gonza.s.m.
dallas, TX US
3/9/2023 12:16pm
you all are the tech gurus, so enlighten me. this proto looks pretty high pivot. aren't most riders/brands settling in on mid-pivot after a few years...
you all are the tech gurus, so enlighten me. this proto looks pretty high pivot. aren't most riders/brands settling in on mid-pivot after a few years of high-pivot stuff? or am i mistaken?
It’s not THAT high is it? Looks similar to a Norco Shore or GT DH bike. I suspect it’s a Horst link, can kinda see a...
It’s not THAT high is it? Looks similar to a Norco Shore or GT DH bike. I suspect it’s a Horst link, can kinda see a pivot on the chainstay?
What surprises me most is that Yeti would go with this design? They have their 6bar e-bike platform and their switch infinity designs, so why not stay with the brand identity instead of following the mainstream?
Maybe because it is too complicated/unneeded to actually function well on a dh bike? I mean it works relatively well on their trail bikes (which cater...
Maybe because it is too complicated/unneeded to actually function well on a dh bike? I mean it works relatively well on their trail bikes (which cater to a bigger demographic, marketing wise, than a world cup racer) and such but is it needed on a dh bike when way simpler designs have won countless more races?
for me there are two answers:
1-some suspension systems are that bad efficient that high pivot make it better(Antisquat)
2- is in fashion to go high
airwreck
HI US
3/9/2023 12:27pm
The new air shock?
Screenshot 20230309-151457.png?VersionId=R. 63xFhqIBW
The new air shock?
I still have one of those boxes, can't even remember what was in it.
Onawalk
3/9/2023 12:37pm
rludes025 wrote:
I just stumbled on to this link within the 'roots run deep' page https://yeticycles.com/technology/special-projects
Screenshot 2023-03-09 120335
This can't be it, it's a Horst link!! They hid the pivot very well and threw me off the trail with the chainstay being completely inline...
They hid the pivot very well and threw me off the trail with the chainstay being completely inline with the rear axle.
Am I wrong thinking a Horst link bike has the chainstay pivot below the rear axle (assuming a line drawn between the centre of both front and rear axles)?
is the centre line of the chainstay pivot slightly above the rear axle?
3/9/2023 12:38pm
The new air shock?
The new air shock?
I'm guessing the Totem goodie box was packed full of spare seals and bushings. I never had a Totem, but all my friends that did said the forks always needed a rebuild and ate seals and bushings like cookie monster eats cookies.
3/9/2023 1:26pm
Onawalk wrote:
Am I wrong thinking a Horst link bike has the chainstay pivot below the rear axle (assuming a line drawn between the centre of both front...
That's a minor detail, I think Rocky got around the FSR patent by putting the pivot above the rear-centre line, so technically yes, but I'd say if the pivot is on the chainstay near the rear axle (and the brake link is floating obviously), then we categorise it as a horst link. It's gonna function more or less the same regardless of where the pivot actually is. QED, remember the older Demo where the main pivot was concentric so they could drop all the pivots, including the chainstay one? You can do something similar by raising all of them if you wanted for example.
And it very much looks like it's a 6-bar anyway, so the whole horst-link discussion is moot Smile
Re Totem, meh, I got swindled!
3/9/2023 2:02pm
Kinda funny that Richie Rude won South Africa on the same Saint groupset that's on this prototype 10 years later. Grinning
25
Simpancz
3/9/2023 2:25pm
Old does not mean obsolete 😆
3/9/2023 3:36pm
PisgahGnar wrote:
What is this business behind the chainring? I know some high pivots also use a second pulley attached to the bashguard, like the e13 guard on...
What is this business behind the chainring? I know some high pivots also use a second pulley attached to the bashguard, like the e13 guard on Forbidden's, but this is huge.
image-20230309130257-1
that pulley location reduces the negative effect of the derailleur clutch by keeping the chain in more of a parallelogram shape so there isn't as much growth
3/9/2023 5:22pm
https://i.imgur.com/PNzath0.png From @Marshall Willanholly in the team rumors thread. I see daylight! :P
From @Marshall Willanholly in the team rumors thread. I see daylight! Tongue
You can see the edge of the dogbone link inside the seat tube too, unless that's an oddly asymmetrical seat tube.
jazza_wil
whistler, BC CA
3/9/2023 6:28pm
dylanjp006 wrote:
Another company back in the dh game zerode!
zerode!B30AADC2-22EE-41EB-AC9D-6261B070454C
Their Instagram post has #pinion #gates
So gearbox belt drive dh bike?
Good to see them back in the game!
dylanjp006
Palmerston North NZ
3/9/2023 6:33pm
Remember speaking to a zerode athlete in October last year, he mentioned that zerode would be bringing back a dh bike but didn’t say anything about frame material or drivetrain system
3/9/2023 6:51pm
if you go to wheelbased.com they have a article on yeti suspension designs.
they show something like the dh bike .
Norristown, PA US
3/9/2023 7:44pm
MTBrent wrote:
That void behind the upper part of the shock looks like a prime area for a 6th bar to connect the rocker and chainstay/lower link...
the 6th bar goes outside the seat tube on the 160e, most likely to accommodate the dropper. DH bike doesn't need a dropper, so that wasn't a design constraint.
3/9/2023 10:49pm
Whoa! There have to be some more links in that seat tube!! The chainstay probably isn't mounted directly to the frame, but via another short link...
Whoa! There have to be some more links in that seat tube!! The chainstay probably isn't mounted directly to the frame, but via another short link and there's a dogbone link to the top link!
It says Sixfinity on the website but where is it hiding? Looks like the rocker could potentially actually be a split pivot and it also looks...
It says Sixfinity on the website but where is it hiding? Looks like the rocker could potentially actually be a split pivot and it also looks like something hiding in the seat tube behind the shock area…9F66B16B-0FAD-4F3A-AA08-EEBE3598FEF9.jpeg?VersionId=zQ
On high pivot design, you can get similar effect than switch infinity (or their 6 bar) by moving the pulley wheel instead of the main pivot.
This is possible since pulley don’t need to accept different diameters with fixed tooth count.
3/9/2023 11:32pm Edited Date/Time 3/9/2023 11:40pm
DDEDDAC8-EDC3-44BF-AD75-F278FDE28FF4
 0E50A63B-E76B-4B2B-BE2C-E2647799155B
On the topic of Zerode - 19.03. is the date! Wink
Looks like horizontal shock, hp-Horst link without the excessively high pivot, the frame doesn’t look like a tank!
loris_74
3/10/2023 12:08am
zerode.png?VersionId=d4qO6z f7k8yJBi6VQqBnogMcs
I would say still an "excessively" high pivot. There is a weird square jonction in front of the BB.
Nicolas M.
Steinheim DE
3/10/2023 1:25am
Probably because different suspension designs work best in different travel ranges.
laurikuris
Kiili vald, Harjumaa EE
3/10/2023 5:09am Edited Date/Time 3/10/2023 5:10am
Will new XO have alu/alloy cranks and cage? Not sure if those pictures have been here before.428362 full
 cb2a34 full.jpg?VersionId=Fv8u1bI6O4lp3DhM116j
3/10/2023 5:15am
That bash guard on the chainring looks like it has the eagle logo on it?
sprungmass
Calgary, AB CA
3/10/2023 7:31am
Looks about right. 9 cogs machined out of steel, 2 steel (die cut?) ones pinned and then last alloy 52T pressed on. Too bad they went Shimano route with all the pinned sprockets because the current eagle cassettes with 11 machined cluster are the cleanest looking. The new cranks look really nice. 5dev vibes.
weekndr
Boulder, CO US
3/10/2023 7:56am
Looks like integrated chain guides on the chain ring itself.
Leaked press release says bashguard compatible, but no need for a chain guide.
3/10/2023 8:15am
Integrated bashguards*
@sprungmass I think the 52T is a spider/carrier, the two smaller aluminium rings are pressed/pinned onto it and the lower 9 gears still appear to be single piece, as currently. Should make for a cheaper to make (cheaper to buy?) and a lighter cassette. With less endurance though (but Shimano also has 3 Al rings on the XTR cassette, 2 on the XT, 1 on the SLX and 0 on Deore).
3/10/2023 8:23am
Integrated bashguards* @sprungmass I think the 52T is a spider/carrier, the two smaller aluminium rings are pressed/pinned onto it and the lower 9 gears still appear...
xtr cassette is made of cheese unfortunately. buddy of mine trashed his after 3 months and most shimano pro‘s are running the xt one because of unreliability.
