Jotegr
Nakusp, BC CA
9/4/2024 12:01pm Edited Date/Time 9/4/2024 12:02pm
nskerb wrote:
It seems like the new hot thing is to want steeper head tube angles. It seems like a counter culture thing but who knows lol. I...
It seems like the new hot thing is to want steeper head tube angles. It seems like a counter culture thing but who knows lol. I guess I’m still living in the (recent) past. In highschool i rode a 2001 trek fuel that felt like it was actively trying to OTB and kill me. I still really like really slack trail bikes. Give me a 150mm bike with a 63° head tube angle and I’ll be happier than a pig in shit.
Meh, it really depends IMO. For my riding, adding an angleset to 2017-2020ish geometry bikes (which over the last 7 years I have done many times) have improved them in  every single way (downhill bikes aside).  Not to oversimplify it too much, I think there's some relationship between wheelbase and head angle that on the shorter wheelbases of yesteryear, the slacker head angle was a straight upgrade for aggressive riding. On the new long wheelbases, it's not. None of this stuff is in a vacuum.
EDIT: Acknowledging that it probably does help, seeing o-chains on idler equipped bikes is quite funny.
9/4/2024 12:45pm
Jotegr wrote:
Meh, it really depends IMO. For my riding, adding an angleset to 2017-2020ish geometry bikes (which over the last 7 years I have done many times)...
Just because a bike has an Idler doesn‘t mean it won‘t have pedal kickback. You can (and nearly always) have the main pivot still higher than the idler, because otherwise you would get terrible anti-squat.
It just depends on the difference between the main pivot (instant centre) and idler location, however high they are.
ZAKBROWN!
Salt Lake City, UT US
246th
9/4/2024 1:13pm
I ran an O-chain all summer in Whistler on my Kavenz, which theoretically should have minimal kickback, and was very happy I did.  It definitely still does something to quiet down the bike and reduce feedback through the pedals, possibly just by dampening chain movement.
FaahkEet
Falls Church, VA US
9/4/2024 1:22pm
it's the normal x01 dh crankset
Thanks, don't really follow DH parts so looked different from what I normally see and was a curious why grip tape would be placed there if that was ineed the case.
Simcik
Loma, CO US
9/4/2024 1:25pm
FaahkEet wrote:
Thanks, don't really follow DH parts so looked different from what I normally see and was a curious why grip tape would be placed there if...
DH cranks see a TON of shoe rub in that spot so it is there to give a little barrier from the shoes rubbing straight on the carbon arms. Enduro and trail carbon cranks will typically have clear mask on them to accomplish this but DH cranks just seem to get more rub be it BB width, conditions or terrain. Therefore they put some heavier duty protection on there.
lickmycrinkle
Beverly Hills, CA US
9/4/2024 1:40pm
ZAKBROWN! wrote:
I ran an O-chain all summer in Whistler on my Kavenz, which theoretically should have minimal kickback, and was very happy I did.  It definitely still...
Wet chains could well be quieter. Good theory.
30
Konda
Kidderminster GB
9/4/2024 2:43pm
https://www.bikeradar.com/news/shimano-cues-drop-bar
More gravel than a MTB rumour (please don't nuke me),  but I'm excited to see cues brifters finally on the horizon. I have some old XT calipers in the shed which have been waiting for some hydraulic brifters.
And what are gravel bikes but 90s mtbs with drop bars? 😅
TimBud
875th
9/4/2024 2:49pm
Time for a “gravel rumours” thread?
9/4/2024 6:46pm
You're already in it, all this stuff will just be (re)discovered in five years by the gravel crowd.
9/4/2024 8:46pm
Someone posted this guy before, which is a sick looking homemade bike. My question is, isn't the off-the-shelf oval ring clocked incorrectly because of the idler? Its...
My question is, isn't the off-the-shelf oval ring clocked incorrectly because of the idler? Its backwards, like the old 90s BioPace chainrings
It is.
iceman2058
IL
146th
9/5/2024 2:24am
Just because a bike has an Idler doesn‘t mean it won‘t have pedal kickback. You can (and nearly always) have the main pivot still higher than...
A high pivot point also generates anti-squat by virtue of it being situated above the rear wheel axle. When the rear wheel pushes the chain stay forward (as a result of pedaling), it wants to extend the suspension if the main pivot point is higher than the axle. This is one of the "magic ingredients" of the high-pivot design, generating anti-squat without having to rely on chain growth to do so. Yes, most typically place the idler in such a way as to generate a bit extra anti-squat as well (by placing it slightly below the high pivot), but yeah, the offset of the pivot relative to the wheel axle does a lot of the work.
9/5/2024 3:06am
The idler is actually placed so that it promotes squat to counter the (excessive) antisquat generated by the suspension geometry.
It's a game of fine tuning. But in either case, when there is a change in chain length (either by generating antisquat or pro squat), an Ochain will likely have a similar effect. If nothing else, it will work k the rebound with a high pivot bike as opposed in the compression cycle with a standard pivot bike.
iceman2058
IL
146th
9/5/2024 3:30am
The idler is actually placed so that it promotes squat to counter the (excessive) antisquat generated by the suspension geometry. It's a game of fine tuning. But...
We’re about to derail this train again…. But how would an idler placed below the pivot point be pro-squat? The chain tension would want to extend the suspension…which is what anti-squat is. Am I missing something?
B Rabbit
Sydney, NSW AU
9/5/2024 4:26am
From the Enduro Facebook group. Looks like the 2025 model will have a UDH chainstay update and that’s it.
IMG 1930.jpeg?VersionId=HBNIMG 1929.jpeg?VersionId=MFdZ3EyhvCY2y JsH2Y.qIiuvC6WIMG 1928
austin-NC
Lincolnton , NC US
1511th
9/5/2024 5:30am
I kind of like that they are doing this, its a great bike and it doesn't really need an update. Does that mean that the bikes should be a little cheaper especially the frame only option since the molds are long paid for?
9/5/2024 5:42am
We’re about to derail this train again…. But how would an idler placed below the pivot point be pro-squat? The chain tension would want to extend...
Who said it's placed below the (virtual) pivot? Smile
I worded it badly (rushing as I was typing during work on my phone) but tried to put it in general in regards to high pivot bikes and the nuances that the suspension kinematics and the chain tension cause when it comes to antisquat. Trying to say that the chain can be used to INDUCE squat because the geometry induces suspension extension, like you mentioned. That's why I said it's a game of fine tuning - with an idler you tune the behaviour with idler placement and thus the effect of the chain on the suspension while with a standard (low) layout you tune the behaviour with pivot placement to counteract the chain induced squatting behaviour.
In this case the idler is mounted to the seatstay (iTrack patent comes into play here), so there are additional details that come into play. I haven't yet gone through how having the idler mounted to one of the links affects the situation, so it's likely it's not as clear cut (so idler below or above the virtual pivot point). I'd bet it's a combination of the relative position (below/above) AND the torque applied to the link by the position of the idler.
iceman2058
IL
146th
9/5/2024 6:30am
Who said it's placed below the (virtual) pivot? :)I worded it badly (rushing as I was typing during work on my phone) but tried to put...
gibbon
9/5/2024 6:36am Edited Date/Time 9/5/2024 7:05am
austin-NC wrote:
I kind of like that they are doing this, its a great bike and it doesn't really need an update. Does that mean that the bikes...
Yeah right!
That said Hope actually did this. They calculated an amortized cost for the carbon bike including development time etc but then after a while they realized they had learnt so much from the project that could be applied to other carbon products and help to spread the sunk costs. So they dropped the price by £1000 (iirc) and gave a rebate to all the original customers!
This is very Hope-like.
In the Uk there was/is a salary sacrifice scheme you can use for buying a bike and save 25-30%. Hope signed up but it was a lot of paper work. So they just bought bikes for the staff instead .
They used to run the machines 24hr with a night shift but came to realise how bad for your health working nights is........so they scrapped it.
They were going to spend £2.5 million on a building a Velodrome......because the nearest one in Manchester is super busy (mostly because of the GB cycling team) and difficult for people to use.
I got to know Simon (One of the Hope CEOs) a little and have visited the factories a few times.They are super nice.
veefour
Cinderford GB
268th
9/5/2024 6:44am Edited Date/Time 9/5/2024 6:50am
gibbon wrote:
Yeah right! That said Hope actually did this. They calculated an amortized cost for the carbon bike including development time etc but then after a while they...
Yeah right!
Hope is a great company with admirable business practices. Then there's Specialized....they've made some great bikes (I've owned a few), but when it comes to business practices, not so great.
Grand Junction, CO US
9/5/2024 7:47am
Specialized has done some questionable things, especially on the legal end, but I don't feel pricing is an area they are adrift. After all, this isn't AIDS medication or some good/service needed for survival.
They should price at whatever level they feel the market will pay for their product. If they are wrong, nobody buys their stuff. Their loss. There is also a lot of nuance around product pricing and the underlying psychology around it. I'm not sure they'll actually sell more if they cut enduro pricing $500. Its a premium product, and people are generally okay paying more or "premium" (whatever that is).
We don't point the finger at toyota to drop the price of the Tacoma if a generation gets long in the tooth. Maybe they end up doing so if supply backs up, but if the market is in equilibrium, pricing is...pricing.
9/5/2024 7:51am
B-Practice Podcast at around the 30 minute mark, Dak „we should talk more about this in two months“
I‘m calling the Maxxis Radial Casing - or something similar.
Having ridden the new Schwalbe Tire on my DH Bike last weekend I can say that it is a very noticeable feel difference, exactly the thing everybody talks about in the reviews.
Not sure if it‘s the „next revolution“ but I would be surprised if other tire companies would miss out on this technology.
Suns_PSD
Austin, TX US
9/5/2024 8:13am
pinkrobe wrote:
I was at a dealer today, and they said that the new Sentinel was coming with internal storage and longer/lower/slacker treatment. Soonish.Also, alloy Stumpy 15 release...
Also, alloy Stumpy 15 release pushed back to spring/summer 2025.
The sentinel doesnt need the lower or slacker treatment... it 100% needs steeper & longer.best upgrade you can make to a sentinel is a 1deg headset...
best upgrade you can make to a sentinel is a 1deg headset to steepen the HTA.
You're living in 2026. We got more reach, we got steeper seat tubes, now stays are getting longer and occasionally proportional across sizes and stack heights...
You're living in 2026. We got more reach, we got steeper seat tubes, now stays are getting longer and occasionally proportional across sizes and stack heights are growing. Next step is to figure out that the crazy front centers slack head tubes, long forks and long reaches make weighting the front wheel really hard any time you're not pointed down something steep... moderate head angles let you ride a longer reach and have room to be dynamic on the bike without it turning into a bus. Geometron is already there on their latest bike, though it's still a pretty extreme take.
I do think bike geo will continue to evolve and I'd like to see taller stacks, longer chainstays, shorter stems in that 30mm range, and a bit steeper HTA of around 64.2' for even big bikes. This should result in a more upright position, better front wheel traction, the ability to manual easily, a lot of resistance to going OTB, while still managing overall length.
B Rabbit
Sydney, NSW AU
9/5/2024 8:28am Edited Date/Time 9/5/2024 8:29am
I’ve got one and it really does need an update IMO.  Adjustable geo from the stumpy Evo and an steeper seat tube would be nice.
I’m have no idea why the didn’t do this, then go the new design in a year or twos time.
And cheaper? Lol, that’s very wishful thinking Smile
NoahColorado
Fruita, CO US
2448th
9/5/2024 8:41am
If product life cycle length influenced pricing Shimano Saint would be free by now. 😆
44
nskerb
Kelso, WA US
9/5/2024 9:10am
Specialized has done some questionable things, especially on the legal end, but I don't feel pricing is an area they are adrift. After all, this isn't...
Toyota pricing has gone bonkers while somehow staying super under the radar. I bought a 19 Tacoma OR off the lot for 32k. I’m pretty sure a 23 OR is close to 50.
Books will be written on the life of the 5th gen runner. It came out when I was in middle school and I’m several years out of college now. The return on investment/development Toyota made off that generation has to be one of the greatest in the history of cars lol. The prices for them basically doubled while remaining identical besides a few facelifts.
bigbrett
1015th
9/5/2024 9:15am
B Rabbit wrote:
I’ve got one and it really does need an update IMO.  Adjustable geo from the stumpy Evo and an steeper seat tube would be nice. I’m have...
https://www.fairbicycle.com/product-page/drop-best-uc-m6?currency=USD has entered the chat. Tada, now your enduro is perfectly up-to-date Smile
Rick26
., QC CA
9/5/2024 9:29am
Some reviews back in 2019 stated that the bike needed a steeper seat tube angle, pretty sure it's still the case 5 years later.
It's quite surprising from Specialized to let the Enduro slowly drift away without doing anything when the competition had the time to release 2 generations of their enduro bikes since then.
senorbanana
San Jose, CA US
9/5/2024 9:57am
errr, I owned the enduro for a couple years and my headset cracked (along with most of my friend's enduros) and the seat angle sucks. def due for a geo update with size specific chainstays, updated headset design, lower leverage ratios, and trunnion delete.
amazing bike however
