2024 Red Bull Hardline
veefour
Cinderford GB
268th
5/29/2024 1:55am
LePigPen wrote:
Oh I was literally joking. There's ZERO chance viewers have any say on this. You think Gee would give a flying fuck? From what I heard...
From what I heard the reason it's not happening is a) they couldn't get a decent netting solution up in time and b) sounds like they ran against a timeframe to actually fix the jumps. I'd even be convinced they didn't think the fix was feasible. From what I can see the reason the transition is so tight is just literally physical space. Could mellow the lip, but you still have a G out issue on the run in. So the only solution would be rounding the entire thing out which makes speed checking VERY hard. Which means you absolutely need a net if people are struggling to brake cuz there isnt a flat spot to do so.
Or literally a million other reasons lol. It's just a bad design. Hopefully they get it next year. But all 3 riders who rode it said it was dogshit and the hip was so bad they didn't even attempt it lol. Nothing to do with viewers. Just bad design and short on time.
saskskier wrote:
Ha ha. All fair points. I don't think Gee cares, but the higher ups might.  If they pull it from the race (and can make it...
If they pull it from the race (and can make it work a bit better), it'd be cool to have a session with athletes that want to hit it. After some reflection though, I also think that the weather is such a crapshoot at the best of times, I actually think it'd be ridiculously good luck to get a window where the wind wouldn't shut that thing down.
Curious what they do instead if it's off the table.
If it is out I can't see any other option than to run the old track.
gibbon
5/29/2024 2:21am
They could run it down Lovey Dyfi at the park......Blueline!!!
5/29/2024 3:09am
markb2392
Guildford GB
5/29/2024 3:24am
Apparently the gap is out because they couldn't find a safety net that big in time Laughing
dmanvan
Perth AU
5/29/2024 5:07am
Should have just gone for dakar style rider airbags.. .. the ladies would need airbags and those ornaments that people put on their towhitches.🤷‍♂️🤣🤣
veefour
Cinderford GB
268th
5/29/2024 5:46am Edited Date/Time 5/29/2024 6:14am
Confirmed on Brayton's vlog. It shows they'll be using the new start, then the track rejoins the old one on the landing of the metal kicker (just before the cliff drop where Jess got injured). It's worth watching just to see Ronan's Ratboy impression. Laughing
dknapton
5/29/2024 6:17am
In Braytons video, BK says right after he hit it, he said they have to put a net under it. Apparently Gee didn't want a net, BK and RedBull did, they couldn't get one in time so it's off. But they mention that hopefully next year it'll be in and that they spent a lot of money on it.
veefour
Cinderford GB
268th
5/29/2024 6:20am
dknapton wrote:
In Braytons video, BK says right after he hit it, he said they have to put a net under it. Apparently Gee didn't want a net...
You can see the transition and lip have been rebuilt. Amazing how much more aesthetically pleasing it is with a bit of netting hiding (or at least obscuring) the scaffolding.
5/29/2024 8:05am
sort of too bad, and I do realize I've commented here that the original lip looked like a fatal disaster waiting to happen. after seeing the rebuild of that lip I wonder what BK or someone else's thoughts would be re-guinea-pigging it? Gap looks shorter by a good 10ft and the lip looks way more appropriate for the speed. All the same, cheers to BK as someone who a lot of the riders look up to, for sticking up for what he saw was a mandatory safety measure.
SteveClimber
Perth, WA AU
2276th
5/29/2024 8:14am
There is also a well meaning selfish interest to BK's logic that you can't argue with. Without a net, if someone has a freak accident or mechanical and dies, that's potentially Hardline finished, which means no more income from an event he has won multiple times.
It's wild that Gee didn't want a net.
Anyway, looking forward to the race as always, hopeful no horrendous weather. It's been so wet in France I'd imagine Scotland has also been coping it, hopefully no delays.
610th
5/29/2024 8:28am
veefour wrote:
Confirmed on Brayton's vlog. It shows they'll be using the new start, then the track rejoins the old one on the landing of the metal kicker...
Worth watching just for Ronan's Ratboy impression: https://youtu.be/OVuEK0Uypec?t=219
5/29/2024 8:33am
Matt Jones track walk vid.  Am I hearing it correctly that the call to remove the canyon was made basically during track walk?
veefour
Cinderford GB
268th
5/29/2024 8:50am
Brayton was saying it was out while he was still in his van before arriving on site, so I think they all knew before track walk.
gibbon
5/29/2024 8:56am
There is also a well meaning selfish interest to BK's logic that you can't argue with. Without a net, if someone has a freak accident or...
I'm not too far away and it's cold, dark and raining sideways here in the middle of the afternoon!!
LePigPen
Harbor City, CA US
151st
5/29/2024 10:32am
Again, baffled they eye balled the build, only tested it a week(?) before the event, and then basically "thought of the net only after BK demanded it" or whatever happened. As someone who loves how the builds look at DyFi and generally loves the entire Hardline track design... It's so weird to see them drop the ball. The only thing that makes sense is building on such uneven terrain. One compromise turns into two... Turns into three. And as you build it out more and more without having the big picture dialed you literally just end up with an unrideable disaster.
I think the canyon is cool. When they actually design it right. But the fact that the smaller hip before it was SO bad they couldn't even test it... Kinda tells you things went wrong during the build. To me it's almost the more alarming topic. The riders PREFERRED to jump the 70 ft canyon gap with no net and a lip that looks built for a 35-45 footer... Rather than attempt the small hip. That scares me lol. Not sure if they even got to work on the hip during the canyon gap fiasco.
LookinForIt
280th
5/29/2024 3:05pm
Now, I know it doesn't align with the macho-hype-adrenaline content that RedBull puts out, but can we get crazy skinnies in Hardline?
That hip over the creek surely doesn't work, but what if it was a sweet skinny?
I know it's not the UK's style, and sure my BC-ism is showing through, but I think it would look so cool, and really test the rider's abilities to control speed at race pace (which is more or less the point of Hardline. Jumps test your ability to gauge speed when the trail doesn't have a "trail speed" because it's a race course).
Maybe I need to start a Hardline 2025 thread Silly
Nico_Hrndz
561st
5/30/2024 2:05am
Now, I know it doesn't align with the macho-hype-adrenaline content that RedBull puts out, but can we get crazy skinnies in Hardline? That hip over the...
Skinnies sure would match the original RB mtb content (2003 RedBull Ride Australia anyone?).
Dunno how I feel about a skinny THAT long over the creek -pretty sure that most riders would prefer a long (secured) jump versus a skinny at a race pace. But that would be interesting to see in a lower speed section.
bulletbass man
Collegeville, PA US
169th
5/30/2024 10:08am
LePigPen wrote:
Again, baffled they eye balled the build, only tested it a week(?) before the event, and then basically "thought of the net only after BK demanded...
Well there ain’t a lot to gain from testing the small hip.  But based on how many times I’ve seen the canyon gap on fb/insta/etc there was a lot to gain from hitting the canyon if you cared about social media followers.
that photo of jim flying thru the air will be iconic.  Reminds me of Matt mcduff’s loop of doom photo.
I think Hannah also clicked off the road gap.
the biggest hurdle for the girls will be the 90s.  That’s a lot of speed to carry for a lightweight rider.  A large case pad may make it more feasible.  Hoping someone gets it done.
tahnee for lit kit!
610th
5/30/2024 12:29pm
Well there ain’t a lot to gain from testing the small hip.  But based on how many times I’ve seen the canyon gap on fb/insta/etc there...
tahnee for lit kit!
Isn't Jackson in the same ballpark weight-wise as a lot of the women?
And agree on Tahnee's kit, it's so rad!
StudBeefpile
Almost Canada™, WA US
863rd
5/30/2024 1:27pm
tahnee for lit kit!
Yeah that is a solid point.  I would say that lighter riders have to work harder to gain maintain speed then us.... more solid riders.  For example im a stout 225 and ride with a friend who is 150.  I notice that all I have to do is pump one thing well and im up to speed on the trail while hes having to do jazzercise on his bike to keep up.
3rd'd on Tahnee's kit.  I will say that this year overall kits are looking great.
iceman2058
IL
146th
5/30/2024 5:02pm
First Hardline full pull with Craig Evans - yeah, just riding the track itself is hard, never mind the massive features...
saskskier
958th
5/31/2024 10:13am
The girls are unlocking the course! Clips from Tahnee and Vaea below:
Don't forget Cami! I think she was the one who unlocked the road gap for the ladies and she hit the on/off before the 90's. Really curious to see if any of them will check those off. I have no doubts they're keen, but not sure if they can get the speed.
610th
5/31/2024 11:22am
saskskier wrote:
Don't forget Cami! I think she was the one who unlocked the road gap for the ladies and she hit the on/off before the 90's. Really...
Tahnee already hit the on/off and the 90s and is calling it good for this year. Would have loved to see her race but fully respect her decision.
610th
5/31/2024 11:50am
Cami is freakin' savage! Unsure
saskskier
958th
5/31/2024 11:57am
Cami is the Brage of women riders. Ha ha
610th
5/31/2024 1:28pm Edited Date/Time 5/31/2024 2:30pm
Jono POV is WILD! Sound on for the screaming...
Another angle:
Post a reply to: 2024 Red Bull Hardline
