Cannondale Bosch Shimano: drivetrain don’t play?
lawn dart
Denver, CO US
Edited Date/Time 7/18/2024 7:35pm
I have a Cannondale Moterra that I bought lightly-used from a friend.  It has the Bosch 750 Wh motor.  Killer fun, this bike!
Drivetrain is an issue, though.  From early-on, I got pedal-skipping under load.  The kind of skipping that usually tells you that the freewheel, chain, or front sprocket is warn-out …only this happens after like 2-3 rides—on a completely new drivetrain.  I’ve replaced everything:  freewheel, chain, derailleur, front sprocket, but still, after only a few rides, the skip is back.
Shimano slx derailleur and freewheel, Shimano 12spd chain, fsa front sprocket.  Anyone have any suggestions? I believe that the fsa front sprocket is the limiting factor here, since it’s either the only, or one of the only options for the Cannondale offset, and Bosch spindle.  I really wish it could be all Shimano!IMG 8243IMG 8246IMG 8247.jpeg?VersionId=gGfnLl7gSHlibGcxYa9fTMNQQu6j
Kale123
Brisbane, QLD AU
7/19/2024 12:45am
Derailleur hanger out of alignment?
lawn dart
Denver, CO US
7/19/2024 3:32pm
—no.  We’ve straightened it (to no effect).
I’m starting to wonder if the chain isn’t cut too short.  And / or if shifting under load is twisting the chain.
7/19/2024 4:17pm Edited Date/Time 7/19/2024 4:18pm
You said you replaced the freewheel, but modern mountain bikes don't have a freewheel. Did you mean the cassette? Cassettes are the modern version of freewheels. Or perhaps you were referring to the freehub, which is the ratcheting assembly inside a rear hub that allows the cassette to "freewheel," i.e. spin freely while coasting.
Whatever you meant by "freewheel," the freehub or the cassette could both be causing skipping under load, so I would make sure you check out both of those systems. Sometimes freehubs can benefit by just being disassembled and cleaned.
lawn dart
Denver, CO US
7/20/2024 6:56pm Edited Date/Time 7/21/2024 4:53am
You said you replaced the freewheel, but modern mountain bikes don't have a freewheel. Did you mean the cassette? Cassettes are the modern version of freewheels...
Yes, cassette. You can see it’s relatively new in the photo (I’m not big on washing bikes, because:  bearings).
I am old enough to have worn out freewheels as well as free hubs and cassettes, unfortunately,  long and short:  the skipping is just like a stretched chain, worn-out cassette, or even sprocket.  Yet, they are all new.
I’ve had it in a few shops, to no avail.  A free hub issue is an interesting idea, but why then, does everything work well for 3-4 rides after I replace the front chainring?
7/21/2024 12:00am Edited Date/Time 7/21/2024 1:13am
Could be the clutch in the mech is creating too much resistance and causing the chain to kick back. Try adjusting the clutch or having it off. Obvious one is gear cable could be badly routed/kinked check both inner and outer for tight spots by cycling the suspension without a shock. Other than that freehub internals would be most obvious thing - try a known good system such as a 18t dt hub or something.
Oh, b limit could be too far in and chain might not be wrapping around the smaller sprockets?
Thecolonel
Fairview, NC US
7/21/2024 5:36am
A friend had replaced everything on his 11 speed XT drivetrain, some parts twice, trying to fix noise and skipping in the middle cogs of the cassette. When he installed a HD (steel) freehub body the problem went away and has not come back. Apparently the independent cogs of the cassette had dug in to the alloy freehub body enough to cause misalignment. I would think an ebike would come with the steel freehub body though?
lawn dart
Denver, CO US
8/4/2024 5:04am
Hey all:  I finally got somewhere on this problem. I swapped out the wheel that had the Shimano cassette / free hub / wheel for an i9 wheel that I have built to a sram drivetrain (on my enduro bike).  Switched the derailleur and chain to sram too.  1 ride in, and it’s working fine!  No skips!  Gonna give her another ride today!
lawn dart
Denver, CO US
8/4/2024 5:06am
jamesnoyce wrote:
Could be the clutch in the mech is creating too much resistance and causing the chain to kick back. Try adjusting the clutch or having it...
Thanks for the input.  The comments here and help from LBS’s have me on the right track, I think.
Post a reply to: Cannondale Bosch Shimano: drivetrain don’t play?
