1/30/2023 1:08pm
Here I go derailing the thread again... Even went to DMs to avoid that.
Race face also has one, but at 30T there needs to be an offset to fit the chain past the spider tabs. That offset could create some sideloading in the spider, possibly causing erroneous measurements of power (as the power meter measures flex of the system).
371st
1/30/2023 1:13pm
Hey Primoz- you could just stand up more when you pedal and push a harder gear...
MTBrent
Concord, NH US
1/30/2023 1:29pm
TimBud wrote:
Renthal's 1XR comes in a 104/30t option
Fyi, for the 104BCD holdouts out there who want to get into super granny gear mode:
https://usamadeco.com/products/104-26t-st-pro-integrated-guard-mountain-chainring-new?_pos=2&_sid=100024076&_ss=r
26T and bashguard on 104BCD.
I ran this on Saint cranks with 12sp SLX.  26/51 is ludicrous gearing, but damn you could climb anything!
lloyd506
154th
1/30/2023 2:00pm
MTBrent wrote:
Fyi, for the 104BCD holdouts out there who want to get into super granny gear mode: https://usamadeco.com/products/104-26t-st-pro-integrated-guard-mountain-chainring-new?_pos=2&_sid=100024076&_ss=r 26T and bashguard on 104BCD. I ran this on...
With that gearing at a snails pace.
1/30/2023 4:05pm
sram-crank
Another spy shot of the new SRAM drivetrain from the Queenstown Bike Fest. The cranks and bash guard look pretty sweet.
TannerVal
Hampton, NH US
1/30/2023 6:05pm
sram-crank
New 4Dev cranks look meh
1/30/2023 7:24pm
PisgahGnar wrote:
 Neko on a proto Santa Cruz now?
924E1637-7C47-4C39-9D9E-489BAEB490D1
He’s posted other photos of that Nomad last year riding enduro. Also looks like he’s been riding the cannondale Jykle.
TannerVal
Hampton, NH US
1/30/2023 7:28pm
Makes sense. I’m sure any company focusing on performance would love to have frame feedback from the guy who’s been developing his own World Cup bike for the past two years.
Kango
Calgary, AB CA
1/30/2023 9:10pm
sram-crank
I like how little material there is after the crank hole for the spindle.
parnifel
1/30/2023 9:49pm
sram-crank
The new SRAM stuff does pretty rad, but is there any advantage of the whole derailleur being directly mounted to the frame via the direct mount option? More ground clearance? Smoother shifting? Isn't that what the hangers were for..if you strike a rock and just the hanger is bent, you can sometimes salvage the derailleur - and in this case being mounted directly, just replace the whole thing? won't come cheap...
sluette
1/30/2023 10:23pm
sram-crank
parnifel wrote:
The new SRAM stuff does pretty rad, but is there any advantage of the whole derailleur being directly mounted to the frame via the direct mount...
One advantage is certainly that the new rear derailleurs are much flatter and do not protrude so far.
The other is that SRAM uses its power more and its UDH dropout could become standard.
2668326-178rstqx1e5v-sram prototyp les gets 3616-large
parnifel
1/30/2023 10:50pm
sram-crank
sluette wrote:
One advantage is certainly that the new rear derailleurs are much flatter and do not protrude so far. The other is that SRAM uses its power...
Great picture of that derailleur and I see from that angle that its flatter and doesn't protrude that much...still - seems like a really stable construction but I if a rocks strikes that, there could be more frame damage than expected..only time will tell I guess.
1/30/2023 10:59pm
The UDH hanger part is replaceable. If it's plastic, it will not be as bendy as a thin metal hanger, thus won't bend as much. It will break, but hopefully the parts will be cheap to replace and will be intentionally a weak point.
Bending a hanger on a ride means you'll be able to ride out. Breaking the mount is a problem. On the other hand if I'm not grossly misunderstading how things might work, it would mean less weird shifting issues caused by bent hangers (the amount of drivetrains I've made to work again using just a hanger straightener is insane) and more user satisfaction. Unless the mounts implode on a weekly basis.
sluette
1/30/2023 11:22pm
parnifel wrote:
Great picture of that derailleur and I see from that angle that its flatter and doesn't protrude that much...still - seems like a really stable construction...
Rock strikes should be managed by the overload clutch...
ArchiRaph
582nd
1/31/2023 12:05am Edited Date/Time 1/31/2023 12:07am
sram-crank
Do you think those cranks could be made of titanium or more conventional aluminum?
nicompr
1/31/2023 3:03am
sram-crank
Coming from Sram, I say it'll be alu or maybe carbon
ArchiRaph
582nd
1/31/2023 7:09am
sram-crank
I you look at front ant back of those new crank, it seems directly inspired by the generative design prototypes from last year.
remote image
XO 2023
remote image
1/31/2023 7:22am Edited Date/Time 1/31/2023 7:24am
bold cycles just released their new unplugged, wireless shifting only because there are no ports on the whole frame, brakes go through the headset of course… Sick
CB8F4B23-DD5D-4939-81AF-CF24DE1457FE.png?VersionId=fGBjgkH7
sluette
1/31/2023 7:28am
Nice ride, but cable through headset is a no go! Also the fat stem looks really ugly.
1/31/2023 7:32am
bigger problem is wireless shifting only IMO, what about those who want to ride shimano drivetrains?
DIGRIDEPARTY
Burlington, VT US
1/31/2023 8:09am
remote image
XO 2023
remote image
Sram didn't make those cranks. Autodesk made them. The project had nothing to do with SRAM aside from sram uses the software.
1/31/2023 8:37am
SRAM did indeed make these cranks. If they didn't provide the desired parameters for the end product to meed into the generative design engine, they would not get that exact result.
kcy4130
MT US
1/31/2023 8:42am
That's like saying a set of allen keys assembled my bike, instead of saying I assembled my bike.
sluette
1/31/2023 8:51am
SRAM did indeed make these cranks. If they didn't provide the desired parameters for the end product to meed into the generative design engine, they would...
Completely right! There are some new features in the latest AutoCAD Release, one of them is the "create cranks" feature. That's it, hit the "create cranks" button and you're done! Awesome! Unbelievable! Woohoo
1/31/2023 10:16am
Bildschirmfoto 2023-01-31 um 19.11.46.png?VersionId=PQjH
the release of the transition relay shows us that the new sram groups are called X0 and XX, the 1 in the name is gone. guess an official release is imminent.
