HexonJuan
WI US
11/28/2023 6:23am Edited Date/Time 11/28/2023 6:24am
HexonJuan wrote:
Norco going high pivot on models above Fluid makes a lotta sense from a company standpoint. Product differentiation. Fluid gets the old layout, the latest n...
Norco going high pivot on models above Fluid makes a lotta sense from a company standpoint. Product differentiation. Fluid gets the old layout, the latest n greatest wonder bikes get the high pivot treatment.
I've seen and ridden the new Norcos and these are legit. They are proper good bikes.
Color my interest piqued. I felt the same about a friend's Optic. I think Norco has done a lot of good homework when it comes to fit and function over the last 4 years.
Javigutz
Beverly Hills, CA US
11/28/2023 7:07am
Dec 7th is going to bring some new potions to the witchcraft
I really hoping HIGH expectations
610th
11/28/2023 8:23am Edited Date/Time 11/28/2023 8:26am
jonkranked wrote:
they're watching us.
also, no screenshot?
Only got this; spring rates for 126lb rider.
From memory it's $850 for the shock assembly only, spring and hardware are extra. You can use springs from other manufacturers.
Screenshot 2023-11-28 at 05.18.46.png?VersionId=GVY25KfN0L8Gz.uYnXHVyD
Edit: Here's the slug:
Screenshot 2023-11-28 at 08.25.08.png?VersionId=mrT9mWD1 tdOuhQS6oZBaAHJ4S5
610th
11/28/2023 8:55am
DirtyHal wrote:
I might be blind but I'm not seeing what sizes are offered?
Screenshot 2023-11-28 at 08.55.16.png?VersionId=1uCaS7CpGHOlIKoBFkFqLC1
Suns_PSD
Austin, TX US
11/28/2023 8:56am Edited Date/Time 11/28/2023 8:57am
This fits a really nice spot in the market.
It seems to only have 2 tunes available, A or B based on spring rate. And if you are right on the edge (i.e. 500# spring) you might end up in between instead of in the sweet spot of the tune. Not to mention that it doesn't appear to be frame specific any longer. Of course, I don't have all info only what I see at that link, so who knows.
For the same money, I'd still choose an Avy tuned Bomber CR personally. (I did and have one on order)
Suns_PSD
Austin, TX US
11/28/2023 9:02am
The Push shock just hit PB as well.
Norristown, PA US
747th
11/28/2023 9:42am
komarek wrote:
Suns_PSD wrote:
This fits a really nice spot in the market. It seems to only have 2 tunes available, A or B based on spring rate. And if...
the one thing this has over an avy tuned shock is the user adjustable stroke. 5mm isn't a lot, but its something.
ZAKBROWN!
Salt Lake City, UT US
246th
11/28/2023 10:00am
That's not really unique though is it?  It's just a spacer behind the bottom out bumper unless you're also changing eye-to-eye.  Seems like it would mess with HBO though, I know the EXT should be rebuilt to adjust HBO if you change stroke.
11/28/2023 10:02am
Also HBO.  Usefulness depends on the bike, but in the right use case it's really nice to have.
Suns_PSD
Austin, TX US
11/28/2023 10:03am Edited Date/Time 11/28/2023 10:05am
It's not adjustable however and Avy accomplishes the same thing using custom shaped & density bumpers for your specific application. Well except the Avy solution is better because the bumper has a rebound effect consistent with the amount of damping it provides, unlike hydraulic bottom out.
Norristown, PA US
747th
11/28/2023 10:12am
ZAKBROWN! wrote:
That's not really unique though is it?  It's just a spacer behind the bottom out bumper unless you're also changing eye-to-eye.  Seems like it would mess...
didn't mean to infer that it was unique, but that it's not a feature available on any of the shocks that can be tuned by Avy to the best of my knowledge.
ZAKBROWN!
246th
11/28/2023 10:28am
jonkranked wrote:
didn't mean to infer that it was unique, but that it's not a feature available on any of the shocks that can be tuned by Avy...
Yeah IDK what Push's solution is but newer DHX2's are pretty easy with the 2-piece spacer - https://www.ridefox.com/fox17/help.php?m=bike&id=1100
On the Bomber (like pre-21 DHX2's) you'd just have to clamp the shaft, unscrew the rebound eyelet, insert spacer, and reinstalls eyelet.  User adjustable as long as you have the right tools Wink
ZAKBROWN!
246th
11/28/2023 10:31am
ZAKBROWN! wrote:
Yeah IDK what Push's solution is but newer DHX2's are pretty easy with the 2-piece spacer - https://www.ridefox.com/fox17/help.php?m=bike&id=1100 On the Bomber (like pre-21 DHX2's) you'd just have...
Just looked at the full article, it's pretty much just like the newer DHX2's only on the eyelet end instead of the shock body.  So a bit easier than the Bomber, and no need for shaft clamps.
Norristown, PA US
747th
11/28/2023 10:36am
avy no longer offers the SSD modification for the dh/x2s that have the externally adjustable stroke via the spacer/plate.  the sv8 has a similar adjustment for stroke, but the spacers screw in under the bottom out bumper instead of the main shock body
Jakub_G
SK
11/28/2023 11:10am
Suns_PSD wrote:
It's not adjustable however and Avy accomplishes the same thing using custom shaped & density bumpers for your specific application. Well except the Avy solution is...
Is the rebound statement part your own theory or something you can back up? Because common theory of HBO is pretty clear in that it offers added rebound damping in the same part of the travel where it ads compression damping(it takes force to disengage cone from the cup), which is considered nice bonus when you get that deep into stroke.
11/28/2023 11:15am
I've owned a couple of Avy tuned shocks as well as the current Super Deluxe with HBO.  With HBO you don't need to alter rebound since the HBO only kicks in during compression and doesn't add any spring energy.  HBO feels smoother on large drops when you max out travel - like you're landing on a pillow; however as you point out the HBO on the Push is non-adjustable, so how well it will work on any given bike is unknown.
2320th
11/28/2023 11:43am
360 F 224631753 gvsQykTBpUquwyETSQgFML4AFsNfn8oJ.jpg?VersionId=.KmdlaNAXhRlz4DNBS
11/28/2023 12:26pm
O1D4 wrote:
I'm sure there is a better thread for this 'discussion' but 'e-bikes' already have a name that clearly differentiates them from 'bikes' so there is no...
I'm sure there is a better thread for this 'discussion' but 'e-bikes' already have a name that clearly differentiates them from 'bikes' so there is no need to rename 'bikes' in any way or form.
Silly
veefour wrote:
Exactly. I've never heard anyone refer to a non powered toothbrush as analogue or acoustic.
I've been calling regular bikes "Naturally asperated" for a couple years but it hasn't caught on yet.
The naming convention was determined decades ago.  Motorized pedal bikes were called mopeds, full human powered bicycles have and always will be bicycles.
11/28/2023 12:55pm
Please can we just get on with it?
If you want to discuss the differences in bicycles and motorbikes please do that somewhere else.
louiesquared
Bentonville, AR US
11/28/2023 12:57pm
This is the most logical thinking that I have seen in the e-bike vs bike naming debate. I'm 100% on board with this.
E-Moped or E-Ped are the only terms I am accepting at this point. Who's with me? lol Laughing
2320th
11/28/2023 3:29pm
This is the most logical thinking that I have seen in the e-bike vs bike naming debate. I'm 100% on board with this. E-Moped or E-Ped...
This is the bike industry, logic was never part of the equation
Moreno Valley, CA US
168th
11/28/2023 6:34pm
I just call them motorcycles😂
Yoda
IT
56th
11/29/2023 1:34pm
For those who can't get enough raw alu, Ancillotti's proto is now for sale: Ancillotti bikes. Very sick.
