Trek's effective seat angles are always amusing, they should state what seat height its measured at.
As a rule they are measured at the stack height. Since the 'effective' seat tube angles are usually measured at the effective top tube length level, which is by definition the stack height.
Which is exactly why these bent seat tubes and effective seat tube angles are such bullshit when it comes to XL bikes (yeah, it's personal).
Even if they add 20-30mm on the reach in there they’re still missing 20-30mm to be considered modern. Treks bikes were the best in the business...
Even if they add 20-30mm on the reach in there they’re still missing 20-30mm to be considered modern. Treks bikes were the best in the business a few year ago but in 2016 they just got lazy and ceased to innovate which is exactly what geometry they still use. Seat tubes slack as hell and long as hell, head angles from the early 2000s and reach straight from 2014... no wonder their factory riders like Reece Wilson are 5ft 7in and on an XL with a +7mm reach adjustment Headset. Get with the times already. And wtf is that Color? Looks like a sweater from the 80s.
2021 Trek Slash 7 (Alloy)
looks very much like a kona process 153
[img]https://p.vitalmtb.com/photos/forums/2020/08/13/9823/s1200_screenshot_2020_08_13_slash7nx_21_32992_b_primary_webp_image_1440_1440_pixels_scaled_68.jpg[/img]
170 Front 160 Rear
HTA: 64.6 High 64.1 Low
STA: 76.1 High...
170 Front 160 Rear
STA: 76.1 High 75.6 Low (Could be better)
Reach: 20-30mm longer compared to last generation
Internal Frame Stage (Carbon and Alloy)
Super Deluxe with Thru Shaft (spec'd due to 'clearance issues')
34.9mm Seat Tube
Threaded BB
looks like they scrapped the knock-block, or was it only on the carbon bikes? bike looks very similar to the old slash, was hoping for a little more evolution lookwise.
170 Front 160 Rear
STA: 76.1 High...
170 Front 160 Rear
34.9mm Seat Tube
Threaded BB
looks like they scrapped the knock-block, or was it only on the carbon bikes? bike looks very similar to the old slash, was hoping for a...
They have kept the knock block but it’s now got more rotation compared to the previous headset. Also you could take them out as the fork will not hit the frame.
Adding 20-30mm would make a size Large have a reach out at ~485 which seems 'modern' to me and similar to the new Process X and nearing the sort of 490mm that most are getting to for a Large. Head tube angle is within a half degree of other bikes too. The seat tube angle is admittedly still a bit shallow given the bend but it's much better than before. It's taken Trek a while to get there but I'd argue Giant and Specialized are on a similar timeline with their geometries.
It does also seem like they got rid of the 'Straight Shot' downtube so knock block isn't necessary. I understood that they were looking for more frame stiffness with that but I could never tell the difference compared to older Trek models.
Adding 20-30mm would make a size Large have a reach out at ~485 which seems 'modern' to me and similar to the new Process X and...
As a rule they are measured at the stack height. Since the 'effective' seat tube angles are usually measured at the effective top tube length level...
I couldn't trust them to measure it properly! Its well known the previous gen Fuel was quite a bit different from the published geo tables!
Time to abandon the daftness which is virtual seat tube angle. Define the seat height and then the offset between the centre of the bb and centre of the saddle rail.
Well everybody has a different seat height, so it's not completely relevant for all people again. But there's an easier way. What if... Now, sit down, hold on, this is a wild idea. What if the seat tubes weren't bent, offset and the like and would actually point towards the BB? Like in the old days?
On a serious note, Unno provides the seat tube angle at different heights. And I made a calculator calculating the effective angle at seat height, which even calculates the actual seat tube angle from two different frame sizes, if those two have different effective angles provided (assuming the actual seat tube angles are the same considering manufacturers are mostly lazy in this regard). Or you just take it off a photo, which is reasonably precise, at least it used to be where a 75° virtual bike was actually sub 70
BTW, a message to the mods (if it's possible), drop the 2020 from the thread name and keep this thread rolling through eternity? We are well into MY2021 rumors, and it's just a PITA to run two threads, when to define the switchover point, etc. Why not just merge things?
BTW, a message to the mods (if it's possible), drop the 2020 from the thread name and keep this thread rolling through eternity? We are well...
done and good idea. the year removed faster than a poached image from a press release
Well everybody has a different seat height, so it's not completely relevant for all people again. But there's an easier way. What if... Now, sit down...
Appreciate that, but measuring effective seat angle at the stack height is pretty damn useless. Seat height per size is going to vary +/-50mm max, and the corresponding change in seat offset could also be quoted as well, add a few more numbers to the mix.
Straight seat tubes intersecting the bottom bracket would be fine, although pivots tend to get in the way.
Appreciate that, but measuring effective seat angle at the stack height is pretty damn useless. Seat height per size is going to vary +/-50mm max, and...
Don't get me wrong, completely agreed. And I was about to say something similar to your suggestion, to provide the effective seat tube angle at an X height for each size, which would be MUCH closer to reality than what we have now, which is, again completely agreed, completely useless. And is the reason why I made the calculators.
On the other hand, (X)S size riders usually get an even steeper seat tube angle, which though not as big of a problem as sitting over the rear axle, most likely is a problem nevertheless (didn't give it as much thought as the XL scenario, which is a personal problem, as mentioned), while M and L riders tend to have their seats fairly close to the stack height, which actually makes the published numbers reasonably close in reality as well. It's mainly the XL guys that bear the brunt of this issue, at least when it comes to overly slack seat tube angles. But these things are getting better in any case, so a drastic change in this field might not be as necessary as it used to be.
Interesting, the aluminium has a thru-shaft shock, because the reservoir didn't fit, but the carbon has the downtube shaped in such a way to fit the reservoir and they are using the standard Super Deluxe.
Interesting, the aluminium has a thru-shaft shock, because the reservoir didn't fit, but the carbon has the downtube shaped in such a way to fit the...
Carbon models are still using the thru shaft model (9.8 XT pictured)
Ah, but it's a full piggyback shock. But then, what drives the oil to the piggyback? On a normal shock it's the volume change with the damper shaft displacing the oil and driving it towards the reservoir. What's the mechanism here?? Or is it just an elongated mount to keep the same effective ETE and stroke on a standard shock as opposed to the thru-shaft shock? And just screw it onto the bearing mount shock variant. Or use the thru-shaft shock damper body but normal internals.
Here's a better look of the new maxxis mud tire. Blenki ran them some time ago at Rotorua.
[img]https://p.vitalmtb.com/photos/forums/2020/08/15/9835/s1200_Screenshot_20200815_203052_Instagram.jpg[/img]
Looks like a perfect tire for dusty conditions, and without cutting them down !
Ah, but it's a full piggyback shock. But then, what drives the oil to the piggyback? On a normal shock it's the volume change with the...
As far as i know there is clearance issues with the lockout lever on the piggyback in the last third of the travel. So trek moved the lockout lever onto the shock body instead of leaving it on the piggyback as seen on this rail.
Oh god... 'We can't fit the shock to the frame... Let's make a completely custom shock that no one ever will stock parts to service and won't know how to service it!'
Oh god... 'We can't fit the shock to the frame... Let's make a completely custom shock that no one ever will stock parts to service and...
I know Trek is one of the largest bike brands in the world. But can I just say, as someone who has been mountain biking since 1995, I have never once been "wow'd" by a single Trek design. They are like the vanilla ice cream of the bike world. And my lack of excitement for them always gets increased with all the proprietary crap.
I'd say this was their intent too. The wetscream hasn't seen use since 2014 cairns I think and it's an old design (even though I tried one and it is not bad, it just feels a bit weird). Shorty's knobs are maybe too short and the central rectangular one may not jel well with deep stuff. Maxxis are expanding their range of dh tires a lot, how many are there, 8?
https://www.pinkbike.com/photo/19211463/
https://www.pinkbike.com/photo/19211465/
https://www.pinkbike.com/photo/19211468/
Logic.
