Luke Afb, AZ
6/3/2020 6:33am
I’ve been wanting to do the tubeless set up this week. Long story short with the old tires..lol..I ended up buying a set of Maxxis tires (Assegai/DHR2) for my DT Swiss M1900 wheels. Wrapped them nicely (one wrap) with gorilla tape and got the bead to seat. Easy enough.
My buddy and I sprayed around with soapy water around the wheel and it bubbles on a few spokes AND the lip where the wheel joins on one wheel.
Are the wheels pretty much shot? Is it worth trying a second wrap of gorilla tape? If I added the sealant, would this seal those leaks? I bought/installed tubes today so I can ride again, but wondering what Vital-brain thinks
Too many people rush the taping itself or don't seat the tape before adding sealant. If any of that sealant gets under the tape, it'll prevent the tape from adhering properly. So take your time and do a really good job with that part.
The leaking at the rim seam is questionable also, what condition is the rim in, has it seen some hard hits?
I can assure you it wasn’t a rushed job wrapping the rim. I scrubbed the entire gap including the inner walls with alcohol and a new toothbrush. The tape had no rolls and was very centered around the perimeter. I’ve never heard of seating the tape tho 🤔 the tape still *looked* good yesterday when I put the tubes in (no harsh edges) but obviously it isn’t. They are DT Swiss M1900 wheels
Interesting. I did put a piece of gorilla tape over one of the leaking spikes and it still leaked. I cut a very small “X” in the hole to get the tip of the valve in, and then pressed it thru snuggly. Here’s the valves. I’m not sure how deep they seated tbh
Used to play a game in the shop when replacing tubeless tape--with the wheel mounted in the truing stand, start walking backwards holding the end of the old tape and see how far you can get. One time I walked all the way across the room because somebody had triple-wrapped their rim with Stan's tape. And guess what--there was sealant underneath.
Tubeless set-up can be frustrating as hell when it doesn't go right. I hope you find a solution soon!
I need to have the bike serviced, I may just see if they’ll do it but I don’t like being defeated!
It really isn't necessary anymore as brands have got tubeless stuff more dialed in.
Did the tire lose air overnight?
I mounted the tires the next day so it was definitely dry. We never put the sealant in since they didn’t hold air tho. Maybe it would’ve helped? But I think the spokes leaked more than they should
Man, I hate all things pneumatic. Tubes, tubeless, whatever. If it involves holding air inside it, I'm cursed and it never works for me. The other day, I tried (again) to tape up my wheels and go tubeless. I almost got it to work but the front tire was leaking slowly - about 15 psi in an hour - so I made the decision to put the tube back in and try again later. Wouldn't you know? I went to ride the next day and the tire was flat, even with a tube. FML.
Rode the hardtail yesterday and my buddy got a big thorn in his tire (which sealed because he’s tubeless). Hopefully they get it figured out because we’re trying to make a trip to Sedona this weekend
They local bike shop was able to get them setup tubeless and I didn’t even think to ask about it! Already got one ride on them and they’re holding air. We are in Sedona this weekend so the timing was great
“The widths of our tape are selected with our rims in mind. Generally, we recommend tape that is 1-2mm wider than the internal width of your rim to account for the drop channel.“
Post a reply to: Tubeless Wheel Issues
