i tossed some custom paint on my bike last year, idk if that counts for much, also its about to go to a 1x4 setup
[img]https://lp1.pinkbike.org/photo/4240/pbpic4240292.jpg[/img]
i like it! what frame is that? ahh, the good old sherman dj. i miss that fork.
Here i have used a M6 thread and installed it with Hex-bolts, look better and easier to install. Its a moded Halo Spin Doctor
And here is my Kore stem wich i have cut the clamp in two pieces like a BMX clamp. Not much for weightreduction but the looks is also important
, though the paint is bad.
My 831 is hitting my Mob frame when I spin the bars. It doesn't stop completely, but it is noticeable. I have an internal headset, so my steer tube is already cut too short for an external. I really don't want to have to grind down the corner of the blue anodized compression knob. Has anyone had a similar problem?
My 831 is hitting my Mob frame when I spin the bars. It doesn't stop completely, but it is noticeable. I have an internal headset, so...
spankthewan: one dude on a swedish forum im member on had the same issue but on his Tweet Tweet and he made spacers for the steerercrown to stack the headset but its not a solution i would recomend you. Fabricate your oun set of caps insted of doing something irrational.
[img]http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs570.ash2/149288_1466615026817_1276783598_31058853_7156581_n.jpg[/img]
Just removed the cable guides and rim brake bosses from my old Ellsworth hardtail (run it single speed). Custom paint coming next.
Is that the one you rode in the Jib series? I think I'll have to dig up those videos sometime soon.
Blue MRP G2 SL
And here is my Kore stem wich i have cut the clamp in two pieces like a BMX clamp. Not much for weightreduction but the looks is also important , though the paint is bad.
@bturman...holy crap! 65-70mph on that fork/whees/bike? no thanks!
works amazing
80mm Totem Solo Air on my dirt jump bike:
4spd Dura Ace on a Chris King SS hub with X0 der. and Dura Ace chain.
Compression ring for a Chris King headset
The fork on the STP is comprised of: Reba uppers and Moco, Pike lowers, Argyle spring internals.
X9 der. pulley in MRP G2 - significantly less drag
XT m971 crankset on a 83mm bb Intense M6
really simple but it dropped M6 travel to 8" and my bashgaurd stopped hitting the ground as much
Shortened the stroke of the DHX, 12.9" bb, 65 ha
shortened stroke= the best angles ever!!
nice one!
I like your chain link cable guide, pretty neat
here some of mine; glued on sandpaper for added grip:
made a fixed gear rear hub out of mtb front disc hub:
"shortened" the spokes:
that's just few, i also moded two hardtail bikes into one full suspension among other things
Post a reply to: DIY and Customized Thread
