Carnation, WA
10/19/2020 7:55pm
I went to the bike shop today and was kind of amazed and overwhelmed by the choices I had with just Maxxis tires: Exo, Exo plus, Double Down or DH. Then do you want to add Cush Core? I’m curious what other are running, riding style, terrain, what you like or don’t like and your weight.
Currently I’m running Exo casing, tubeless, no inserts, around 28 PSI front and 30 rear. I want more sidewall support but don’t want to push the extra weight up hill unless that’s the best choice. I’m 220lbs been riding for 16 years so I know how to not abuse my bike but also ride pretty fast. I live in Washington and most of what I ride isn’t very rock, but lots of roots. Good mix of tech trails and flow trails. I feel like my tires are rolling on high speed stuff too much and not enough traction in the tech stuff if it’s wet. I have the tread pattern down, just all these casing options now.
I weigh 190 pounds and live in the rocky part of Washington, and I used to be fast once. I run DD front and DH rear, and I wouldn't go back to EXO's if you paid me. I recently started running a rear Cushcore to combat rear tire roll and a front Huck Norris to keep my rims alive. It's clearly too much tire for lighter guys but it's been great for me.
Ridding a full DH tyre on the rear of my ebike has been great so I'm thinking of going to heavier tyres on the regular bike also. Probably supergravity tyres from schwalbe (72 kg, fast enough amateur)
I've been fine on EXO as far as flats/cuts, but am hard on rims and didn't realize how awesome more sidewall support is until I tried Cushcore and experimented with DD casing front tire too.
Front: 2.5 Assegai EXO+.
Rear: 2.4 DHR II EXO+ w/ Nukeproof Ard insert.
Damping is good and no tire roll or dings at 27 rear 23 front!
Rear pressure is 25psi and i'm around 82kg. Riding very rocky terrain and this setup is proving to be bombproof so far.
Huck up front with wtb tough,
Cush (with some material removed) in back with a vee rumba I’m playing with in gravity core. Normally wtb tough though.
Usually 25-27psi up front, and 27-30 in the rear. I’m 155lbs rider weight
Trail bike will be same Huck front, Cush rear, but on Ibis 742s. Will be giving the exo+ a shot, not been on Maxxis in a minute.
Only had them about a week
Fairly aggressive 95 kg rider on all types of trails, rocky North Welsh to steep and rooty in the lakes and Scotland. These have done the trick without dh casings or inserts
I recommend running cushcore front and back or procore with your current tires if you haven't been suffering from cut tires. The inserts provide pinchflat protection, prevent tire roll and allow you to lower your tire pressure by 3-5psi.
R: Maxxis Aggressor DD 2.3 DC - ARD insert
Weight with kit: 185lbs
riding style: Hack
Incidentally, I'm on DHF EXO front Aggressor DD rear. I weigh 145 lbs. Tubeless, no inserts; tire pressures at 15 front and 17 psi rear. Stan's Flow Mk3 front, Flow EX rear.
Trails are loam and rocks, not much roots. I get a flat at most once a year.
Trailbike Exo+ Maxxis casing whatevers (usually DHF) with a Vittoria Air liner up back only
DH bike Need all the help I can get, Cushcore front and back on DH casing. (Assegai)
EX511's both bikes. Solid reliable combo.
Nobl TR38 carbon wheels
2.35 Magic Mary Addix Orange Snakeskin
2.35 Hans Dampf 2 Addix Orange Snakeskin
Cushcore Front and Rear
It's Rad !
DoubleDown usually comes with the faster rolling MaxxTerra rubber and seems a good compromise of grip/ rolling speed/ wear. I'm also having good luck with Schwalbe SuperGravity casing with Apex Soft rubber (orange stripe)... very similar to Maxxis DoubleDown.
What I really want is DH casing for the rear tire with MaxxTerra rubber. MAXXIS MAKE IT HAPPEN PLEASE!!!
I'm definitely back and forth on the no insert DH casing vs. EXO+ with insert option right now. The damped feel of the insert always has me coming back to it though.
(no sarcasm, generally curious as i haven't run cushcore ever)
Post a reply to: Tires and inserts
