New Spindrift? I've been expecting it for a long time. But based on the ongoing sales since rampage, they probably overstocked the current version quite significantly...
New Spindrift? I've been expecting it for a long time. But based on the ongoing sales since rampage, they probably overstocked the current version quite significantly and had to get rid of that first.
"But the coil negative spring lets it down. For heavier riders like me, the extra air pressure creates an abrupt feel on touchdown, forcing me to compromise on support. For lighter riders, the spring should work well, but then the rebound could become too slow."
As soon as I saw that it uses a negative coil spring that was non-adjustable I knew it wasn't going to be worth getting. Unless you are at the exact intended body weight, you won't get full travel or you will get a harsh topout, as the reviewer found. He compensated by running less pressure and more compression, but it also appears the rebound is too aggressive, so even fully open it was too slow. Shame, the chassis looks promising. Doesn't Formula offer custom shim stacks that are user-install friendly? Perhaps that combined with a coil conversion kit could make this thing come alive.
The TLDR:
"But the coil negative spring lets it down. For heavier riders like me, the extra air pressure creates an abrupt feel on touchdown, forcing...
The TLDR:
the user installed valving is for compression only (they call it CTS). but yea, seems like some weird misses on this, especially since it's not like they don't have the features / tech already existing in the Selva.
The TLDR:
The TLDR:
Hopefully they will do the dual air and coil versions as they have with the Selva
The TLDR:
The TLDR:
Coil negative springs are bad engineering at this point. Coil negative springs only available in one weight is just sloppy customer care.
"there was an incident that ended the ride prematurely for another journalist. This particular rider, who weighs in the neighborhood of 190 lb (86 kg) went a little deep off a 5-foot rock drop, and the resulting landing force ended up snapping the frame at the seat tube near the shock mount area" -PB, on their Scalpel article
The TLDR:
The TLDR:
Not necessarily, there are clever ways to avoid their short comings while still utilizing their benefits. Unfortunately this design falls short of that though.
Rocky Mountain are doing full SRAM builds since T-Type, go check 2024 Instinct builds.
RM are also associated with IFHT films (Mahalo) so it's not that...
RM are also associated with IFHT films (Mahalo) so it's not that unlikely that a new promo video for the 2024 Altitude will be made by them.
In their instagram video I believe they said it's the Tyee.
A few weeks ago I asked Propane if they were going to spec the Vivid on a frame only and they said keep an eye on the site for changes. I suspect that was a hint at a new one?
I think I found the reason why:
"there was an incident that ended the ride prematurely for another journalist. This particular rider, who weighs in the...
Yeti was taking pot shots at the scalpel too in a few of their new asr adds
addsmage widgetimage widget
A few weeks ago I asked Propane if they were going to spec the Vivid on a...
Some time ago , I asked the compatibility of the tyee with a vivid air or ext aria , and they told me that neither of the two fits. Maybe it’s valid only for the S size 🤔
Did you get that for ordering directly from them? As a o-chain fan in excited to see what this is and hope as a multiple purchaser I can also have a 'crafted offer'... 😅
Did you get that for ordering directly from them? As a o-chain fan in excited to see what this is and hope as a multiple purchaser...
I’m interested in what this could be. I wonder if it’s a full new device?
That’s just their regular mailing list. I never ordered from them and also got that mail.
I got a new ochain recently and asked about what the new version will do and got the answer that the new models have been completely overhauled and they have solved some of the problems that the current models had, whether it was the four locking screws, maintenance or dirt getting in. And it will only come in the versions that are currently discounted, so SRAM, Shimano and RaceFace.
So probably nothing groundbreaking, just improvements.
To anyone saying that Lewis brakes are trickstuff clones...You say that because their look or the tech? Lewis patented their own adjustments systems. Take a look at Radic kaha and 612 brakes. For me those are sane kind of ripoff too with just visual differences.
If you read the pb article now they upped the weight to 220 lbs. seems a bit fishy
The TLDR:
The TLDR:
Sure, sure. But if a co doesn't cater to more than Typical Male measurements, a lot of the potential market will not be served well by the product. Maybe bad is an overstatement, but it certainly is an incomplete assignment.
Robert from The Loam Wolf here. I was the one who broke the Scalpel, and I’m not surprised I did - overshot the landing of a large jump for an XC bike, landing in the pocket between the landing and the flat ground after it. Huge bottom out.
I corrected Kaz at Pinkbike’s quote - he had flatteringly guessed me to be 190lbs, whereas I am 220lbs. Nothing fishy.
I wholeheartedly believe the Scalpel is fit for purpose and that it was my fault! Was having far too much fun and got carried away.
Yeti was taking pot shots at the scalpel too in a few of their new asr adds addsmage widgetimage widget
At first glance I thought the ASR was pretty slick, I'm in the market for a new 120ish full suspension frame this year and It's nice to have so many good options. I get the Cheeky marketing from them, poking fun at the competitors, but then I started thinking, there's no reason I would pick the ASR over the Epic 8. They are comparable in a lot of ways but Specialized was able to achieve their low frame weight AND add SWAT storage. I realize in-frame storage might not be important to XC racers but having owned a frame with SWAT, I love it. As a lot of these new-age XC bikes become so similar it's little details that will set them apart. I guess I'm just curious why someone would choose the ASR over the Epic 8. Turquoise color option?
Not sure I could tell them apart from that picture and I ride a Hugene.
A feature is published on Vital too, for a few hours already.
The TLDR:
https://www.vitalmtb.com/news/press-release/introducing-formula-belva-d…
Haha missed it, because it was at the bottom of the page for me, 2nd to last article.
Looks like the new Scalpel is dropping, but either it shouldn't be on the homepage yet or they forgot to unlock the article
They must be late since PB already published their article
https://www.pinkbike.com/news/first-ride-2024-cannondale-scalpel.html
Looks like it, but at the same time the Fit Grip sticker is on the bottom, that's a single adjust damper.
Sounds like Sea Otter is the release.
To be fair, they also had ads referencing the Santa Cruz Blur and Specialized Epic.
You can’t because it’s a tyee, they even say that on the insta post or YouTube don’t remember
Yeti: you just aren’t that guy. Stop it.
Cannondale doing some damage control.
