Buttons
Provo, UT US
1/31/2023 11:23am Edited Date/Time 1/31/2023 11:25am
Sram didn't make those cranks. Autodesk made them. The project had nothing to do with SRAM aside from sram uses the software.
SRAM did indeed make these cranks. If they didn't provide the desired parameters for the end product to meed into the generative design engine, they would...
SRAM did indeed make these cranks. If they didn't provide the desired parameters for the end product to meed into the generative design engine, they would not get that exact result.
sluette wrote:
Completely right! There are some new features in the latest AutoCAD Release, one of them is the "create cranks" feature. That's it, hit the "create cranks"...
Completely right! There are some new features in the latest AutoCAD Release, one of them is the "create cranks" feature. That's it, hit the "create cranks" button and you're done! Awesome! Unbelievable! Woohoo
From what I heard someone high up at Sram is heavily invested in autodesk, that's how their little prototype partnership came to be. (By heavily invested I mean a stock owning board member)
owl-x
Seattle, WA US
1047th
1/31/2023 11:37am
those HR Giger pro model cranks trigger some trypophobia in me. no bueno, keep those away
Losifer
Sandia Park, NM US
1774th
1/31/2023 1:20pm
Holes! Holes everywhere!!!
1/31/2023 1:41pm
parnifel wrote:
The new SRAM stuff does pretty rad, but is there any advantage of the whole derailleur being directly mounted to the frame via the direct mount...
The new SRAM stuff does pretty rad, but is there any advantage of the whole derailleur being directly mounted to the frame via the direct mount option? More ground clearance? Smoother shifting? Isn't that what the hangers were for..if you strike a rock and just the hanger is bent, you can sometimes salvage the derailleur - and in this case being mounted directly, just replace the whole thing? won't come cheap...
The theory is that the AXS motor puts so much force on the shifting, that the speed limitation is to avoid flexing a single shear mount when pushing the chain over. By going to a double shear mount and increasing lateral stiffness, the shifting speed can be increased.
I've looked at that new SRAM mount from several angles, and it looks pretty clever. It is much thinner than it looks. The ability to bend (or break) the slender outer part, coupled with the "breakaway" of the motor, and the narrower footprint overall, seems to be how it is intended to not just ruin everything.
Jacob_Richard
Colorado Springs, CO US
2572nd
1/31/2023 3:13pm Edited Date/Time 1/31/2023 3:24pm
Dave_Camp wrote:
sitting here using creo
Once you finish your installation of Auto Desk you can find the make fork button here.
I'm sorry you've been manually designing this whole time Dave
newfork 3
1/31/2023 3:56pm
lmao, right next to the "patent this existing design, but make it  slightly different" button on the Dave Weagle version.
DIGRIDEPARTY
Burlington, VT US
1/31/2023 5:45pm
Wrong. it was a 100% Autodesk project with minor assistance from SRAM. I know the person from Autodesk who did it. SRAM doesn't have 3D Printers or the software. It was a PR piece for the generative software using a client.
2320th
1/31/2023 11:22pm
My real question about any new sram cranks is if they made it so you can remove a dub crank bolt from a factory installation without two people hanging off snipe's on the crank and the 8mm on a ratchet. Terrible galling on dub cranks ever since they released them, I've watched someone sprain a wrist trying to get a dub crank bolt out.
JerseyMojo
JE
861st
1/31/2023 11:59pm
155E690B-5B55-4763-9B5F-8FAC3437C678
New TLD helmet on Jesse’s feed. Called Flowline, released (or announced) on Friday (3rd). Surprised it’s not an over the ears option like the DropFrame.
loris_74
1460th
2/1/2023 12:11am
Capture d%E2%80%99%C3%A9cran 2023-02-01 090946.png?VersionId=mYkZpWiFH3vGg758N
TLD Flowline already in stock on some websites ...
2/1/2023 12:16am
Wow, that is… uninspired.
2/1/2023 12:27am
Looks like a kids helmet...
Regarding Autodesk and crank designs, it's not like topology optimisation is a rare thing in the world of finite element software suites... Speaking with my coworker here he mentioned it's been included in FEA suites for the last 15 years, but has seen limited use because of manufacturing limitations. 3D printing removed that. The coworker also mentioned that apparently Abaqus and Ansys recently added the option to take the manufacturing method into account, so the topology optimisation can create a part within negative angles, enabling injection moulding for example.
@metadave I get around the bolt issue by using a meter+ long steel pipe, rest it on my hand on the handlebar and crank on the pedal with my foot. It's been a challenge once or twice, but at least I can do it alone...
2/1/2023 12:57am
it‘s their new budget friendlier helmet compared to the A3.
peter.p.lloyd
Edinburgh GB
4247th
2/1/2023 2:01am
vweb wrote:
Josh Lewis to... Scor (with Deity and Marzocchi) https://www.instagram.com/p/CoHUb-3qjuN/?utm_source=ig_web_copy_link I understand Marzo and Deity want him, jibby things and all is part of their DNA. But...
I understand Marzo and Deity want him, jibby things and all is part of their DNA. But Scor... Anyway.
Makes perfect sense to me. Their philosophy is short CS, playing around bikes.
sluette
2/1/2023 2:12am Edited Date/Time 2/1/2023 2:14am
referenced to Vali Hölls Insta Story, the release date is still ahead :-)
https://www.instagram.com/stories/valihoell/3028123555710666225/
SharedScreenshot
JerseyMojo
JE
861st
2/1/2023 6:53am
Kinda surprising they're going that way with a budget helmet - I just picked up a '23 colour A3 from Leisure Lakes in the UK for £95..
2/1/2023 7:16am
My real question about any new sram cranks is if they made it so you can remove a dub crank bolt from a factory installation without...
Defo, I had to use a 24” breaker bar 🤦🏻
awitt
Santa Barbara, CA US
624th
2/1/2023 8:32am
5452F2E6-1C27-42F2-8BF1-47E63F27DA1B
I’ll just leave this here…
2/1/2023 9:45am
I think the interesting part is the fork. Everything else seems standard fare. Current Codes, current X01 shifter, Super Deluxe coil, nothing out of the ordinary.
2/1/2023 10:30pm Edited Date/Time 2/1/2023 10:30pm
Definitely not Michelin, not Pirelli either.   Conti sponsored GT before so I wouldn't be surprised if they're back.  The Kryptotals (and Argotals, too) also seem to...
Conti sponsored GT before so I wouldn't be surprised if they're back.  The Kryptotals (and Argotals, too) also seem to be the best tires to be on right now.
The recently published UCI lists confirm Continental is definitely sponsoring the GT Factory Team, among others.
Kango
Calgary, AB CA
2/1/2023 10:39pm
krabo83 wrote:
  the release of the transition relay shows us that the new sram groups are called X0 and XX, the 1 in the name is gone...
Bildschirmfoto 2023-01-31 um 19.11.46.png?VersionId=PQjH
the release of the transition relay shows us that the new sram groups are called X0 and XX, the 1 in the name is gone. guess an official release is imminent.
Seems about right. The leaked photos of the new AXS drivetrain shows just XX on the derailleur.
