My guess would be that the suntour made fork & shock body were the cheapest/easiest to source and that the internals are a completely custom affair...
My guess would be that the suntour made fork & shock body were the cheapest/easiest to source and that the internals are a completely custom affair. I’m not positive but I think ohlins used to do something similar until they invested in making their own lowers/uppers for their forks
EXT is doing that also. Their Era fork is actually the cassis from a XFusion Trace 36, but with a different steerer. It used to be that way anyways, maybe EXT has an exclusive design now.
Tom and Pauline are starting their XC season this weekend. Will they be on the blacked out BMC again, or a new Pinerello? I'm sure Pauline posted something about getting used to a new team and new bike...
Tom and Pauline are starting their XC season this weekend. Will they be on the blacked out BMC again, or a new Pinerello? I'm sure Pauline...
She was talking about getting used to her new CX bike during the CX season.
Ugh electronics, disgusting.
Now that that's out of the way: Very interesting to see them place the battery sort of inside the upper cage. Looks...
Now that that's out of the way: Very interesting to see them place the battery sort of inside the upper cage. Looks good.
wonder what features they're leaving out to tier down? the freewheel pulley? think we'll be able to stomp on it without breaking? less AI-supported install/tuning? (I know it's not AI, it's a joke)
wonder what features they're leaving out to tier down? the freewheel pulley? think we'll be able to stomp on it without breaking? less AI-supported install/tuning? (I...
Def the freewheel pulley (XO doesn't have it either...), maybe more plastic parts? Bushings instead of bearings in the pulleys. GX AXS Eagle probably offers some clues...
Def the freewheel pulley (XO doesn't have it either...), maybe more plastic parts? Bushings instead of bearings in the pulleys. GX AXS Eagle probably offers some...
It will still be 3-4x a linkglide group I see in my future.
Rough idea of how spesh demo prototype linkage might work. Essentially a 4 bar with an additional shock linkage. Link next to bb, and chainstay, would be a different shape for packaging, but pivot locations work.
The Levo SL delivers unmatched ride quality and capability, amplified. For the trail rider who craves serpentine singletrack, sending it skyward, and lives for advancing your skills and fitness. Meet your new bike, the Levo SL. You’ll be blown away by it’s unmatched combination of flawless handling, capability, and “2 X You” amplification that gives you the Power to Ride More Trails. Compare it to anything out there, with a motor or without, and we know you’ll agree — Levo SL is THE ULTIMATE TRAIL BIKE.
IT’S ALL ABOUT THE RIDE — When everything works just right a bike disappears when you ride it. We stripped away the mass to keep the Levo SL lean and responsive. It’s tough enough to withstand heavy abuse, but light enough to nail big moves. Its dialed geometry, kinematics, and shock tuning leave nothing desired.
THE FRAME OF REFERENCE — Everything starts here. Lively, precise ride feel. Strategic carbon fiber layup provides super-responsive chassis stiffness. We tuned the entire chassis—front end, rear end, and the link that unifies them—as a single unit to minimize lateral flex under pedaling to harness every bit of pedal force.
GEOMETRY OF CONTROL — The cockpit centers you in the bike, optimizing traction and corner control. The low bottom bracket, slack headtube angle, and reduced fork offset keep things stable in the rough while giving you the freedom to destroy the turns. The head angle can be personalized to, 63, 64.25, and 65.5 degrees.
LESS IS MORE – The Levo SL is greyhound lean and telepathically responsive. Its curated component selection is light, yet capable—for true trail riding. Put it all together and you get the benefits of amplification along with benchmark handling.
MIXED WHEEL — A 29” front wheel ensures stability and surefooted performance in the most hectic terrain, while a 27.5” rear wheel allows for a compact chainstay and super responsive behavior. If you prefer the rolling and traction benefits of a 29” rear wheel, just flip the pivot link chip and mount the big wheel.
TURBO OPERATING SYSTEM — Our seamlessly-integrated operating system delivers unmatched performance across torque, range, ride feel, ride quality, power, reliability, and rider experience. It’s the invisible hand that enables you to do more, know more, go farther, feel stronger, and have more fun.
SPECIALIZED SL 1.2 MOTOR — The all new Specialized SL 1.2 motor is whisper quiet, boasts unmatched smoothness, delivers 43% more torque (50Nm), and 33% more power (320 Watts) than its predecessor. Resulting in “2x You” performance; it’s you pedaling, but a side of you only a Levo can bring out.
GO DEEP RANGE — Levo SL features a premium, high quality, and seamlessly integrated 320Wh battery pack. Combined with the efficient motor, you’re set up for long, epic rides of up to 5 hours (in Eco Mode). For longer rides, just slide our 160 Wh Range Extender (sold separately) into your bottle cage—for 50% more range.
MASTERMIND TCU — Our most advanced and intuitive e-bike control unit. Connecting the bike, the Turbo OS, the Mission Control App as well as the rider, all in a protected and easily visible display. MasterMind TCU enables over-the-air updates so your bike will get even better over time. With MicroTune fine-tuning power output levels in real time is at your fingertips, optimizing range management and performance.
MISSION CONTROL APP — The Levo SL integrates fully with our Mission Control App and lets you personalize your motor characteristics with MicroTune, Support, and Peak Power. You can say goodbye to range anxiety with Smart Control, and even thwart would-be thieves with Turbo System Lock.
• All new carbon frame, comes in mixed wheel configuration (compatible to 29 rear with no extra parts needed.) New kinematic with flatter leverage curve which provides more support and playfulness off the top, but plenty of control in rougher conditions. The headtube angle and bottom bracket height are both adjustable.
• New SRAM XX Eagle transmission
• New SRAM Code Stealth Ultimate brakes
Observed this lever going to the new “code” caliper on a bike belonging to a Sram tech. Bleed port clearly states mineral oil
I’ve seen a spec sheet for an upcoming bike that had the brakes called out as “Code RS DB”…seeing the DB8 is their only mineral oil brake, I’m guessing DB will be their nomenclature in regards to mineral oil brakes.
Soooo Does anyone have an ETA on the New Commencal meta? Or what ever it shall be named.
Upcoming Boxxer confirmed it's 38 mm (or at least not 35 mm). Didn't have calipers handy to check it exactly though 🙂
i have the new GX AXS spec'd on my new ride but it's not expected to show up until late June. Not sure that means anything.
Any word on release date?
I just checked it out in the flesh in San Remo, Canyon is testing there with Rock Shox. No idea about any other details.
But we all saw it!
supposedly the only difference is materials.
That's a whole lotta bearings!
2 more pivot points than the current design.
pros: looks like no headset cable routing
cons: might have to sell both kidneys this time
biking in 2023 is wild man
Strut haters rejoice!
o rly? who would have thought!
SJ Evo adjustability but doesn’t need links to switch from mx to 29 :thumbs up:
Tom was on a new MTB today for the short track in France
https://www.vojomag.com/news/spyshot-le-pinarello-de-pauline-ferrand-pr…
From Vojomag
This isn't a "SpayHot"... it's almost a full review... L☻L !
