SRAM updates the DB8 brake with a stealth lever body design
Press Release below
The DB8 is a simple, robust, and powerful brake for riders who prefer to set and forget. The low-maintenance Mineral Oil system uses proven lever technologies and features easy adjustment access and superior ergonomic comfort. The stealth lever body design brings the hose parallel to the bar, allowing for a sleeker, more modern ride. Code-like power is no surprise, as DB8 utilizes similar caliper architecture and existing brake pads.
– Stealth lever architecture for a sleeker, more modern ride
– Code-like power
– Tooled lever reach adjust
– Uses existing Code pads
– Designed for use with Maxima Mineral Oil only
– Designed for use with SRAM Mineral Oil Bleed Kit only
Visit SRAM.com for more information.
I wish they'd give it a bleeding edge style port on the caliper body to get a better bleed.
Post a reply to: SRAM Updates DB8 Mineral Oil Brakes with Stealth Lever Body
