Specialized Stumpjumper 15 & GENIE Shock - Impressions, Setup Help, Discussion
Edited Date/Time 1/10/2025 9:23am
I wanted to start a forum for current, future, or potential Stumpjumper 15 owners to compile questions, answers, tips, problems, etc.
Below is overarching information about the bike and our coverage of the bike thus far.
▪️Overall Details
- Carbon models
- Alloy models
- 145mm of rear wheel travel // 150mm fork (160mm compatible)
- S1/S2 - mixed wheel only // S3-S6 - 29-inch (mixed wheel compatible with aftermarket link)
- FOX Float with Specialized patent-pending GENIE shock on most models
- Coil models available (FOX & Öhlins)
- S1 - 210x52.5 shock // S2-S6 - 210x55 shock
- S1/S2 - 180mm PM // S3-S6 - 200mm PM
- 63, 64.5, or 65.5-degree head angle
- Two-position bottom bracket adjustment
- Size-specific chainstay lengths
- SWAT 4.0 downtube storage ( alloy & carbon)
- 30.9mm dropper post // 38.6mm seat post clamp
- 12x148 Boost rear hub spacing
- Alloy frame + GENIE = 1.47 kg (3.24 lbs) heavier than carbon
- Carbon frames = internal routing for brake/dropper
- Alloy frames = internal routing for brake/rear derailleur/dropper
▪️Geometry finder gives you numbers for each size in each geo position.
▪️Specialized suspension calculator, which is a good place to start for setup. 30% sag is recommended in the rear.
▪️FIRST RIDE Review
I was a fan of the bike when it launched. You can read my First Ride article HERE. TLDR—below is how I would compare the SJ15 against the Stumpjumper models it has replaced, along with my 'What's The Bottom Line?' I think it pretty well sums up SJ15 if you don't want to sift through all the marketing hype on the Specialized website to understand what the bike is about.
To close out the different ways the Stumpjumper 15 rode with different GENIE spring curves, here is how I would break down the bike's descending vs. climbing abilities, along with the previous Stumpjumper variants for reference:
- 2021 Stumpjumper: 50% climbing, 50% descending
- 2021 Stumpjumper EVO: 35% climbing, 65% descending
- 2024 Stumpjumper 15: 30-45% climbing, 55-70% descending
If you've been riding the current Stumpjumper, I think you can achieve a similar all-around feel with the Stumpjumper 15; you might just have to push a bit harder to reach a similar average speed. If you really prioritize efficiency and don't want to give up the light, agile, hammer-on-the-pedals vibe, I'd look at the new Epic EVO instead of the new Stumpjumper. It's light, it can still get rowdy, and it's more fun to pedal. If you previously rode the Stumpjumper EVO, or want a more descent-focused trail bike, the new Stumpjumper will surprise you with how hard it can be ridden.
The Stumpjumper 15 picks up right where the previous models left off and continues to move the needle forward when it comes to capability and adaptability. The tweaks and updates are subtle, but they're in all the right places. The geometry is still spot-on, the frame is stiffer, the frame details are refined, and the on-trail performance is as versatile as ever. Planted, snappy, calm, or lively—it's a bike with multiple personalities. Riders should look past the fact that it has only 145mm of travel, and take into consideration the possibilities available with the geometry adjustments and new GENIE shock. With a few simple changes, you can recreate either Stumpjumper of the past, or achieve descending abilities that surpass the outgoing EVO.
▪️Riding Three Years of Stumpjumper 15 and GENIE Shock Development in Two Days
We had the opportunity to run through the development of Genie and SJ15. This video dives into why Specialized created the shock, how it coincided with the development of the SJ15, how different Genie setups feel, and how Genie compares to riding the bike with a coil and traditional air shock.
▪️Tuning, Shock Anatomy, and Other Details
Garrett
Sterling, VA, USA
12/21/2024 8:01am
Jason, this was just fantastic. Thank you for this granular look at suspension curves and air springs. Would love more of a "so what" at the end so we can start thinking about how this applies to bikes other than the SJ.
12/22/2024 2:40pm
First time in a long time I shared a bike tech thing with some friends!
12/29/2024 3:34pm
Have you taken the genie shock to your preferred suspension service centre for a full rebuild? How did it go?
b0cephus13
Oceanside, CA, USA
1/9/2025 6:18pm
I have a 2023 SWorks Evo. I bought a Genie to see how things go. May as well post about it here!
TomJones
San Jose, CA, USA
1/10/2025 8:57am
Considering the only difference between the Genie and a "regular" shock is the outer air sleeve, and the rider should be able to pull it apart to swap volume bands themselves, I don't see why anyone would have an issue servicing it.
1/10/2025 9:28am
I just added this video to the main forum post, but I'll drop it here as well so everyone above gets notified. We had Chance from Specialized run through adjusting volume spacers, what parts on the GENIE make it unique/cross over with other FOX shocks, and some general tips and tricks for using the shock. This isn't a service video, but hopefully, it helps answer some questions about what serviceability will look like in the long term.
1/13/2025 8:58am
TomJones wrote:
Considering the only difference between the Genie and a "regular" shock is the outer air sleeve, and the rider should be able to pull it apart...
I suspect people will hate the idea of the Genie shock less and less as they're exposed to them in real life, on friend's bikes and on their bikes. This will be a great contrast to many other proprietary Specialized forks and shocks, which people hated more and more as they were exposed to them in real life, on friend's bikes and on their bikes.
e-riv
Flagstaff, AZ, USA
1/19/2025 6:32am
I just added this video to the main forum post, but I'll drop it here as well so everyone above gets notified. We had Chance from...
Whoa whoa, what is that yellow piece at the top of the upper eyelet, above the end stroke spacers???
1/19/2025 8:38am
Is there changes to the tune or hard parts to deal with the extra stored spring energy?
1/19/2025 8:58am
e-riv
Flagstaff, AZ, USA
1/20/2025 3:43am
rhohman wrote:
Interesting🤔
Blatant
Phoenix, AZ, USA
1/21/2025 6:46pm
Mine went belly-up after a handful of rides. Was quite enjoying the bike and the shock until that. Feels like air in the damper. Local Fox warranty center is a month out on repairs. Two local certified service centers can’t get rebuild kits. Bought a RS SDU as a holdover and it feels absolutely trash on the bike. Currently not super-stoked.
1/22/2025 8:03am
Blatant wrote:
Mine went belly-up after a handful of rides. Was quite enjoying the bike and the shock until that. Feels like air in the damper. Local Fox...
hey- recommend calling Specialized Rider Care and explaining the situation. SBC has a small inventory of complete shocks to help with situtations like this to keep you rolling. if they can't help for whatever reason DM me and I'll help you get it sorted.
1/22/2025 8:07am
there is a floor to the amount of volume we felt was acceptable after the band cuts of the extra volume. the permananet eyelet spacer helps ensure a rider can't tune themselves into a bad spot.
Blatant
Phoenix, AZ, USA
1/22/2025 8:19am
hey- recommend calling Specialized Rider Care and explaining the situation. SBC has a small inventory of complete shocks to help with situtations like this to keep...
Thanks for that. That was my first contact. I was advised they could not help me. I offered to buy a shock and was told they had no inventory.
1/22/2025 8:43am
Blatant wrote:
Thanks for that. That was my first contact. I was advised they could not help me. I offered to buy a shock and was told they...
DM'd
1/22/2025 8:44am
The rebound tune is progressive.  Meaning at slower speeds shaft speeds it produces low damping, and as shaft speeds increase so does the rebound force.  This helps the shock feel lively and responsive where the rebound forces/shaft speeds are not super high, but creates a "high speed catch" where return forces are high and it generate a higher shaft speed.
It is also worth noting that the extra spring force at the end is not exponentially higher than a "normal" spring. The first stage of the spring is softer than your traditional spring, then the extra ramp at the end brings forces back up to only slightly higher force than a traditional spring. This means we are not having to tune around forces that are very far from the norm.
1/22/2025 11:32am
I suspect people will hate the idea of the Genie shock less and less as they're exposed to them in real life, on friend's bikes and...
My concerns around shocks like this are more about exactly what @Blatant described - the average rider is going to struggle to get proper support for these, as has been the trend for every proprietary shock in history. I checked in with the NZ distributor and I also cannot get dedicated parts or tools for these, so will yet again need to explain to people why I can't help with their shock when they were led to believe by specialized that servicing would be straighforward.
1/22/2025 4:29pm
My concerns around shocks like this are more about exactly what @Blatant described - the average rider is going to struggle to get proper support for...
I just reached out to Fox to better understand why you can't purchase the parts and the singular "special" tool to work on the damper. What you know, but maybe not everyone reading this is that most Fox shocks have an unique tool for this type of operation. So yes, unique to our shock, but not unique in the Fox aftercare/service world. I'll let you know what Fox comes back with and if we can't get it sorted quickly, assuming you actually want to work on these shocks, I'll ship you the tool. Just DM me your address. With that part and a standard Float damper service / air spring service kit you can sort 99% of any issues a rider might encounter.
mtbschrader
Rocky River, OH, USA
1/23/2025 12:38pm
I have the new S Works frame (S5 size) and built it up with a mix of new parts including XO transmission, except cranks, and what I brought over from my previous bike. Anyways there's a nasty annoying clunking sound whenever I go down rough terrain. Really miserable at times. And yes, the drivetrain is set up correctly. 2 guys at 2 shops have also been over it and one had a SRAM tech talk him through it. It works great on pavement. Have contacted Specialized and SRAM but no real answers. I coasted some downhill trail sections with no chain and derailleur. Noise went away. No one knows what it is or claims to have heard of this issue except one other guy online with same frame, size, and drivetrain. He and his shop can't figure it out either. Anyone else have this issue?
1/27/2025 3:40am
I have the new S Works frame (S5 size) and built it up with a mix of new parts including XO transmission, except cranks, and what...
Check that the chain isn't contacting the derailleur when it's in the 10t cog. I've noticed on some frames (including a new SJ15) that SRAM's recommended chain length in 2 links too long, and causes contact. Remove a link and check this over, maybe best to try this with a old transmission chain if you have one laying around just incase this isn't the solution for your case
mtbschrader
1/27/2025 12:26pm
honeymoon wrote:
Check that the chain isn't contacting the derailleur when it's in the 10t cog. I've noticed on some frames (including a new SJ15) that SRAM's recommended...
I've wondered about the chain length. I'll check that out although the clunking is in all gears and I did try putting padding on a few spots of the derailleur with no luck.
1/30/2025 10:42am
I just reached out to Fox to better understand why you can't purchase the parts and the singular "special" tool to work on the damper. What...
Joe, did Fox get back to you? The required tool (398-01-114 Tooling: Custom Spanner, 2-Pin, Specialized Genie, Bearing Housing) is not yet being produced by Fox, or so one of their tech reps at the 800 phone number claimed.
1/30/2025 11:24am
Hey Joe thanks for the message - It seems like things have been updated in the last few days and I have a tool on order through Fox now! I'm always keen to service anything I can get decent support for so while getting a tool for myself is nice it sounds like the message is getting though for everyone else now as well
1/30/2025 1:05pm
Hey Joe thanks for the message - It seems like things have been updated in the last few days and I have a tool on order...
Was this through the NZ distributor for Fox that you ordered this tool?
1/30/2025 3:49pm
Yes
2/5/2025 8:55am
rhohman wrote:
Joe, did Fox get back to you? The required tool (398-01-114 Tooling: Custom Spanner, 2-Pin, Specialized Genie, Bearing Housing) is not yet being produced by...
Hey- this tool has been produced and is availble per the latest conversations I've had with Fox.
2/5/2025 9:08am
Anybody have a stumpy 15 without the genie shock for comments?  Most of the big names on specialized (Finn, loic, Chaz) aren’t running the genie as they have different suspension sponsors.
2/5/2025 9:47am
S3 Stumpjumper 15 S-Works owner since October 2024
Genie shock
The past 2 rides I've noticed that my rebound on my Genie shock finds it way towards full fast.  I feel that I've read elsewhere that people have had issues with the rebound settings changing as you use the lockout lever.  Am I the only one? Known issue? Remedy?
This bike has been a challenge to get the suspension setup to my riding preference, but I've landed on the following:
25% sag in Genie, 1 XV spacer, smallest bottom out spacer
Low BB setting (ran high for the first few months)
+1 headset cup to steepen the headtube angle to 64.5 degrees with my 160mm Fox 36
mtbschrader
2/5/2025 10:22am
S3 Stumpjumper 15 S-Works owner since October 2024Genie shockThe past 2 rides I've noticed that my rebound on my Genie shock finds it way towards full...
Genie shock
I had issues with my climb switch wanting to migrate towards closed all by itself, even on bike paths. Your issue could be related? FOX had me send it in and it seems all good now. I'd contact them and ask about it.
Post a reply to: Specialized Stumpjumper 15 & GENIE Shock - Impressions, Setup Help, Discussion
