haen
8/11/2021 10:16am
EugenM wrote:
someone uploaded the wrong pictures for the force 😁😁🙊 [img]https://p.vitalmtb.com/photos/forums/2021/08/11/11280/s1200_Collage_20210811_164804.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2021/08/11/11281/s1200_Screenshot_20210811_165213.jpg[/img]
And GT didn't bothered doing bike shots with the proper specs. The Elite version has been shot with Shim package but will be sold with rubbish...
And GT didn't bothered doing bike shots with the proper specs. The Elite version has been shot with Shim package but will be sold with rubbish ... sorry I mean Sram package.
Supply chain issues could have caused a shift in spec after those pics were taken.
8/11/2021 10:48am
BidouHD wrote:
Giga-Watt on katie winton last post ? [img]https://p.vitalmtb.com/photos/forums/2021/08/11/11282/s1200_Screenshot_20210811_160338_Instagram.jpg[/img]
Looks more like a Santa cruz to me
8/11/2021 4:29pm
Yeah that's an SC. Nukeproof have said there will be no GigaWatt
8/11/2021 11:20pm
that‘s not katie winton, just the videographer.
kuzlich
Lisichansk UA
8/11/2021 11:46pm
Yeti eMTB from pink-user. It looks like the editors are already know and have tested the bike.
8/11/2021 11:49pm
No shit ?! I though brands like Moustache shut down their factory for the craic ...
Whatever the reason, like I said they didn't bother retaking the pictures with the proper specs. Maybe one day they will shoot the product page/catalog picture with the wrong paint scheme and you will be ok with that too, you know shortage of paint or something ...
8/11/2021 11:51pm
That is very much unlike the patents. And very much like a 6 bar linkage.
8/11/2021 11:55pm
The Yeti? It has an Infinity logo on the chainstay, so I guess there is some kind of linear linkage there with some rearward axle path in the beginning of the travel.
8/12/2021 12:02am
Possibly a rail just like on non electric bikes. But still, the black peice connecting the Chainstay and the rocker screams a six bar linkage.
Die you see the plethora of the patents they have covering a linkage variant of mounting the main pivot that is currently mounted to the rail sled?
8/12/2021 12:20am
Just opened the picture at full res, it is indeed a 6 bar. Two short links connected by the vertical link and a separate Chainstay and seatstay. Very much like the Supreme proto.
8/12/2021 5:24am
I wonder wether more companies will start testing this design. It looks like a great way to make an horst bike have an actual rearward axle path.
SnusDog
Santa Fe, NM US
203rd
8/12/2021 12:16pm Edited Date/Time 8/12/2021 12:22pm
Kenevo SL Comp Carbon price and release date listed on a Swiss site.
29th of August 21 - 7600 CHF which is $8300
(For anyone waiting for a slightly less absurdly priced Kenevo SL)
8/12/2021 1:28pm
Tommy G riding a new bike. Updated Torque that can run dual-crown fork or brand new canyon freeride bike line up???
8/12/2021 1:53pm
I wonder wether more companies will start testing this design. It looks like a great way to make an horst bike have an actual rearward axle...
Regardless of the number of the links, a rearward axle path still requires an idler. Or has tons of pedal kickback.
What I'm interested in is if their normal bikes will also go 6-bar or if they will stick to rails? A 6-bar setup would enable an aluminium frame (as if Yeti would do aluminium :D ).
8/12/2021 9:25pm
are they long stroking those things? 160mm in the back as capable as these new enduro bikes may be is never the same as 200mm of good old travel! The current Fury is a sick rig too.
taifi
RO
8/12/2021 9:54pm
Maes appears to be on the Force for Maribor: [img]https://p.vitalmtb.com/photos/users/2/photos/146458/s1200_Maribor21_52i7727.JPG[/img]
Seems like a sanction 170-190mm
8/12/2021 10:57pm
So many pits Pics, great work!! This Trek Bikes, commencal with nur linkage, so many good stuff 😍
8/12/2021 11:06pm
I think they must be overstroking, or running a different linkagez similar to what Norco are doing with the range. I think we will see a lot more of this, where enduro and DH bikes use the same frame but different length shocks etc, the geometry is pretty similar, and it cuts the development costs on the DH bike.
Or will there be a sanction that is just the force overstroked?
8/12/2021 11:43pm
Just listening to the Marginal Gains podcast, where it was mentioned that Silca may be working on a high end shock pump. That is really something I would look at.
grambo
8/13/2021 12:10am
I think they must be overstroking, or running a different linkagez similar to what Norco are doing with the range. I think we will see a...
PB bike check claims 190mm Fox 40 and 160mm rear travel so not long stroked and stock Force linkage...
_Lan
AO
8/13/2021 4:17am
I actually checked before that PB bike check went live. Looks like the stock linkage and shock. 162mm in my rough drawing
8/13/2021 4:42am
the force uses a 230mmx65mm shock which is the longest you can get, so must be a standard shock, probably impossible to overstroke it after some research. Doesn't look to be a lot of clearance in the front triangle either
8/13/2021 5:13am
the force uses a 230mmx65mm shock which is the longest you can get, so must be a standard shock, probably impossible to overstroke it after some...
Nope. There are larger shocks available for downhill and superenduro (like the Pole Stamina 180): 250x75
