nskerb
Kelso, WA US
1/22/2024 12:11pm
smelly wrote:
It’s curious how Greg (Norco, really) and Neko are saying completely different things. Neko spends two years developing a race bike and concludes you can’t adjust...
It’s curious how Greg (Norco, really) and Neko are saying completely different things. Neko spends two years developing a race bike and concludes you can’t adjust anything independently, every change will affect something else. And complexity breeds its own challenges with marginal performance improvement.
Norco heads in the exact opposite direction, highly complex suspension with claims of independent adjustability. Making those changes in isolation would be so time consuming. To slacken the head angle and keep bb height the same you’ve have to switch out flip chips for both. Changing HA alters your front center, unless you move the BB - which would then change the rear center. According to Neko, any COG changes affect suspension  and if you can’t trust Neko, who can you trust?
on a personal level, bikes already require so much maintenance I can’t see buying something complicated for a marginal performance benefit I’m not talented enough to reap. As it stands my bikes need a couple full tear downs and rebuilds a year, which is like a half day job that would cost me $500 to have a shop do it all. Heaven forbid you’ve got headset routing.or more than 4 pivots.
Neko also had an article on PB a little while back stating basically there was no reason to run a mullet and they were objectively not faster than full 29 on a DH course. He’s rad but not everything he says should be taken as irrefutable truth.
1/22/2024 12:33pm
Nico_Hrndz wrote:
Loosedog teasing a new build. Double crown seems a bit overkill for a regular 4060LT, so might be a bigger rig to be revealed from Scor?
Screenshot 2024-01-22-14-11-29-98 1.png?VersionId=cVF24C4OuhGik.H5di
Heard they were playing around with AL and longer travel, but wasn't expecting double crown stuff.
chriskief
New York, NY US
1/22/2024 2:17pm
AndehM wrote:
Neko also has been very concerned about being able to manufacture these frames on a small scale while still hitting the required tolerances.  I think a...
Neko also has been very concerned about being able to manufacture these frames on a small scale while still hitting the required tolerances.  I think a lot of the stuff the Norco proto has in it will be incredibly tight for tolerances (like the eccentric machined BB area, the front shock mount, etc.).  Neko was having issues with just getting the swingarm to align well with the main triangle, which is why he went to carbon.  Every one of those adjustment features built into the frame adds a lot of complexity and demand for strict tolerance.  And besides this being an issue with durability, alignment issues can cause real issues with suspension performance.
I've got a bike by a big name with lots of adjustment built into it, and honestly, I'd rather they spent the time getting tighter tolerances.  The angle adjust headset cups are really picky about preload and being packed with grease otherwise they creak.  The rear end loves to move the linkage bearings, I'm speculating due to a tiny bit of misalignment between the rear and front.  But it's nothing obvious enough that I'd be able to win any warranty claim.
The latest PB podcast with Jessie Melamed goes into tolerance issues. Carbon frames coming out of the mold with minor differences (a couple millimeters here and there). And why two “identical” bikes aren’t riding exactly the same. Well worth a listen.
18
1/22/2024 3:14pm
brash wrote:
Greg was saying he could alter Geo characteristics without affecting another, say can slacken HTA but not BB height, STA etc.... how the fark do you...
Greg was saying he could alter Geo characteristics without affecting another, say can slacken HTA but not BB height, STA etc.... how the fark do you do that? Modular BB shell? I suppose STA doesn't mean a lot in DH but still, bold claim cotton.
the complex 6-bar suspension that norco is using allows for more fine tuning due to different bars of the suspension controlling specific kinematics. Neko was adamant about not using a suspension platform any more complex than a 4 bar to reduce production cost and manufacturing complexity. Building a bike is harder than it looks and Neko did it without the big corporation money. Norco had enough money to design, develop, and patent a crazy new dh concept AND sign on Greg. Im sure we can convince Neko to develop a 6 bar bike for the next iteration. Maybe an 8 bar...?
monarchmason
Nevada City, CA US
1/22/2024 3:56pm
the complex 6-bar suspension that norco is using allows for more fine tuning due to different bars of the suspension controlling specific kinematics. Neko was adamant...
Fuck it why not 10 bars? 10 bars. All oversized bearings. Internal shock. Titanium frame. External derailleur cable but internal brake cables through the headset. Proprietary pull shock. And uhhh… dang. I think I got Scott's next Gambler.
38
nskerb
Kelso, WA US
1/22/2024 7:45pm
Fuck it why not 10 bars? 10 bars. All oversized bearings. Internal shock. Titanium frame. External derailleur cable but internal brake cables through the headset. Proprietary...
You forgot one thing. Suspension lockout wires through the headset.
1/22/2024 9:11pm
Why not just go full roadie tech and run everything through the bars and stem? I swear I've seen a photo.
1/23/2024 4:22am
The Norco is a 4bar...
1/23/2024 7:55am
So 2023, lockout is wireless, just like the brakes. Processor for the ABS is in the frame.
1/23/2024 10:21am
Splayleg wrote:
Do you know any engineer that has podiumed at a World Cup? Not sure a degree is better than tires in the trenches
I think Jesse Melamed is also an engineer.
1/23/2024 11:33am
I'm pretty sure Loic studied mechanical engineering in university, as well
1/23/2024 1:15pm
The only difference I see is UDH and new colors.
Looks like we won't be seeing updated full models for at least a year, more likely 2+. Ripley V4 dropped in 2019. If they're releasing this rear triangle without a whole new bike, V5 is likely at least a year off. Meaning 2025.... 6 (or more) years for a model, un-changed. You didn't ever see that from the ~2010-2022 timeframe when bikes were constantly being updated and changed with the latest and greatest. As I said, evolution is slowing down a ton. For engineering reasons, but also being made worse by the market hurting badly.
PellyNH
Austin, TX US
1/23/2024 1:28pm
Looks like we won't be seeing updated full models for at least a year, more likely 2+. Ripley V4 dropped in 2019. If they're releasing this...
I'm not sure.....supposedly, the updated Ripmo was already set to launch and they opted to hold it back. (likely to clear excess inventory)
Ibis currently shows 25% off factory sales on Ripmo, Ripley, and Exie. Normally, that would mean clearing the way for new models. However, these days I honestly don't know if it means anything...
1/23/2024 2:08pm
you seen their latest prototype?
synBike
North Vancouver, BC CA
1/23/2024 3:19pm Edited Date/Time 1/23/2024 3:19pm
Don't open this can of worms again Grinning. Someone got in in their head that a 6 bar linkage bike is only a "real" 6 bar if the wheel and not the shock is attached to the follower links.
monarchmason
Nevada City, CA US
1/23/2024 3:44pm
synBike wrote:
Don't open this can of worms again . Someone got in in their head that a 6 bar linkage bike is only a "real" 6 bar if...
“Dont open this can of worms again.”
*proceeds to swiftly open it*
23
RockHugger
Denver, CO US
1/23/2024 8:05pm
PellyNH wrote:
New Ibis Ripmo AF and Ripley AF are live: https://www.ibiscycles.com/bikes/ripley-af
download
I can’t see them bringing a new design to market with the AF first. Carbon would lead. Big sales plus retailers selling all their demo fleets leaves me hopeful something more is coming.
Outlawed
Vancouver Island, BC CA
1/23/2024 9:48pm
Anyone heard what happened with the fork that Marzocchi was teasing prior to Rampage?
1/23/2024 10:11pm
Yeah they've been on sale since 2020, just mis-labelled as a Fox 40, whatever that is
1/23/2024 11:08pm
Yes. It's 4 bar.
1/23/2024 11:28pm Edited Date/Time 1/23/2024 11:31pm
IMG 5902
Anyone seen these from Lewis brakes? Can an 8-piston brake for Surron mean, for example, a lighter6-piston version for MTBs or e-MTBs? Wink
Still wondering why Hope stopped working on the new version of the 6-pot 2-3 years ago with all the positive feedback they received from the testing guys…
