3/9/2023 10:01am Edited Date/Time 3/9/2023 10:01am
you all are the tech gurus, so enlighten me. this proto looks pretty high pivot. aren't most riders/brands settling in on mid-pivot after a few years...
you all are the tech gurus, so enlighten me. this proto looks pretty high pivot. aren't most riders/brands settling in on mid-pivot after a few years of high-pivot stuff? or am i mistaken?
It’s not THAT high is it? Looks similar to a Norco Shore or GT DH bike. I suspect it’s a Horst link, can kinda see a...
It’s not THAT high is it? Looks similar to a Norco Shore or GT DH bike. I suspect it’s a Horst link, can kinda see a pivot on the chainstay?
What surprises me most is that Yeti would go with this design? They have their 6bar e-bike platform and their switch infinity designs, so why not stay with the brand identity instead of following the mainstream?
Maybe because it is too complicated/unneeded to actually function well on a dh bike? I mean it works relatively well on their trail bikes (which cater to a bigger demographic, marketing wise, than a world cup racer) and such but is it needed on a dh bike when way simpler designs have won countless more races?
PisgahGnar
Hendersonville, NC US
1724th
3/9/2023 10:03am Edited Date/Time 3/9/2023 10:31am
What is this business behind the chainring? I know some high pivots also use a second pulley attached to the bashguard, like the e13 guard on Forbidden's, but this is huge.
image-20230309130257-1
3/9/2023 10:12am
Less losses Tongue
The pivot looks a bit higher than what GT and Trek use (which is a low-high-pivot (lol...)) but I'd say still lower than what Norco and V4 Supreme use, let alone what Zerode did back in the day.
Do I spy two shock mounting positions near the BB?
Also, regarding horst link... There's a massive aluminium piece concentric to the rear axle. I vote split pivot. As for 6-bar and all, it's surprising to me how small the rocker link is considering it's a long travel bike...
3/9/2023 10:14am
The new air shock?
Screenshot 20230309-151457.png?VersionId=R. 63xFhqIBW
The new air shock?
krabo83 wrote:
that artwork gives me totem-vibes.
My thoughts exactly.
NoahColorado
Fruita, CO US
2448th
3/9/2023 10:17am
PisgahGnar wrote:
What is this business behind the chainring? I know some high pivots also use a second pulley attached to the bashguard, like the e13 guard on...
I don't know anything about this.
PisgahGnar
1724th
3/9/2023 10:23am
Less losses :P The pivot looks a bit higher than what GT and Trek use (which is a low-high-pivot (lol...)) but I'd say still lower than...
Less losses Tongue
The rocker size looks just like an Atherton, maybe even bigger.
Aksel_Lfft
Plaisance-du-Touch FR
3/9/2023 10:26am Edited Date/Time 3/9/2023 10:28am
Also, is it just me or is the upper part more like a pulley than a proper sprocket ? hmmm can't wait to see more angles of this suspension layout !
mtbAndy
Big Stone Gap, VA US
133rd
3/9/2023 10:34am
looking at the GT, you're right, same ballpark...thanks for clarification. also curious as to why a "non yeti" platform.
I listened to a podcast the other day where John Hall mentioned some platforms work better on some travels than others. It was a good podcast, other than some guy from off camera that kept butting in, you should check it out.
nsp234
3/9/2023 10:36am
Aksel_Lfft wrote:
Also, is it just me or is the upper part more like a pulley than a proper sprocket ? hmmm can't wait to see more angles...
Thought so as well, but after a second look it seems to be a round plate covering the pulley?
3/9/2023 10:41am Edited Date/Time 3/9/2023 10:43am
Less losses Tongue
Agreed on the pivot being mid-high and split pivot design rather than Horst link. Rear end looks quite similar to the Hope HB916 but with a higher pivot and smaller rocker link as mentioned. I think this design lends itself to being quite flexible for fine tuning kinematics while still being nicely packaged.
Should we start placing bets on what the kinematic numbers will be???😂
kcy4130
MT US
3/9/2023 10:52am
There's got to be a linear rail behind that seat tube, right? tehe. It would make sense to use a six bar like their ebike, I can't see any definite evidence of it tho.
3/9/2023 11:03am
I'd imagine the chain rub on the sides would be unbearable if there was no cog, but it does look pretty smooth to me. Maybe it could allow them to fine tune the chainline? If it were me I'd use that link on the idler to fine tune the position, or maybe have it under some sort of tension.
csermonet
GA US
3/9/2023 11:03am
Yeti always gets wild with their dh bike suspension, so i would expect something sorta novel on this one outside of  just being a high pivot/idler. we'll see soon enough
3/9/2023 11:04am
ArchiRaph wrote:
F77068E7-FCDD-4161-B285-0F285725A04E
gonza.s.m. wrote:
 yeti back to the business, hell yeah!
yeti.jpg?VersionId=X0vsbHfyWpSXJYAU7H5RWO0AFe
iwil815 wrote:
Quote at the bottom of the Richie video: “IT’S BEEN HUMBLING SEEING YETI WORK HARD TO BRING A DH RACE BIKE TO LIFE WITHOUT COMPROMISE. AFTER...
Quote at the bottom of the Richie video: “IT’S BEEN HUMBLING SEEING YETI WORK HARD TO BRING A DH RACE BIKE TO LIFE WITHOUT COMPROMISE. AFTER LEAVING THE SPORT ALMOST TEN YEARS AGO IT’S EXCITING TO GET THE OPPORTUNITY TO BE INVOLVED WITH ANOTHER YETI SPECIAL PROJECT.  RACING ENDURO OVER THE PAST DECADE HAS BEEN REALLY FULFILLING, BUT I AM EAGER TO EXPLORE DH AGAIN. I WANT TO PUSH MYSELF AT HIGHER SPEEDS AND GET IN TUNE WITH THAT DH MENTALITY AGAIN AND IDEALLY BRING THOSE BENEFITS OVER TO ENDURO. WHEN IT COMES DOWN TO IT, I JUST WANT TO GET ON A DH BIKE AGAIN AND HAVE SOME FUN.”
Looks like he will step into a few races on the new rig.
also judging by the shouting he's been on a spiked bottle again
Losifer
Sandia Park, NM US
1774th
3/9/2023 11:05am
Sure... Perhaps someone could guide you to some insight?
66th
3/9/2023 11:08am
csermonet wrote:
Yeti always gets wild with their dh bike suspension, so i would expect something sorta novel on this one outside of  just being a high pivot/idler...
3/9/2023 11:09am
Less losses Tongue
Kapolczer wrote:
Agreed on the pivot being mid-high and split pivot design rather than Horst link. Rear end looks quite similar to the Hope HB916 but with a...
Short links tend to be harder to optimize kinematics-wise than longer ones (thus Neko opting for the mother of all rockers) as the angle changes through the travel are more severe and can be more unfavourable in certain travel parts.
3/9/2023 11:10am
rludes025 wrote:
I just stumbled on to this link within the 'roots run deep' page https://yeticycles.com/technology/special-projects
Screenshot 2023-03-09 120335
This can't be it, it's a Horst link!!
They hid the pivot very well and threw me off the trail with the chainstay being completely inline with the rear axle.
kcy4130
MT US
3/9/2023 11:13am
Great find rludes! In the text: "First launched on our 160e to handle the specific requirements of an e-MTB, the nerds at Yeti re-applied Sixfinity in a whole new way with one singular goal in mind: to build the fastest Downhill Mountain Bike ever."
3/9/2023 11:15am
return of the MRP roller chainguides? missed out on the opportunity to come out with orange rollers again haha
El Granada, CA US
347th
3/9/2023 11:16am
kcy4130 wrote:
Great find rludes! In the text: "First launched on our 160e to handle the specific requirements of an e-MTB, the nerds at Yeti re-applied Sixfinity in...
Yeah, I noticed that too.  And look at the seat tube, it's huge, with a cutout behind the rocker.  I bet it's 6-bar like their ebike, with the extra bar going from the swingarm through the seat tube to the rocker.
3/9/2023 11:19am
Whoa! There have to be some more links in that seat tube!! The chainstay probably isn't mounted directly to the frame, but via another short link and there's a dogbone link to the top link!
Sonofbovril2
ZA
2976th
3/9/2023 11:24am
Whoa! There have to be some more links in that seat tube!! The chainstay probably isn't mounted directly to the frame, but via another short link...
It says Sixfinity on the website but where is it hiding? Looks like the rocker could potentially actually be a split pivot and it also looks like something hiding in the seat tube behind the shock area…9F66B16B-0FAD-4F3A-AA08-EEBE3598FEF9.jpeg?VersionId=zQ
3/9/2023 11:28am Edited Date/Time 3/9/2023 11:28am
Exactly. You do not put a fender on the seatstay bridge to not cover the 'seat tube' with mud (you do it to prevent mud covering the links in there) and you do not make the seattube THAT chungus only to cut a hole in it without a reason.
Obviously I could be wrong, I did say it's a split-pivot about half an hour ago...
krisrayner
San Luis Obispo, CA US
3/9/2023 11:30am
#TBT to Richie smoking Loris at World Champs in South Africa
Screen Shot 2013-08-30 at 1.33.13 PM copy
MTBrent
Concord, NH US
3/9/2023 11:32am
That void behind the upper part of the shock looks like a prime area for a 6th bar to connect the rocker and chainstay/lower link...
