2024 Norco Optic C1 carbon high pivot mountain bike XO AXS T-Type transmission
movemint
Gladwyne, PA US
2024 Norco Optic C1 carbon high pivot trail bike.
$7500
Size 3
Upgraded with Fox Factory 36 fork and Crank Brother Synthesis carbon wheels.
Used on 3-4 rides, but in great shape. Has a couple of little marks that show use, but otherwise looks new.
140mm front, 125mm rear travel. 29" front/rear wheels.
AXS Charger, seatpost brass pins, small frame parts to run with mechanical or different setup included.
MSRP $9,099
Frame Optic Carbon, VPS HP, 125mm Travel, UDH
Fork   Fox Factory 36 FLOAT GRIP2, HSC, LSC, HSR, LSR, LNT, 140mm, 44mm Offset, Fender
Rear Shock  Fox FLOAT X Factory, 185x50mm Trunnion
Rear Shifter   SRAM Pod Controller
Rear Der   SRAM X0 AXS Eagle T-Type
Crankset   SRAM X0 Eagle T-Type, Boost, 30T AL Ring, 170mm
BB   SRAM DUB BSA Threaded
Cassette   SRAM Eagle T-Type 1295, 10-52T
Chain   SRAM XO Eagle T-Type
Chain Guide   Norco Idler Guide and Lower Guide
Brakes   SRAM Level Stealth Silver, 4-Piston, Sintered Pads
Rotors   SRAM Centerline 200mm front, 180mm rear
Handlebar   Deity Skywire Carbon 800mm, 25mm Rise
Stem   CNC Alloy, 40mm Length, 35mm Clamp
Seatpost   One Up Adjustable Dropper, 34.9mm, 210mm
Headset   FSA #57 E, Sealed Bearing
Saddle   Fizik Alpaca Terra, Wingflex
Grips   DMR DeathGrip
Front   Hub Crank Brothers Synthesis 12x110mm Boost, 6-Bolt
Rear Hub   Crank Brothers Synthesis 12x148mm Boost, XD, 6-Bolt
Rims   Crank Brothers Synthesis CARBON
Front   Tire Maxxis Minion DHF 2.5", 3C, MaxxTerra / EXO / TR, Folding
Rear   Tire Maxxis Dissector 2.4" WT, 3C, MaxxTerra / EXO / TR, Folding
Spokes   Sapim Race Butted Stainless
PXL 20241028 184647396~2
PXL 20241028 184935826.NIGHT~2PXL 20241028 185004133.NIGHT~2.jpg?VersionId=BieGhpFkTDpZOyYb0gF TQN9qcXR0NPXL 20241028 184746442 0PXL 20241028 184805561 0.jpg?VersionId=ED6PXL 20241028 184703350~2.jpg?VersionId=RJY4QAPXL 20241028 184716170.jpg?VersionId=ISJjVMlluIyOgU  8b8RDNRi59Hf5PXL 20241028 184906576.NIGHTPXL 20241028 184834295.jpg?VersionId=ODXT7QmWqlpMI1A80d4aiJKlKWWccPXL 20241028 185223524.NIGHT
PXL 20241028 185028472.NIGHT
PXL 20241028 185339709.NIGHT~2PXL 20241028 185020199.NIGHT~2 0.jpg?VersionId=VxHHPXL 20241028 185055129.NIGHT~2 0PXL 20241028 185040403.NIGHT~2PXL 20241028 185129147.NIGHTPXL 20241028 185157009.NIGHT
Post a reply to: 2024 Norco Optic C1 carbon high pivot mountain bike XO AXS T-Type transmission
