probably not work, I don't think there's enough material. But making a new axle-nut shouldn't be that...
There’s definitely enough material in the stock axle nut but I’ll give the lewis lever a test first.
8/28/2024 11:02pm
I checked things and for an M5 thread the hole to be drilled is larger than 4 mm. Still, drilling out an existing hole could be problematic. It would probably make sense to make a new nut also to be able to go back to the original setup. Drilling out the nut is a one way street.
HexonJuan
WI US
8/29/2024 6:30am
Purty much nailed that answer. Only thing I would add is work from simplest to hardest remedy. It does sound like you have excessive seal roll at the caliper to me. Given it's known that Mavens need the pistons cycled in and out a few times to develop the proper amount of piston slip, I would work that process a half dozen+ times, that's after insuring you don't have any kinks in the brake line.
Nobble
Santa Cruz, CA US
8/29/2024 7:12am
HexonJuan wrote:
Purty much nailed that answer. Only thing I would add is work from simplest to hardest remedy. It does sound like you have excessive seal roll...
If I had a dollar for every time I’ve massaged the pistons on these stupid brakes, I could buy a few six packs of beer to drown the pain these things have caused me.
The pistons aren’t retracting fast enough. I’ve tried lubricating them, I’ve tried not lubricating them, I’ve tried replacing the olive and barb, I’ve tried replacing the levers.
Replacing the levers helped, and they’re no longer bad enough that they’re gonna make me crash again but they’re still distracting.
They look like the calipers might be leaking now. Maybe this set is just cursed.
8/29/2024 11:11am
In the World cups incl world champs, Lots and lots of 'lever strapped to bar' to essentially purge the brake and keep a good solid feel..
Why is this a thing we must do? For reference Ever since I seen this years ago i've done it to all shimano/trp brakes, It gets rid of the wandering bite point for me, But i must do it every 2-3 rides.
My Mavens Once setup correctly(can be fiddly) have been fantastic. Park day after park day no worries.
8/30/2024 12:44am
Regarding the putoline I think it could be safely used on brake as Intend use it with the Trinity (and they work absolutly perfectly).
8/30/2024 3:23am
I have just realized there is a typo in the tilte of this thread. Can't unsee it now.
NicoZesty96
portogruaro, VE IT
8/30/2024 3:25am
Ops that was me 😓
jasbushey
8/30/2024 6:41am
Hey lets not derale this thread like the tech rumors...
HexonJuan
WI US
8/30/2024 7:15am
Nobble wrote:
If I had a dollar for every time I’ve massaged the pistons on these stupid brakes, I could buy a few six packs of beer to...
Slow retraction is a solid indicator of a fluid restriction. That can be from a deformed brake line or foreign object(s) blocking ports. Assuming you lubed the caliper pistons externally, I would not think of that as a leak but residual lube. barring a deformed brake line I would ping Sram tech support at this point. I think we can all agree you did your due diligence.
sprungmass
Calgary, AB CA
8/30/2024 10:56am Edited Date/Time 8/30/2024 10:56am
I remember watching the Trinity tech video and Cornelius said they got the idea from Shimano riders using Putoline to get rid of wandering bite point. He cited the PinkBike forums where someone used it and the idea caught on. So it technically can be used in any brake rated for mineral oil.
AnttiH
Tampere FI
9/1/2024 11:49am
Robstyle wrote:
Gave the trickstuff maven combo a decent run. I have a track that will make most brakes fade and will expose problems real quick.  I kept...
I kept the front pure maxima to ensure I defo would have a working brake at one end lol.
The triven combo went pretty good to be fair, it's got good modulation the top was muddy and icy and no issue keeping things in check.  But of no surprise to me the organic pads left the chat pretty quickly. Lever has more throw than I'd like, no surprises there either.
A fun experiement none the less.
How was the Trickstuff/Maven combo otherwise? So the modulation was ok, the lever pull is heavier and there's more free stroke. But how was the power? Is a full Maxima setup more powerful than with the Maven caliper? When I get the Lewis parts I think the free stroke issue could be resolved with the bite point adjuster. So I'm wondering if I could get more power out of the brakes with the Maven calipers?
Robstyle
Invercargill NZ
9/1/2024 6:04pm
AnttiH wrote:
How was the Trickstuff/Maven combo otherwise? So the modulation was ok, the lever pull is heavier and there's more free stroke. But how was the power...
The power is similar, without using the same pads it's hard to say exactly.
You have to overfill them a little to work, but yes a BPA will help. I reckon a 2.3 rotor would be mint too.
WMullins
Blind Bay, BC CA
9/2/2024 5:55am
thegromit wrote:
My saints are dying (RIP) they've been good but have always needed a bit of up keep. I find that all shimano brakes seem to be...
My saints are dying (RIP) they've been good but have always needed a bit of up keep. I find that all shimano brakes seem to be loosing oil and needing to be topped off during the lifetime of pads. Whats up with this design they always seem to need more oil.
I am thinking of moving to some hope v4 with 223 rotors. I had the tech 3's a long time a go and they felt goo but lacked some serious power. I am curious if I am going to regret moving over to a brake that might not have as much hit in the beginning. Any thoughts on hopes? I've heard they can be a little squeaky too.
Finkill wrote:
Made the move from Shimano to Hope Tech 4 V4 on my enduro bike this year. Took a little while to adjust to the modulation on...
Made the move from Shimano to Hope Tech 4 V4 on my enduro bike this year. Took a little while to adjust to the modulation on offer, but now love them. Galfer purple pads and 220mm rotors in the Alps were faultless. Back in the UK I'm on 203 rotors and the hope red pads. Come winter I will switch to sintered. The Green pads are super powerful but worried about lifespan.
There is some noise in certain situations, but totally fine and not really noticeable.
I now want to replace the Shimano brakes on my trail bike with Hope brakes.
Little late to this but I finally ended up pulling the trigger on a set of T4 V4's after experimenting with Code RSC's (with and without cascade cams) and a variety of Shimano setups over the past season. I appreciated the modulation of SRAM but the lack of power made them useless on any serious race runs. Kinda the opposite for the Shimano's, constantly locking them up and still didn't have the end-stroke power for big park days. After finally calling it quits on a set of XT lever+Saint caliper+MTX red pads, I ordered a set of Hope's via my employer/shop. Set them up with 203 Freeza rotors, green pads, and nonbraided lines.
At first I was a little worried due to the slightly mushy feeling in the lever, even when perfectly bled I could almost yank them to the bar with enough force. All those doubts went out the window the second I got them out on the trail. They have so much power that you never have to really pull on them. The modulation and ultralight lever feel gave me significantly better control compared to all other brakes I've used in the past, even TRP/Hayes/Magura. I would estimate my arm pump has decreased between %20-40 over a 3 minute DH run while posting consistently faster times. The only issue I've had so far is very minor rotor rub but probably due to me bleeding with the pistons pushed out slightly/brand new pads. No noise, fade, pump, or anything of that sort so far. Moving forward, I really can't see myself owning any bike over 140mm with anything other than Hope's on it (except maybe Trickstuff/Radic etc). Also, not as important, but the build quality and finish is very, very impressive. Really blew my mind compared to the mainstream brands.
sethimus
9/2/2024 7:11am
sprungmass wrote:
I remember watching the Trinity tech video and Cornelius said they got the idea from Shimano riders using Putoline to get rid of wandering bite point...
pretty sure this came up on the mtb-news.de forum first…
sprungmass
Calgary, AB CA
9/2/2024 7:38am
WMullins wrote:
Little late to this but I finally ended up pulling the trigger on a set of T4 V4's after experimenting with Code RSC's (with and without...
This is exactly why I decided to keep my TS Maxima. They felt exactly as you described. "Squishy lever" doesn't mean much when you have so much power and control on tap with little effort. Some people get too obsessed with a firm bite point
NicoZesty96
portogruaro, VE IT
9/2/2024 2:37pm
sprungmass wrote:
This is exactly why I decided to keep my TS Maxima. They felt exactly as you described. "Squishy lever" doesn't mean much when you have so...
Cause most people are on the stock codes or whatever, where you either have a mushy feel with no power, or a strong bite, again, with no power
So you just get hand fatigue
My Maguras are not that firm but the power is there so I never find myself pulling hard to stop or slow down
I guess that’s only elevated with superior brakes such as v4s and Maximas
9/2/2024 6:20pm
Speaking of Hand fatigue, just did 2 x park days in a row... I used to suffer bad hands with shimano XT's... but now on mavens and its surprising how much of a difference they have made to my riding & hand fatigue... no sore fingers etc just sore forearms etc from the huge bomb holes.
Just full blast into a corner, quick tap on the mavens and whip around the corner no sore/very little hands vs shimanos of start earlier, rear skipping with the front odd lock and pulling hard ending up with sore hands.
My Ebike XT's with Galfer 223's & ebike pads cope pretty OK though but havnt taken to a lift access place.( no worries of weight of 223's etc on ebike)
TheKaiser
Storrs, CT US
9/3/2024 10:45pm
In the World cups incl world champs, Lots and lots of 'lever strapped to bar' to essentially purge the brake and keep a good solid feel..Why...
When you say: "Why is this a thing we must do?" do you mean:
A. "Why do our very expensive brakes suck and require creative hacks to work?".
or B. "Why does strapping the lever down help our brakes work better?"
If you meant A, I can't tell you for sure, other than to say, either bike brake engineers lack the skill to make bike brakes perform consistently in real world conditions with real world maintenance programs, or they have the skill, but don't feel the consumer pressure to design the brakes with a priority on consistency, and instead are prioritizing looks, cost, profit margin, outright power, weight, etc...
If you meant B, we really dug into that topic of why strapping levers works starting on page 7 of this thread. Several ideas were bandied about, including some that were totally new to me, so I think it's worth going back to read it if you haven't yet. In short, the primary suggestions seemed to be the sustained pressure dissolves residual air into the oil, making it non-compressible, and/or the sustained pressure shrinks residual air bubbles down in size, making them float up through the system more readily, so they can ultimately reach the lever reservoir where they're unlikely to cause trouble, and/or the sustained hours-long pressure causes the pistons to slip through the caliper seals a bit more than normal, which resets them to a position closer to the rotor, leading to less lever throw required for full firm pad contact.
