8/13/2021 6:27am
GUILLO wrote:
[img]https://p.vitalmtb.com/photos/forums/2021/08/12/11293/s1200_Captura_de_Pantalla_2021_08_13_a_la_s_00.55.32.jpg[/img]
At least huh... 5 year since its release?
watchcwgo
NJ US
8/13/2021 6:42am
Sram frame fit specifications document has the new rotors listed, HS2 is the name, they are thicker now, 2mm to start.
_Lan
AO
8/13/2021 7:00am
the force uses a 230mmx65mm shock which is the longest you can get, so must be a standard shock, probably impossible to overstroke it after some...
the force uses a 230mmx65mm shock which is the longest you can get, so must be a standard shock, probably impossible to overstroke it after some research. Doesn't look to be a lot of clearance in the front triangle either
Nope. There are larger shocks available for downhill and superenduro (like the Pole Stamina 180): 250x75
I think melonhead is saying the longest stroke you can get for a 230mm shock is 65mm.
a trunion 225x75 shock is shorter than 230mm so it's possible to use that for DH application, might not even need to change the rocker.
8/13/2021 7:46am
_Lan wrote:
I think melonhead is saying the longest stroke you can get for a 230mm shock is 65mm. a trunion 225x75 shock is shorter than 230mm so...
Already thought of that, none of the pics of the bike the GT riders are racing on have had a trunnion. Also looked to see the clearance in the rocker link to see if a trunnion would fit but the rocker has a 50mm clear width and trunnions are 54mm wide. Could be a custom link or maybe they’re just rocking it as a 160 like the bike check said.
8/13/2021 9:01am Edited Date/Time 8/13/2021 9:06am
Uhm, you guys are forgeting about the non-metric 230x70 size… There’s a guy in the EMTB forums that put such a size on his 2020 Kenevo and made it a 200mm-travel emtb-beast. So things are possible! Wink
mixmastamikal
Salt Lake City, UT US
2979th
8/14/2021 12:01pm
Uhm, you guys are forgeting about the non-metric 230x70 size… There’s a guy in the EMTB forums that put such a size on his 2020 Kenevo...
Do you have a link to that? I don't believe that is physically possible with any of the shocks I have seen on the market. Also if it was done I would be pretty concerned about the bushing overlap (or lack thereof), especially considering that it is on a yoke link specialized that that will side load the F out of shocks.
Jakub_G
SK
8/15/2021 3:32am
Do you have a link to that? I don't believe that is physically possible with any of the shocks I have seen on the market. Also...
You remember the good old 222x70mm shocks that worked absolutely fine, right? Now, how and why adding 8mm to E2E would make it works less fine? Yes, I don´t see the reason either.
8/15/2021 5:26am
Which shock can be lengthened from 222x70 to 230 x 78 mm? Which shock platform has that much spare space in it?
8/15/2021 6:22am
noeserdalt wrote:
Yeti Ebike [img]https://p.vitalmtb.com/photos/forums/2021/08/14/11302/s1200_233424047_10225746651311460_3261860654978109541_n.jpg[/img]
Yeti Ebike
first time i‘m kinda excitect for an ebike because i wanna know details about that new suspension design by yeti Smile
Jakub_G
SK
8/15/2021 6:57am
Primoz, I like you so I won´t give you sarcastic answer, but you need to have a look at what I was replying to man.
8/15/2021 7:31am
Well that was the most obvious option to go form a 222x70 shock to a 230 mm ETE shock. That or a custom eyelet part, moving the hole by 8 mm.
I checked the DHX2 and Float X2 and none are available in a similar ETE size with maybe more stroke, that you could then short-stroke (as you do metric shocks). Super Deluxes obviously won't be, as they are metric and thus much less custom than old imperial shocks were.
Am I missing something?
66th
8/15/2021 7:34am Edited Date/Time 8/15/2021 7:37am
is there anything out there about why reece wilson had his top tube covered in what looked like black tape? only saw it on race run...front half of top tube.
8/15/2021 8:07am Edited Date/Time 8/15/2021 8:15am
@sspomer paint protection? I've seen bikes being rubbed there from the knee pads, seeing it's a special paint scheme, might be a bit of protection goping on.
In other news, an absolute legend of a person shared this with me:
Do we have any info on the rotors?
TimBud
875th
8/15/2021 8:08am
another pic. is it a pad? [img]https://p.vitalmtb.com/photos/forums/2021/08/15/11306/s1200_Screen_Shot_2021_08_15_at_8.39.52_AM.jpg[/img]
Did he have a crash in practice at some point? Maybe it got a bit of a crack and they've done a sneaky repair with some carbon tape.
8/15/2021 8:25am
It's aluminium, so it would be a dent, not a crack.
TimBud
875th
8/15/2021 8:33am
ha, yes yes it is. Not carbon repair tape then
Jakub_G
SK
8/15/2021 8:42am
Well that was the most obvious option to go form a 222x70 shock to a 230 mm ETE shock. That or a custom eyelet part, moving...
I guess, 230x70 was unusual imperial size, you can still buy some shocks in that size so I don't think it would be too much of a problem for fox to make custom dhx2 in that size.and that brake rotor is prototype galfer rotor, you can see close up pic on galfer insta but it's quite a long way down.
2320th
8/15/2021 8:43am
@sspomer paint protection? I've seen bikes being rubbed there from the knee pads, seeing it's a special paint scheme, might be a bit of protection goping...
Are those the new Galfers?
jazza_wil
whistler, BC CA
2710th
8/15/2021 9:00am
sharpy212
1127th
8/15/2021 9:15am
is there anything out there about why reece wilson had his top tube covered in what looked like black tape? only saw it on race run...front...
Might be something to take the glare off his eyes, that frame sure is shiny and he did say he was struggling with the light in certain parts of the track. don’t know for sure, it’s just a thought.
8/15/2021 9:20am
Too much Bling Bling with the sun ;-)
66th
8/15/2021 9:45am
jazza_wil wrote:
8/15/2021 11:12am
Yeah the black tape is probably to avoid sun glare, there's the same on some aircrafts and dozers or other heavy machinery.
8/15/2021 12:08pm
I'm going through the Les Gets pit bits (because Galfer rotors...), did anybody notice the difference in the linkages between the factory team and Angel's bike?
2320th
8/15/2021 12:39pm
I'm going through the Les Gets pit bits (because Galfer rotors...), did anybody notice the difference in the linkages between the factory team and Angel's bike...
That's some Balfa level home depot hardware on that link 😂. One step above carriage bolts.
But really, absolutely love to see this bike evolve over the years in such a non year by year way. Commmencal just do it when it's an advantage to racing and not because "it's time for the new one". The current surpreme and this proto both mixing it up at the top proves how much effort they put into their teams and bikes. Also always awesome to see Max waiting at the bottom for his riders to come down at almost every race.
I've heard murmurs of a high pivot Meta AM proto kicking around as well.
