A new TroyLee helmet is in the works , something with more protection at the back , like a Fox Dropframe . In all the photos that Vali is riding with an open face helmet you can see it .
A new TroyLee helmet is in the works , something with more protection at the back , like a Fox Dropframe . In all the photos...
yes but the reach is not the only thing that affects front center... axle to crown, head angle and stack does so as well...
Which is more or less what I said, just the other way around. The thing is you said you want a shorter reach when you have a longer front centre. That's not possible if you're not making the stack ridiculously high or the headtube angle ridiculously slack. Stack and head tube angle are currently hovering around a certain value and for example lengthening the front centre will mean a longer reach. With an appropriate ETT/cockpit length, your seat tube will get steeper, which is something most people like these days (that's why for a given, reasonable, ETT/cockpit length both front centres and reaches have increased at the same stack and HTA when making seat tubes steeper).
Or, compared from size to size, a larger size will have both a longer reach AND a longer front centre with the same HTA (and a small difference in stack). Making the front centre longer and the reach shorter is just unnatural. The two dimensions are intertwined too much to have opposite changes be logical.
I was told by a reputable source that they ran into production headaches like a few other brands due to covid and every brand trying to...
I was told by a reputable source that they ran into production headaches like a few other brands due to covid and every brand trying to squeeze as much out of all the factory's as they can, same reason Cannondale ended up pushing back their model year. Apparently Norco had a few bikes to put out and has had to delay official release for that reason. I think crankworx whistler was the intended date before it was cancelled.
This is a very good point and I think it will be interesting to see if this possibly translates into an increased amount of quality issues down the road. Rushing things out almost always leads to further problems it seams.
What about the enduro?(beside having issues with the higher axle-to-crown heights of the new 38s); anyone knows when the 2021 year model arrives?
I might be confusing this somehow but a quick search shows that the difference in axle to crown from a 36 to a 38 is 2mm. Not sure how that would mess up the geo
I might be confusing this somehow but a quick search shows that the difference in axle to crown from a 36 to a 38 is 2mm...
Issue is when going from the "old" 36's to 38's. There is a considerable axle to crown increase for the same travel.
2021 forks, A2C between 36 & 38 is only 2 mm.
But say you have a 2020 36, that's 581mm A2C, same travel 38 has you at 593mm. 12mm difference. That's 0.5deg HA. Stack and reach also changes. Could probably sort with lowering the bars a tad.
2021 forks, A2C between...
Basically, if you go from a 170mm 36 grip2 to a 170mm zeb is almost like getting a 180mm 36. 9mm to the zeb, almost 7mm to the 38. That is bound to modify the geo; especially if you want to put 180mm on your enduro. That would, currently mean, 17 to 19mm extra on the front for the enduro with a 170mm 36 on it.
Edit. I would be pissed AF if I would be the PM for the enduro. Two new forks, more travel than ever and they can't use it for s$&t.🙄
Basically, if you go from a 170mm 36 grip2 to a 170mm zeb is almost like getting a 180mm 36. 9mm to the zeb, almost 7mm...
my ebike had a 2019 160mm 36, recently replaced with a 170mm 38. The geo did get quite wonky for sure. 26mm A2C difference between the two. The big one been reach is noticeably shorter. I have bandaided it with running the stem slammed on the headtube.
my ebike had a 2019 160mm 36, recently replaced with a 170mm 38. The geo did get quite wonky for sure. 26mm A2C difference between the...
But the 38 is a lot better than the 36 IMO.
Will be interesting to see if more brands start offering frames with reach adjusts in that category. Since many brands already have a flip chip to slacken and lower bb. It would be pretty feasible to offer a 160/160 am with a 36 and a 170/160 enduro park bike with the same frame. Or perhaps a mullet option for a 27.5 bike.
I agree upforking a bike isn’t all too bad to begin with. I ride an upforked prev gen Hightower and the pros outweigh the cons. I just also run a slammed, longer stem.
Anyone know when the official release for the status is? I know its been reviewed but its still not on the spesh website
I think it's been released just not on the website yet.
Seen one at my local bike shop - which is specialized concept store - and one in the woods even.
Spoke with a local spec dealer yesterday and he said the demand for Statuses is high because its pretty good deal but the stock is almost none across whole Europe, pretty much as any bike these days, he ordered like 15 bikes from first batch and might get two if lucky...
https://www.pinkbike.com/news/photo-epic-the-prodigy-at-home-with-valen…
https://www.vitalmtb.com/product/guide/Bikes,3/Specialized/Stumpjumper-…
