9/19/2024 4:53pm
Looks like the new E13 rear hub should be out next week.  The speculation is that the paws disengage when the wheel is spinning to free...
Looks like the new E13 rear hub should be out next week.  The speculation is that the paws disengage when the wheel is spinning to free up the chain tension and pedal kick.
Screen Shot 2024-09-18 at 10.37.33 AM.png?VersionId=e90Hved6Bv
gibbon wrote:
Most E13 hubs disengage the pawls...................eventually.
true but now its a feature, not a bug!
Brisbane AU
9/19/2024 8:05pm Edited Date/Time 9/19/2024 8:11pm
7bc6f9 full.jpg?VersionId=reD
427f12 full.jpg?VersionId=qXQdqrD
1d3b06 full
26856f full
2bbbc2 full.jpg?VersionId=luxkry5GeIS
d98597 full 0.jpg?VersionId=u9.4yRPJvl4I
ec9f52 full
33
nsp234
9/19/2024 11:32pm
Probably next year with the new drivetrains, I've heard spring.
The master cylinder in some pics still looked milled…
9/20/2024 3:51am
How does the Pivot kinematic work ?
The wheel trajectory is defined by the 2 short links, and the seatstays+yoke are there to activate the shock and define the amount of travel ?
9/20/2024 4:03am
It's based off the dw6 link that the Athertons use that is a proper 6 bar (axle mounted to the seatstay link with a pivot on the chainstay). In this case the missing pivot is handled by the rear triangle flexing, so it really depends on how the axle/brake section of the triangle moves relative to the two ends of the triangle.
This is true for flex stay single pivots too, you can't characterise them as single pivots as it really depends on where the flexing occurs. If it's only in the seatstay, it's effectively a single pivot. If it's the chainstay (Cannondale does this with the thin section) it's basically a 4 bar. The reality is somewhere in between in practice.
9/20/2024 4:56am
tarekfahmy wrote:
Looks like the new Shimano are in the Vital Test Session in Whistler. We're def getting closer to a release :D
What new Shimano drivetrain in the spring?
Weren’t they supposed to release only the next Saint soon, and some version of the XTR?
gibbon
9/20/2024 5:48am
Saint has been due for about 5 years and we are waiting on Shimano Di2 electronic (with new brakes)
Jakub_G
SK
9/20/2024 8:36am
I was wondering if we would soon see bmx freecoaster hub technology appear for this reason! Would be fairly elegant if it works, but theres normally...
I was wondering if we would soon see bmx freecoaster hub technology appear for this reason! Would be fairly elegant if it works, but theres normally a ton of lag in those systems
Tairin hubs do that and lag is very reasonable, still faster pick up than Dt swiss
9/20/2024 9:28am
On the note of disengaging hubs and pedal kick, so long as whatever drive mechanism you have can automatically engage when you pedal forwards, it's impossible to prevent it from causing pedal kick. The drive mechanism, whether it be hub or BB based, can't differentiate between the chain getting pulled on due to you pedaling and the chain getting pulled on from the suspension compressing. Riding backwards is a little different in that you can use the fact that the hub is rotating backwards relative to the axle to disengage the hub.
seanfisseli
Santa Cruz, CA US
9/20/2024 10:19am
On the note of disengaging hubs and pedal kick, so long as whatever drive mechanism you have can automatically engage when you pedal forwards, it's impossible...
What if you make hub engagement so slow that your suspension can fully compress without the hub catching?
FaahkEet
Falls Church, VA US
9/20/2024 10:22am Edited Date/Time 9/20/2024 10:23am
A hub with 1 point of engagement and one pawl?
9/20/2024 10:33am
On average you'd have less kick, however there's always the chance your hub is up against its point of engagement and you'd get that kick right away.
Suns_PSD
Austin, TX US
9/20/2024 10:59am
I have a theory that e-bikes continue running on when you stop pedaling and therefore always experience pedal kick back as all slack in the hub is always removed.
JVP
Seattle, WA US
9/20/2024 10:59am
I'm still thinking that the pedal kickback perception has more to do with chain management than classic kickback caused by anti-squat. Said another way, it's the chain slap pulling the cassette forward, and then slamming into a pawls/teeth, vs chain growth, caused by anti-squat/growth. This has less (but still it's something) to do with hub engagement and more to do with various ways to control (damp) the chain oscillations and smashing forces when the chain movement comes to an abrupt halt against any of the various bike components.
I've played around a lot with making my bikes quiet, which makes the suspension feel great. This has a lot of overlap with the O-Chain and the E-Thirteen hub rumors. STFU, Hall Lock type derailleur mods (they're easy and I'm a big fan), O-Chain's elastomers, chainstay protection/wetting (VHS, etc), strong clutch... all these are likely components of the same improvement in suspension feel - they all mitigate the forces of chain flop.
In the case of the E-Thirteen hubs, or low-engagement hubs in general, I'm speculating that they reduce the harsh slamming of pawls by allowing enough play that the chain bottoms on the chainstay before hitting a hard stop via the freehub.
That's my theory.
9/20/2024 12:12pm
JVP wrote:
I'm still thinking that the pedal kickback perception has more to do with chain management than classic kickback caused by anti-squat. Said another way, it's the...
That's my theory.
Vorsprung had a video on exactly this.
mtbrdan
Scotts Valley, CA US
9/20/2024 10:09pm
What are you all hearing about the new SC e bike(s?). Named Vala, 160/150,Bosch system 5, non VPP, 600wh with an extender are the rumors I've compiled. Maybe an updated Bullit to follow?
9/20/2024 10:19pm Edited Date/Time 9/21/2024 3:03am
mtbrdan wrote:
What are you all hearing about the new SC e bike(s?). Named Vala, 160/150,Bosch system 5, non VPP, 600wh with an extender are the rumors I've...
Has the person who told you it won't use VPP explained why?  Seems unlikely...
Edit: oh of course, packaging
mtbrdan
9/20/2024 10:24pm
Found some info on the EMTB forums and also on a German E forum and the info lines up with most of what I've heard. We should know more in a week and a half. Garen from SC mentioned that he was up in Bend showing off a new Ebike then heading up to visit Pinkbike on the latest Roller Door pod.
gmancillag
Providencia, Región Metropolitana CL
9/20/2024 10:26pm
I read on a German forum that is going to be released in October, apparently they moved from the vpp on that one because the Bosch system wasn't compatible with the design.
9/20/2024 11:56pm Edited Date/Time 9/20/2024 11:57pm
For the why, packaging?
Edit: I should really read things through before commenting...
9/21/2024 5:38am
I know this site is more big bike centered but Corey Wallace (Kona endurance racer...) spotted on a proto g3 Hei-Hei. Proof that Kona is still alive!
jalopyj
Concord, CA US
9/21/2024 6:56am
I know this site is more big bike centered but Corey Wallace (Kona endurance racer...) spotted on a proto g3 Hei-Hei. Proof that Kona is still...
I would definitely be stoked to see a new hei hei come out.
9/22/2024 7:10pm
It already exists by small manufacturers in MTB, also nw bsd freecoaster eliminates lag in BMX world
longevity was never strong point of e13 hubs, starting from their dh with integrated cassette
9/22/2024 7:11pm
It is called oem formula hubs
seanfisseli
Santa Cruz, CA US
9/22/2024 8:45pm
Lowkey loved mine
9/22/2024 11:46pm
Looks like BOS Suspension is back on track with its MTB range:
https://www.vojomag.com/news/bos-suspension-revient-avec-une-nouvelle-gamme-vtt/
-> Idylle DH fork / Idylle SC (now named Kyll) (39mm stachions anyone?) / Deville + a DJ fork (the USD Obsys should be back too -oh word I'm hoping for a SC version)
sea-otter-bos-suspension-25-vojo-paul-humbert-44.jpg?VersionId=6EwGbgJi2qkitrP3YNLsea-otter-bos-suspension-25-vojo-paul-humbert-13
-> Void / Syors / Stoy shocks as well
sea-otter-bos-suspension-25-vojo-paul-humbert-20.jpg?VersionId=UESJ5AeEq3MwRxYB4LfH
-> aaaannd surprise surprise, a 2 or 4-pot braking system is in the works (using shimano pads)
sea-otter-bos-suspension-25-vojo-paul-humbert-37.jpg?VersionId=tEyTkcjPwoEnn69s9clz
25
lickmycrinkle
Beverly Hills, CA US
9/23/2024 12:45am
Weren't they back into MTB twice already? All I rem mber is the CEO spitting his dummy out over how nobody in MTB appreciates them and that they're never coming back. And they've come back twice since.
However, those parts look straight out of 2004, absolutely no thanks. If they're not gonna make themselves a viable option by actually selling their things, then it's all a moot point anyway.
Jakub_G
SK
9/23/2024 3:54am Edited Date/Time 9/23/2024 5:30am
Nico_Hrndz wrote:
Looks like BOS Suspension is back on track with its MTB range:https://www.vojomag.com/news/bos-suspension-revient-avec-une-nouvelle-gamme-vtt/-> Idylle DH fork / Idylle SC (now named Kyll) (39mm stachions anyone?)...
I don't think they actually left, idylle SC and DC were introduced relatively recently just after RS and fox came out with 38mm range, stoy3 is also one of the newer shocks on the market. Anyways, like to see them still going, my stoy rare is damn good shock and as reliable as they come.
