5/5/2023 12:46pm Edited Date/Time 5/5/2023 12:49pm
Loic talked about the new Specialized DH rig on the Gypsy Tales podcast and mentioned that their linkages can be swapped out/changed to affect how reward (or not) the axle path is. Might just be for testing purpose and won't make it in the production bike. But interesting none the less and will allow them to easily dial in the perfect feel on the test mule.
5/5/2023 6:36pm
But do we even see holes in the frame of Camile's bike? That's a prerequisite for non headset routing (unless it's all external??).
veefour wrote:
Maybe every bike comes with a drill bit.  In all seriousness it'd be interesting to see sales figures at the end of the year to see...
Maybe every bike comes with a drill bit. Laughing
In all seriousness it'd be interesting to see sales figures at the end of the year to see which version is most popular.
Through headset routed, for sure.
I disagree, not a single person in my riding group is down for headset routed cables, most of us would prefer neatly done external given the option between headset and external routing.
TARTARA
GR
5/5/2023 9:59pm
Why the notification counter doesn't work properly... !?
Logopit 1683349050744
5/5/2023 10:39pm
I disagree, not a single person in my riding group is down for headset routed cables, most of us would prefer neatly done external given the...
I currently run fully external routing (the dropper hose enters the frame at the bottom of the seat tube). The next bike will likely be the same. I asked Propain yesterday (for a friend) if the Al Tyee can come with cables entering the downtube port instead of the headset from the factory as it would be stupid to have to replace the outers, cables and the rear brake hose just to have a normal setup.
The problem is I, you and your riding group are clearly not the average buyer. The average buyer buys with the eyes, not the head. Through headset routing (for better or worse) looks better. Therefore it will sell more. Even more so if it will be the default option when speccing a bike - most people won't change the spec and I doubt it's possible to change it after the fact because of the above mentioned hose length issue.
nsp234
5/6/2023 12:15am
I think it might look cleaner, so it works when seeing it online or from some distance.
As soon as you're getting closer you start noticing ugly proportions and poorly executed details. I saw an UNNO dash in person recently and the cheap shitty looks of that cable entry at the headset would be a dealbreaker even if I was okay with headset routing.
5/6/2023 6:34am
Vorsprung has been teasing what looks to be a shock, and their latest instagram post hints that they’ve collaborated with sprindex.
PisgahGnar
Hendersonville, NC US
5/6/2023 10:34am
Gentlemen, what are we looking at here?
IMG 1759.png?VersionId=u3CLTUzI97huVih
slimshady
AR
5/6/2023 10:51am
Canyon's shapeshifter?
5/6/2023 11:31am Edited Date/Time 5/6/2023 11:35am
Probably a Strive that is small enough for Jesse.
Also some of the updates Fox made to the X2 according to their website
https://www.ridefox.com/family.php?m=bike&family=floatx2
NEW base valve piston design and compression tune for increased damping performance and improved sensitivity
NEW bearing housing seal package virtually eliminates possibility of aeration
NEW scraper seal for improved durability
NEW more robust eyelet design on trunnion models
NEW 7000 series shock body on all models
NEW hard chrome damper shaft finish for increased durability
dunno if these „official“ points have been talked about here yet
atekt
Salt Lake City, UT US
5/6/2023 2:20pm
habaden wrote:
Anyone have any intel on what Forbidden is announcing next week?
lloyd506 wrote:
Druid v2 release
Virtual high pivot?
5/6/2023 5:14pm
pit bits from fort william BDS. most interesting is matt walker's proto and mention of atherton bikes running different flext patterns in the printed parts. some of the teams didn't want to give much up at this point. matt and the bike look so dialed in the riding footage. raw tomorrow
jazza_wil
whistler, BC CA
5/6/2023 6:13pm Edited Date/Time 5/6/2023 6:15pm
29 wrote:
Probably a Strive that is small enough for Jesse.    Also some of the updates Fox made to the X2 according to their website https://www.ridefox.com/family.php?m=bike&family=floatx2  ...
I emailed fox Canada the other day about an aerated shock ( Im not the original owner) and they said they have a ‘fix for this trouble’ for $200cad. Haven’t sent it in yet though
5/6/2023 7:15pm
pit bits from fort william BDS. most interesting is matt walker's proto and mention of atherton bikes running different flext patterns in the printed parts. some...
On the Atherton flex experiment, I figured it was the same lugs with the flex tuned by changing the wall thickness or layup of the carbon tubes. I wonder.
5/6/2023 11:06pm
Might be easier for them to adapt the wall thicknesses and fill ratios of the 3D printed parts to achieve a similar effect.
5/7/2023 2:32am
I know it has been mentioned already but are there any updates on the new boxxer release, shouldn’t it be spring/early 2023?
That’s about time now, a friend of mine is building up a new bike and it would be good to know if it’s worth it to wait for the new one.
5/7/2023 4:08am Edited Date/Time 5/7/2023 4:09am
Looking at the proto Saracen, it has a split pivot at the rear. What's up with the Split Pivot patent then? Trek shoed their variant at about the same time, supposedly giving them the ability to use the design royalty free, but what about Orbea and now Saracen? Is the SP patent US only?
EDIT: it appears to be so. Is Orbea sold in the US?
5/7/2023 6:11am
Looking at the proto Saracen, it has a split pivot at the rear. What's up with the Split Pivot patent then? Trek shoed their variant at...
Yes, my LBS (in California) is a dealer.
lloyd506
5/7/2023 1:58pm
lloyd506 wrote:
Druid v2 release
atekt wrote:
Virtual high pivot?
Looks like the same layout as the dh bike there are pictures of. There’s a pivot on rear triangle, can’t remember if on chain or brake stay.
Both colours look really good. Nice builds.
5/7/2023 3:19pm
lloyd506 wrote:
Druid v2 release
atekt wrote:
Virtual high pivot?
lloyd506 wrote:
Looks like the same layout as the dh bike there are pictures of. There’s a pivot on rear triangle, can’t remember if on chain or brake...
IMG 0417 1.jpg?VersionId=bQaFSvOkAVahuWt9w898Yk
5/7/2023 3:51pm Edited Date/Time 5/7/2023 4:01pm
It is (source: I worked at an Orbea dealer last summer). Devinci, Orbea, Hope, and Antidote all use it, to name a few off the top of my head.
5/7/2023 9:37pm
atekt wrote:
Virtual high pivot?
So the new bike will go with a much lower and more reasonable HP ? Riders were getting sick of getting pitched forward at the worst of times maybe ? Looks nice lets hope the finish and build quality matches the style of the bike, it might become a good contender.
fartsack
咸興市 KP
5/7/2023 11:05pm Edited Date/Time 5/8/2023 1:08am
this bike was sporting the allready seen new vivid as well as the boxxer (both without the blackbox sticker)
Plus a rather interesting looking rocker PXL 20230507 083824312.jpg?VersionId=rTkE8DTi44XOpOe8sbupLfrhzjG
5/8/2023 2:03am
fartsack wrote:
this bike was sporting the allready seen new vivid as well as the boxxer (both without the blackbox sticker) Plus a rather interesting looking rocker
As if they used 5Dev cranks as rockers.
5/8/2023 2:15am
3d printed and designed using topology optimisation (removing the unneeded material).
The "new Vivid", could it be called Hyper Deluxe? 😜
Brisbane AU
5/8/2023 2:41am
A little off topic but where did you get this pic ? it looks like its been enhanced using AI aka Topaz Labs
5/8/2023 3:01am
Possibly just blown up to a 1:1 pixel size and we're seeing the effects of post processing.
TARTARA
GR
5/8/2023 3:40am
The photo isn't original, someone added filters - modifications on it !
