I thought there was some corrosion issue with aluminum to carbon. Atherton is doing all aluminum or carbon ti.
Not sure why the bike industry is...
Not sure why the bike industry is so against castings… all these machined rear triangle parts could be cast cheaply. Could do sand castings off a machined piece to reduce tool cost?
Could also do magnesium castings for chainstay/seatstays- similar to a fork lower leg. Tooling for that is insane but part cost is very low.
FWIW, Polaris (and I think Ferrari) has done carbon to aluminum using LORD's adhesive. In the snowmobile world, the parts being bonded were critical load bearing parts of the chassis, so I *think* it can be done.
That said, Polaris said fuck it and went back to aluminum to aluminum because they realized nobody cares about the minimal weight savings of carbon fiber in this application.
I'd say sand casting will have a big issue with porosity. You'd need high pressure die casting to achieve compactness. Also, I'd say mechanical properties of casting ready aluminium alloys might be a bit on the lower side compared to 6000 and 7000 'aircraft grade' alloys, I wouldn't be surprised if this was the primary factor. That and the cost of investment.
Casting is very good for chunky parts. I'd say it'd be good for rocker links for example. Seatstays and chainstays I'm not so sure... Fork lowers are still tubes which gives them a lot of strength.
Also, yeah, flax fibres are widely used. Apparently damping properties of it are very very good.
I'd say sand casting will have a big issue with porosity. You'd need high pressure die casting to achieve compactness. Also, I'd say mechanical properties of...
Doesn’t need to be airtight 😂
Agree about the agriculture grade materials- we did some gravity cast aluminum bits- was close enough to 6061 to work.
Forks are die cast mag- as they do need to hold air/oil and get the good surface finish.
either way cool to see different manufacturing types coming, just seems everyone is focused on staying high end.
Experience from working in warranty at a carbon crank manufacturer years ago. The layer that forms on aluminum when air hits it prevents the bond from fully happening and over time they are prone to separating. Maybe I am not fully understanding what was going on, but that was essentially what happened each time cranks came in for warranty. Was extremely rare to see an actual carbon failure aside from impact on them.
FWIW, Polaris (and I think Ferrari) has done carbon to aluminum using LORD's adhesive. In the snowmobile world, the parts being bonded were critical load bearing...
I was told (friend of a friend kinda deal, so far from first hand experience) that anything not aerospace in regards to aluminium to carbon bonding will likely corrode in ~5 years. The guy, apparently an aerospace engineer, said he wouldn't ride a carbon bike or wheels, or a car or a racecar with a carbon tub with aluminium inserts if over 5 years old. You also have different temperature expansion coefficient problem with the two materials acting on the bonded joint.
On the other hand aluminium cars are bonded, not welded, partly because of the reasons that were outlined in the last few posts - energy intensity, warpage, surface finish, etc. That and parts tend to be extruded and/or cast (Tesla megacasting). Also, Lotus Elise: https://www.youtube.com/watch?v=a-TiFKr2yb0
As for Lord, they are part of the Parker conglomerate, the biggest motion control company in the world, a Fortune 500 company, etc. They are very legit
Hey rumor dwellers, anyone paid some attention to Brose’s concept bike? Which has a new motor with an integrated gearbox a la Pinion MGU?!?!
Now lets speculate what Specialized are waiting for to be thoroughly tested and refined before they release the next Kenevo! 😜😁
Hey rumor dwellers, anyone paid some attention to Brose’s concept bike? Which has a new motor with an integrated gearbox a la Pinion MGU?!?! ;) Now...
Searched quick but couldn't find anything, got a link?? That sounds very interesting
I just read into flax fiber a little, unfortunately its not as strong under performance use in comparison to standard carbon fiber. Probably why we do not have it for bikes. Sad.
back in college some friends of mine were making steel hardtails with lugged carbon tube seat stays and top tubes. the guys that ran Draco if...
back in college some friends of mine were making steel hardtails with lugged carbon tube seat stays and top tubes. the guys that ran Draco if anyone remembers that from that PB era, i wanna say 06-08ish? they were very cool frames and i regret not being able to afford one at the time.
Damn that brings back some memories! I had a Draco, the only Tonka yellow one as far as I know. I would love to know where that frame is now
I just read into flax fiber a little, unfortunately its not as strong under performance use in comparison to standard carbon fiber. Probably why we do...
I think it's also a bit harder to work with. And it's a bit oily so epoxy doesn't stick to it as well and tends to crack over time...
It is used in ski construction quite a bit though.
Properly great looking bike, but its too big for a lot of people, is super boost, and has no official mullet option, which rules out quite a few potential customers
Edit: been beaten to it regarding super boost, but its still very annoying that they seemed to have made one step forward and two steps back
That's a good looking bike but yeah, the reach numbers are up in Canyon territory and Superboost
The sizing is just different, the small is what would normally be classed as a medium and then it goes from there, the last iteration of the chilcotin was a 464mm reach on the medium and no small option available. a bit off topic but why does everyone hate on superboost? most hubs nowadays can go 148 and 157 just by changing out the hub spacers. Maybe it doesn't bother me because i have superboost on my enduro and dh bike so the rims are interchangale
The sizing is just different, the small is what would normally be classed as a medium and then it goes from there, the last iteration of...
You also need to re-dish the rim 4.5mm to the non-drive side when adapting a hub from boost to super boost. You could perhaps get away with not doing this on some frames that have massive clearance, but it is definitely always going to be a compromise as the wheels aren't directly inline with each other
All the details on the new Ransom: https://www.vitalmtb.com/news/press-release/scott-introduces-all-new-ransom.
Looks like your mechanic will definitely hate you if you get this :)
What happened to Scott making light bikes? I realize it's ballpark with other bikes in its intended use category, but, Scott bikes used to be a good 2-3lbs lighter than the competition. I feel like a certain percentage of riders who purchased Scott bikes in the past were willing to look past their quirky features/integration because they were lightest in their respective categories.
So then call it a Medium?
As for Superboost, it's not the standard itself, it's that it's a different "standard". We have multiple MTBs in our household and they're all Boost which makes it easy to swap wheels for different uses and/or repairs. If we add a Superboost bike to the mix that no longer works and the performance boost (see what I did there?) at least for me, is negligible.
If Brendog's instagram story is anything to go by, it seems the new ransom might be out tomorrow
Fezzari brings out Monoform bamboo manufacturing to replace the carbon on their road bikes.
Hey rumor dwellers, anyone paid some attention to Brose’s concept bike? Which has a new motor with an integrated gearbox a la Pinion MGU?!?! Now lets speculate what Specialized are waiting for to be thoroughly tested and refined before they release the next Kenevo! 😜😁
It appears Dario (Pinkbike tech editor) was testing the SRAM Maven brakes yesterday.. Maybe launch is finally around the corner.
https://www.youtube.com/watch?v=rlcuXjeiHjY
Also there’s an instagram account about it - “brose.ebike” or something.
New banshee also seems imminent. Darkside as super enduro considering the sc fork?
New Chilcotin
Medium is 483mm reach, thats a stretch....
I love this bike!
https://knollybikes.com/en-ca/products/chilcotin-170
Martin Soederstroem just leaked the new Ramson
https://www.instagram.com/p/C2ztsBLilkZ/?igsh=amJxdmt4cW80bWJ4
More about the new Ransom: https://www.youtube.com/watch?v=rvzyDNuQeXY
My thought on Darkside as well, despite the single crown fork - just look at those huge rotors! 😁
All the details on the new Ransom: https://www.vitalmtb.com/news/press-release/scott-introduces-all-new-ra….
It's a 6-bar! Was not expecting that.
damn that thing’s ugly!!! imagine paying 10+k just to look like your riding an e-bike.
Wow.
Thanos bike, collecting all the forum hate stones with all that integration.
