8/3/2024 10:12pm
Did anybody notice that the quake has a 75 mm stroke shock and only 180 mm travel?  I feel like I haven’t seen any bikes that...
Did anybody notice that the quake has a 75 mm stroke shock and only 180 mm travel?  I feel like I haven’t seen any bikes that achieve that.  For example, patrol with Cascade Link and 65 mm flavor gets 180 as well.
You could get 100mm too if you wanted to. Typically a lower leverage rate, (more stroke less travel) is seen as desirable. If you adjust the damping properly a wide range of leverage ratios are viable.
8/3/2024 11:37pm
Doesn't the capra use a 250 mm shock?
8/4/2024 1:23am
The current model's a 230
8/4/2024 7:43am
The overall length doesn’t really matter nearly as much as how much the shock actually moves which in case is 65 mm for the Capra. So the same for every other Enduro bike in the travel category  like I was saying, I understand but this is the only bike I’ve ever seen. That’s a downhill bike speck shock (75 mm)with only 180 mm of rear wheel travel.  I know it’s not really a tech thing, but I was hoping someone else could give me some insight as to why Maren chose to go with such a long stroke shock for such a little wheel travel
seanfisseli
Santa Cruz, CA US
8/4/2024 7:52am
The overall length doesn’t really matter nearly as much as how much the shock actually moves which in case is 65 mm for the Capra. So...
Well it’s better for damping performance, right?
8/4/2024 8:27am
Another bike with a 75mm stroke getting just 180mm of travel is the Devinci Chainsaw - haven’t heard a single bad word about its suspension performance. But given it’s a high-pivot, this might not be so strange. Yet again, it depends mostly on what the engineers try (and manage) to achieve! Smile
f.i.t.nj
Englishtown, NJ US
8/4/2024 8:30am
Less stress on the shock & better for heavier riders are primary reasons. Also packaging. They seem to have plenty of room for any normal stroke shock out there.
A lot of times when you see long travel from a shorter stroke shock it’s because there wasn’t any room for something longer (water bottle, complex linkage, dropper clearance etc)
8/4/2024 10:37am
One thing we found when doing a 180 link for the Crestline DH bike is that it required a softer compression tune than a standard off the shelf shock has. Compared to a 65mm stroke shock driving the same amount of travel, on average the 75mm stroke shock generates 33% more damping force at the wheel for a given wheel speed input if the same shock tune is used on both. Pretty big difference. It’s great for heavier riders that are typically pushing the upper bounds for shock tune. Off the shelf tunes work much better for them in this case. For an average sized rider, there isn’t as much of an upside if any at all.
Uncle Cliffy
Medford, OR US
8/4/2024 11:51am
What’s old is new again. I’m going to use some freedom units here, so bear with me:
Close to 20 years ago there was a trend of using longer stroke shocks on downhill bikes. 3.5 inch stroke to be specific. Most downhill bikes back in the day had a 3 inch stroke. (Close to 75mm these days.) Intense M6 is one of them off the top of my head, and I’m pretty sure the first generation Wilson also ran a 10.5 x 9.5 shock. These bikes were never over 9” of travel. Consequently spring rates were very low.
The reasoning was to have a lower leverage ratio. 2.75-2.5 to 1 in most cases. Easier on the seals and shim stack/valving. It was a trend that didn’t really catch on. Marin probably just wants a lower leverage ratio on this bike for whatever reason.
2320th
8/4/2024 12:53pm
What’s old is new again. I’m going to use some freedom units here, so bear with me:Close to 20 years ago there was a trend of...
Remember the old wildcat trail? 200mm off of 2.25" stroke shock. They blew up if they fell over. They have learned.
Uncle Cliffy
Medford, OR US
8/4/2024 1:11pm
LOL. Same size shock my RM7 had. I cased a jump with the compression too high and that Vanilla RC tossed its cookies. 😆
gibbon
8/4/2024 2:27pm
Foes 2-1 with Curnutt shocks.
8/4/2024 8:52pm
One thing we found when doing a 180 link for the Crestline DH bike is that it required a softer compression tune than a standard off...
Does a change in leverage rate have effects on damper behaviour outside of the tune, or is it possible to set up functionally identically performing tunes regardless?
Possibly related question: Are the valve stacks used in dampers all made of the same material, or are there different grades of steel (or even other alloys) to accommodate the requirements of these different tunes?
8/4/2024 11:03pm
boozed wrote:
Does a change in leverage rate have effects on damper behaviour outside of the tune, or is it possible to set up functionally identically performing tunes...
That is a really good question. In theory you can get identical reactions at the wheel, however it’s one of the scenarios where theory and reality don’t really meet. To get truly identical performance you also have to tune the shaft speed at which the shock transitions from LSC to HSC. Without doing that, the bike with the longer shock (assuming equal progression and all) will be out of LSC sooner. With the adjusters you’ve got on a typical shock there isn’t really control over that transition specifically. Whether being out of LSC sooner or later is preferable is debatable.
As for material, generally speaking all steels share the same modulus of elasticity. Give or take a little of course. That and dimensions are what control stiffness of an individual shim. There are spring steels with a much higher yield. That just buys you deflection. Shims are so thin that deflection is easy to get.
To be honest these days, save for a particular air shock and frames that side load a lot, I don’t really see many shocks blowing up. Things have come a long ways. I haven’t converted a shock to a pogo in maybe a six years. Once upon a time a day of whistler was about all it took.
Karabuka
3114th
8/4/2024 11:25pm
Since we were talking about Specialized and now about custom tunes, I've heard that new stumpjumper sales/orders are abysmal...
nato
Christchurch NZ
8/5/2024 12:20am
If the price was right, I'd demo one and very much consider buying one, there's a lot to lIke (had a quick spin on the Ohlins one, very nice irl).
The price is not right. Maybe (next) winter will bring reasonable prices.
8/5/2024 12:24am
Saw one of those in Paganella yesterday. Absolutely wild, thought they put a moto shock on a DH bike at first. Fork was massive as well.
JerseyMojo
JE
861st
8/5/2024 12:25am
One of my friends had his first ride on his new Stumpy Ohlins yesterday. He loves it. I had a spin and it is very nice. Is it value for money - that depends - but he’s very happy with it. He had a V1 RipMo and seemed to gel with the Stumpy very well.
TimBud
875th
8/5/2024 12:29am
Is that info from all shops across all regions or just your mate at your lbs?
Even Spesh themselves won’t have full good access to all of that sales data.
8/5/2024 1:17am
TimBud wrote:
Is that info from all shops across all regions or just your mate at your lbs?Even Spesh themselves won’t have full good access to all of...
I imagine they'd notice if follow-up orders have dropped off
Also, just to throw in an opinion, how could they not have dropped off with those prices?
Sir HC
2036th
8/5/2024 1:31am
And at the price they want, you can have a Levo SL for the same price. Doesn't weigh much more and gives a fair bit of assistance to the top.
I have the previous version stumpy with the flex stays, looked at picking up a frame only. £4k for a frame is mental.
kingsleyrh
Hastings NZ
8/5/2024 1:54am
Yeh... likely because they haven't released the alloy version yet.
B Rabbit
Sydney, NSW AU
8/5/2024 2:48am
More likely it’s not a big enough change from the Evo and people don’t see the value in selling their current bike for an abysmal sum and then paying Spesh rrp prices.
slimshady
AR
8/5/2024 2:49am
Sir HC wrote:
And at the price they want, you can have a Levo SL for the same price. Doesn't weigh much more and gives a fair bit of...
Regular bikes have been subsidizing the insertion of ebikes for a long time now. This is just another step to make Joeys say "you kidding me? I can get a free motor and a battery for the same money?" and choose the ebike.
AJW1
Bracknell GB
1942nd
8/5/2024 4:06am
"More likely it’s not a big enough change from the Evo and people don’t see the value in selling their current bike for an abysmal sum and then paying Spesh rrp prices. "
Its a lovely bike. No complaints whatsoever. Even the pricing isn't terrible by the standards of the last few years.
But despite some incremental improvements (I personally am not against e-shifting), I can't say that it is any better than my 2020 bike. And arguably I have a better spec on my bike.
If I only had a [DH bike/ XC bike/ hardtail] and wanted a trail full suss; or I got burgled and needed to go shopping; it would be on my shortlist. But realistically, I don't need another trail bike. I wonder how many others would say the same?
Karabuka
3114th
8/5/2024 4:26am
Friend said he spoke with one of the reps, from what I understood central Europe gets all of the bikes from a single warehouse and they have acces to the asset management system they use to place orders and they can also see current inventory, total number of orders etc. Its for sure not definite but they must have a decent idea compared to the past sales. Tbh I agree its really hard time to lunch a bling new bike with a post covid excess inventory related sales
rludes025
Whitefish, MT US
2451st
8/5/2024 8:22am
Local shop says allocations are stupid, and Spech is holding them for themselves. He's gotten 2, and had to make phone calls for the second one for a customer. 3-4 month estimated delivery even though a consumer can order online.
ufka_pen15
3017th
8/5/2024 9:21am
IMG 1891
New Gen2 Dorado 37mm with drop dual bolt crown and special mudguard, only in Comp configuration tho. Listed directly on hayes/Manitou website and some other online stores.
IMG 1892 0.jpeg?VersionId=.pA4
8/5/2024 9:32am
The Expert and Pro models are also listed with the fender and new Top Crown. Seems nothing else changed tho
