7/27/2023 10:54pm
Good to see they're still working with WAO for the rims, rather than venture out on their own and end up with something inferior. There's A...
Good to see they're still working with WAO for the rims, rather than venture out on their own and end up with something inferior. There's A LOT of established confidence in WAO.
dolface wrote:
Anyone know/care to speculate if they will offer a rim-only option? Been eying the WR1 Factions but the i9 rims are quite a but lighter which...
Anyone know/care to speculate if they will offer a rim-only option? Been eying the WR1 Factions but the i9 rims are quite a but lighter which is appealing to me...
These use their proprietary spoke and hub design, so no.
Proprietary spoke design? What about nipples?
7/27/2023 11:35pm
I9 has aluminium spokes that have the nipple 'built-in' - the spoke flares out to essentially make the nipple and it threads into the hub.
luisgutrod
Paris FR
7/28/2023 12:06am
the old torchs are bombproff, and the spokes are super sturdy compared to conventional spokes.. hard to destroy.. so, the train of the inmortal I9 hubs passed a few years ago when they introduced the fancier hydras
7/28/2023 4:34am Edited Date/Time 7/28/2023 4:35am
But is a standard nipple compatible with I9 rims, if you have a hub from another brand that’s using standard spokes?
7/28/2023 5:58am
luisgutrod wrote:
the old torchs are bombproff, and the spokes are super sturdy compared to conventional spokes.. hard to destroy.. so, the train of the inmortal I9 hubs...
they had some problems with the driveside bearings and axles breaking though, far from the best hubs
TannerVal
Hampton, NH US
7/28/2023 6:03am
7/28/2023 7:33am
Certainly not by design, perhaps by some janky hack. They don’t sell them rim-only anyways and you may as well get WAO at that point.
Moreno Valley, CA US
7/28/2023 8:44am
Disagree on the spokes I had two spokes snap in a bike case while shipping flying with the bike. Only time I have had an issue was with I9 wheels.
kcy4130
MT US
7/28/2023 10:04am
Srams' UDH spec models include a cable stop on the "Full mount" Model. Does this mean mechanical Transmission? https://www.universalderailleurhanger.com/
image-20230728103858-1
Sure looks like a cable stop. Great find. Couple more views.
image-20230728110200-1
image-20230728110235-2
image-20230728110315-3
7/28/2023 11:29am
TayRob wrote:
SX Transmission here we come!
SRAM is killing the high end componentry right now in terms of sales, but Shimano is winning in every cat XT and below.. SX Transmission is inevitable.
7/28/2023 12:37pm Edited Date/Time 7/28/2023 12:39pm
Makes total sense. Every argument I've read saying why it needs to be electronic to work properly doesn't really make sense when there's potential to sell a lot and take advantage of the mounting.
mspenc
Fort Collins, CO US
7/28/2023 1:06pm
Makes total sense. Every argument I've read saying why it needs to be electronic to work properly doesn't really make sense when there's potential to sell...
The electronics are more crucial when you consider the narrow-wide cassette teeth and how the chain moves on the ramps. SRAM could easily make a mechanical direct mount derailleur (NX maybe) but only work with the older style eagle cassette and have zero issues. That's truly what I want; the better shift quality is a plus for me but not critical - the durability is far more desirable.
7/28/2023 1:57pm
I don't know where you're getting that from. The electronics help the derailleur shift as soon as there is a shift ramp, so it's a perfect shift every time. The mechanical drivetrain will work, but it won't work as well.
7/28/2023 2:15pm
I don't know where you're getting that from. The electronics help the derailleur shift as soon as there is a shift ramp, so it's a perfect...
You probably have more info than me, but to me it just seems like a specific delay per gear, I haven't seen any evidence of a position or resistance sensor. So the first shift gets fired off at any point on the cassette. Your fingers ability to sense the amount of effort required to move into the next gear could perform the same task. Or perhaps some kind of clutch in the shifter that only allows X pressure to be applied to the shifter cable.
7/28/2023 2:33pm
I'm getting it from reading people's inexperienced opinions and you're also making my point. It DOES NOT have to be electronic to shift "well" and if you read those who have experience it's not "perfect shifting every time." That would be the SRAM marketing dept. Durability on the other hand does seem to set it apart which is certainly not electronic dependent.
7/28/2023 3:35pm
You probably have more info than me, but to me it just seems like a specific delay per gear, I haven't seen any evidence of a...
That requires knowledge and experience, something most people don't have when it comes to shifting gears...
7/28/2023 3:58pm Edited Date/Time 7/28/2023 4:03pm
Hey Jesse, I know you're a trained engineer and you're probably smarter than me and work for SRAM and I'm just some guy, but I've read that the SRAM Transmission does not use electronics to sense the shift gates in the cassette in order to sync the derailleur movements to match in time. Instead, the shift movement of the derailleur cage is instantaneous when you hit the button, and the delay you observe is from the chain waiting for a shift gate in the cassette to travel through the gate and change gears. The pronounced shift gates in the cassette (and perhaps the proprietary T-type chain shape) are what allow seamless shifting under load, not the derailleur per se. So it doesn't need to be electronic to shift real good like.
7/28/2023 4:52pm
Hey Jesse, I know you're a trained engineer and you're probably smarter than me and work for SRAM and I'm just some guy, but I've read...
Thanks for the compliments but we all know you're not just 'some guy', and I'm just a bike nerd like the rest. What you are saying makes sense.
All I really have is a lot of ride time on the new Transmission, as well as the older AXS on some of my other bikes. All I said was the electronics help when the derailleur will shift. It doesn't 'sense' this, it just has a map of all the of ramps in the cassette. So it knows the gear you are in, which way you have shifted, and roughly how long the delay will be until the chain hits the shift ramp, so it puts the derailleur into position to catch the ramp, and then finishes the shift when the ramp is met. Like the guys said previously, we have been able to do this with our thumbs on downshifts, slightly pressing the lever and letting the derailleur catch the ramp before finishing the click. Transmission does that by itself, and the best part about that is I will come into a climb I didn't expect and be able to press a button and be turning over into an easier gear while only thinking about cranking up the steep pitch. I wasn't bold enough before to shift while under significant load like that for fear of breaking my chain, that fear was probably unfounded as Shimano does make a great drivetrain, but now I don't have that worry. I do like the idea about the clutch in the derailleur where it will only shift under certain pressure, that could be the solution for mechanical.
But I haven't been able to do that on upshifts. On transmission I personally feel this is when I need to grab a handful of gears trying to get back up to speed. If I have to go click-click-click, it won't mangle 3 gear shifts at once, instead it's a steady, consistent shift for 3 gears.
7/28/2023 7:09pm
Thanks for the compliments but we all know you're not just 'some guy', and I'm just a bike nerd like the rest. What you are saying...
So good to hear from the horses mouth! I've been curious about that myself. The one thing I can't help but reckon is that SRAM should integrate Transmission with a cadence sensor such as that of the Flight Attendant system. Hence the timing could be even more precise, allowing the transmission to speed up when the cadence is very high, instead of predicting the required time between shifts based on an average cadence (I'm making assumptions here please correct me if I'm wrong).
7/28/2023 11:16pm
The main point here is definitely to do single shifts only. With normal mechanical shifters you were able to shift up to 5 gears at one push. This would be way to fast to synchronise the chain and the cassette and you would end up with the chain being mismatched with the narrow-wide teeth. Shimano introduced mechanical linkglide xt two years ago, it does almost the same thing as transmission, it uses a stronger narrow-wide teeth profil and more pronounced shift ramps to make sure each shift is perfectly synchronised. The matching mechanical shifter is an "E-Bike" shifter, that only allows for single shifts and therefore slows down the shift speed significantly. So from my point of view there is no real reason why transmission could not be mechanical, but to shift properly, it would need an single push/single shift shifter, like the ones that are common on ebikes for years. I think this would a pretty hard sell for sram and they can easily hide that by going electronic. On the wireless shifter they can "cue" the shifts and change gears slowly without the user noticing it.
TimBud
7/28/2023 11:24pm
Sram already have mechanical single click shifters on ebikes…
Curly
PNW, OR US
7/29/2023 1:10pm
IMG 1595
 Someone is testing rims up at whistler…
Aksel_Lfft
Plaisance-du-Touch FR
7/29/2023 3:50pm
IMG 1595
Looks like Pinkbike racing team to me (Conti tires+ Manitou), so testing proto reserve wheels ? I'm wondering what would be the updates on those.
Curly
PNW, OR US
7/29/2023 4:54pm
What animal is that on the proto badge? Goat?
Looked like a goat or a sheep…
TannerVal
Hampton, NH US
7/29/2023 4:58pm
Goat = Minnaar = Santa Cruz Syndicate spec DH wheels = Prototype Reserves
id_shred
Couer D’Alene , ID US
7/29/2023 7:16pm Edited Date/Time 7/29/2023 7:18pm
IMG 6229 0
  I saw this yellow GT with the same sticker on the bar. I think it looked more like an angry sheep than a goat. The stem had some writing on it too.
