Fox 38 Rhythm - Is it possible to upgrade damper and change travel?
LarryDavid
Vigo, Pontevedra ES
1850th
I just got a Fox 38 Rhythm in what I thought was a great deal. The fork is 180mm and I was considering to change the travel to 170mm and later on upgrade the damper to a Grip2.
Reading online I find confusing information: I find that the CSU of the Rhythm and the Elite/Kashima models are different material and therefore different wall thickness. Does that mean that they use different damper and airshafts? Or can I fit a grip2 damper and 170mm airshaft with no problem?
When I check the serial number of the fork on the FOX website it says that the damper is optimized for 38 rhythm interface parts. Which gives me more doubts.
Captura.JPG?VersionId=GhpgtKJYsnjt
Anybody has worked on and upgraded a FOX Rhythm?
TheKaiser
Storrs, CT US
12/3/2024 1:48pm Edited Date/Time 12/3/2024 1:50pm
I don't have the level of knowledge you want on that fork, but from what I recall the Rhythm forks are very similar in construction to the current (Fox owned) Marzocchi branded forks. I know the Zokes use 6000 series aluminum upper tubes, vs. the 7000 on the high end Fox forks, and thus have a higher wall thickness to compensate for the weaker material, so I suspect the Rhythm forks are using that same construction.
Regarding interchangeability of Fox parts, you'll need to get someone with more hands on experience with them than me, but I did just want to throw out there that some aftermarket parts are inter-compatible, so even if you can't get a Grip2 damper, you may be able to get a 3rd party damper. For example, these Avalanche dampers are supposed to work for both Fox Performance and Rhythm forks, although each one is custom made for the user so I'm not sure if the fittings differ for Performance vs. Rhythm but, either way, it is an option:
http://www.avalanchedownhillracing.com/Fox%2040/Fox%2036%20Open%20Bath%20Cartridge%20Kit.htm
BTW, I love your work...big Curb your Enthusiasm fan!
bnsleit
Missoula, MT US
12/3/2024 1:49pm
LarryDavid wrote:
I just got a Fox 38 Rhythm in what I thought was a great deal. The fork is 180mm and I was considering to change the...
Not sure about 38s specifically but the air shafts between a 36 Rhythm/Marz Z1 are different than for a 36 Performance/Elite/Factory for the ever so slightly different thicknesses, had to navigate that recently to up the travel on my fork. Haven't checked the damper compatibility though!
LarryDavid
Vigo, Pontevedra ES
1850th
12/3/2024 2:55pm
TheKaiser wrote:
I don't have the level of knowledge you want on that fork, but from what I recall the Rhythm forks are very similar in construction to...
Indeed, looks like the CSU of the Rhythm might be closer to the Marzochi, in this case I guess the Super Z. Anyway, they have different CSUs, but that might be related to the travel difference (190 the Z and 180 the 38). I also see they use different internals.
I got this fork with the idea of tuning it and testing new parts, so aftermarket dampers is definetely on the list. I was initially considering a Fast SC4 or 5 damper. Other option was a Vorsprung coil conversion, which sounds Pretty pretty gooood.
LarryDavid
Vigo, Pontevedra ES
1850th
12/3/2024 3:12pm
bnsleit wrote:
Not sure about 38s specifically but the air shafts between a 36 Rhythm/Marz Z1 are different than for a 36 Performance/Elite/Factory for the ever so slightly...
Yes, the difference you mention on the 36 chassis, I did find it in a nice video from a french suspension tuner where they explain differences along the Fox 36 models. Inner diameter of 36 Performance and Factory is different to the 36 Rhythm: 32.38 vs 32.6
https://youtu.be/DCcyKuw5xPc?si=TUWEyqbfgvj37sf7 table after min 1.30
So I was thinking that the 38 Rhythm and the Super Z might be the closest relatives due to the CSU in same material (i guess) But it is difficult to assure as they all have different part numbers for the CSU
The Super Z has Grip X, but it seems it is also different to the Grip X on the Fox 38. I will try to contact some Fox service to get some light.
TheKaiser
Storrs, CT US
12/3/2024 3:24pm
Yeah, that does sound pretty pretty pretty gooood! I've thought about doing the same thing, either getting a closeout basic fork or a cheap used one, and just using the chassis to experiment with different internals. I go back and forth on it, as, on the one hand, Fox has a huge R&D budget, and exposure to all the pro athletes tuning preferences and the institutional knowledge therein, so you'd hope that after almost 30yrs they'd have their Sh*t dialed. On the other hand, most of the aftermarket tuned forks and shocks I've tried have felt great, and certainly better than stock, so it really seems like there is something the big guys are missing. And I know that there's the explanation/argument that the stock Fox/RS product has to fit the "average customer", plus a reasonable range below and above average, and isn't able to be customized to the end user's needs the way a boutique tuner's parts are. But I still don't fully buy that, because I would say that I, and most of my riding buddies are average in size, and we'd hope a bit above average in ability (but realistically not hugely so compared to Pro riders), and yet these aftermarket tunes still feel substantially better. After a few experiences like that, the idea of getting a cheap chassis and then custom internals from a 3rd party starts to sound like the smart money way to go, as it can actually cost less than going for the premium models from Fox or RS.
Post a reply to: Fox 38 Rhythm - Is it possible to upgrade damper and change travel?
