SupremeShreder42
Kirchheim bei München DE
445th
8/24/2023 10:25am
New slash coming with a higher spec alloy frame option as well as carbon. The idler is friggin huuggggg. Mullet only as well confirmed, that proto...
New slash coming with a higher spec alloy frame option as well as carbon. The idler is friggin huuggggg. Mullet only as well confirmed, that proto floating around is accurate.
Not quite right,
alloy in a good spec is true
8/24/2023 10:42am
Yea that bike has been baked in for quite a while. I believe they shot the promo video and photos for it last fall. Assuming issues with supply chain, waiting on aluminum version and old stock to clear out of shops have delayed it. The shops stock is probably the big one. Shops bought a bunch of not-that-old Slashes for 2023 season and with bike glut and Specialized's insane pricing this year they've had trouble moving them out. Trek can't launch the new frame until the shop inventories are much lower, so they're waiting.
8/24/2023 12:13pm
For the 65mm stroke vivid, claimed weight is 670 grams. I just weighed my Cane Creek IL with a 450-550# coil on it, 63mm stroke. It...
For the 65mm stroke vivid, claimed weight is 670 grams. I just weighed my Cane Creek IL with a 450-550# coil on it, 63mm stroke. It is 720 grams. The EXT Storia is lighter for this size, but I don't remember off the top of my head the exact weight. Kinda kills the point of an air shock for me if I'm only saving 50 grams.
Are you seriously worried about 50g difference in shock weight on a 63mm stroke shock? I could cut my hair and lose 50g 😂 In my...
In my case where in the total system, the bike is maybe 20% of the weight, 50g especially on a performance suspension component is a trade off I’m willing to take.
The point is I'm not worried about a 50g difference, so I'll take coil every single time. It better be at least a 200 gram difference for me to consider air over a coil. My IL with a coil for my weight for my bike is barely heavier, and even tho it doesn't have a piggy back I'd say its still probably better than the vivid. The Vivid is $730, the IL can easily be found for half that, but The EXT Storia, also with a spring for my weight, is within spitting distance of the Vivid's weight and is only $999 that includes two coils, a custom tune, and excellent support (for north America). I don't see the benefit of this Vivid given the other options, since its so "heavy" for an air shock.
barryjenson
Sturdivant, MO US
8/24/2023 12:40pm
Big idler, less drag more pedalling efficiency.
Jrp
Derby , TAS AU
3833rd
8/24/2023 12:45pm
Not really tech but apparently fox factory brought ride concepts
El Granada, CA US
347th
8/24/2023 12:57pm
Wait, like Fox suspension?  That seems like a really weird jump considering they do no apparel / soft goods.  Fox Head makes more sense, but also kinda weird given that they just released their own shoes.
kcy4130
MT US
8/24/2023 1:21pm
The point is I'm not worried about a 50g difference, so I'll take coil every single time. It better be at least a 200 gram difference...
When talking about sram, not much (maybe none) of their stuff makes sense aftermarket at msrp. It makes sense to oem's because they get a much lower mark up on actual cost. Sram isn't alone in this of course, but their markups for end use customers vs bike companies seems a lot more mismatched than some companies. I mean the discount that ext or Cane Creek would give to an oem vs the regular price for us is probably not huge.
Also oem's and bike shops really want air cause it's one part number, (one size fits all, i.e. infinitely adjustable spring rate and one tune for a given frame). Instead of one tune and a bunch of different coils. Coil is a pain in the dick for them. That is why the vivid exists/makes sense. It might not make sense for you or me buying aftermaket, but it does make sense for trek et al.
earleb
North Vancouver, BC CA
225th
8/24/2023 1:37pm
Fox Factory owns Race Face...so adding shoes to the Race Face clothing kinda makes sense.
Whattheheel
Spearfish, SD US
8/24/2023 4:45pm
So when is the Slash going to be released?  I got an email from Trek showing it off so I figured it would already be on the front page?
haen
8/24/2023 5:37pm
So when is the Slash going to be released?  I got an email from Trek showing it off so I figured it would already be on...
show us the email!
Whattheheel
Spearfish, SD US
8/24/2023 5:39pm
I may have posted a pic to that other site under the same username...
8/24/2023 6:12pm
My buddy is a rep for Ride Concepts and he told me about a month ago that they were in talks to be acquired by a "big" company.  He couldn't tell me which but that makes sense.
mntnmrtn
NA, BC CA
1140th
8/24/2023 6:19pm
I thought the Nicolai Nucleon 16 looked a bit "busy" with the idler and rear LAL derailleur, and maybe it's the angle/lighting, but this Slash with both pulleys, big chain slap guard, long rear fender, chunky seat tube, shock mount etc. brings me late 90's vibes too. It probably rides great, but with the swoopy tube junctions and straighter/angular rear end, the lines don't flow that well IMO and it looks a bit "unfinished" in the industrial design department. In front of a white background with studio lighting, it would probably look more finished. My 0.02$.
8/24/2023 8:29pm
mntnmrtn wrote:
I thought the Nicolai Nucleon 16 looked a bit "busy" with the idler and rear LAL derailleur, and maybe it's the angle/lighting, but this Slash with...
IMO this two-tone paint is just not it. Specialized did a great job with the alloy Stumpy Evo, but to me this just makes it too busy, especially with the patterns. Hopefully other models have better combinations.
8/24/2023 9:01pm
Okay so we got Transmission, we got the Vivid, now 200mm AXS Reverb pls SRAM?  Anyone seen one recently?
TannerVal
Hampton, NH US
8/24/2023 9:46pm
Honestly I think it looks great, visually seems very unassuming but realistically has more bite than bark… which is the opposite of most bikes these days
8/24/2023 9:59pm
and a price decrease because the AXS reverb is heavily overpriced. but yes, 200+ is needed
anther side note, why havnt more brands offerd cheaper and longer droppers? (200+) is it just that oneup have this locked down?
nskerb
Kelso, WA US
8/24/2023 10:14pm
“I'd say its still probably better than the vivid.”
yeah fursure brah.
bulletbass man
Collegeville, PA US
169th
8/24/2023 11:02pm
Hope they have one in the Miami green, volt yellow color combo they did on slash a few years back
Endurhevia
CL
298th
8/25/2023 8:32am
Any info on the specialized bikes?? Enduro and both stumpjumper have been out for a while now... Specially the enduro.
Mas
OR US
8/25/2023 8:54am
They own Outside Van as well, I'm told they are growing the "lifestyle" segment of their brand.
mtbAndy
Big Stone Gap, VA US
133rd
8/25/2023 10:28am
They also own Race Face and Easton.
8/25/2023 12:19pm
cmaac wrote:
Could this in fact be a new remedy?
I could see that as being the most sensible - the current slash is pretty good & the remedy has not been updated in a long time.
Apparently its been confirmed as a slash.
The current gen slash is a darn good bike if you want to own one bike that actually pedals pretty good, im not convinced HP enduro bikes are good enough to justify its trade offs.
DonutMTB
Hagerstown, MD US
8/25/2023 3:07pm
p5pb25435251
Seen press info leaked from a buddy of mine, it is not the remedy, it's a new slash
170/170, high pivot, similar adjustments to the fuel EX, can seemingly be run either mullet or full 29
jasperg21
BE
3963rd
8/25/2023 3:22pm
I’ve just noticed that Danny Hart is racing the production 215 in Andorra, while during the rest of the season he was riding the prototype. Does anyone know why he would do this?
IMG 5686 0
