2024 Norco Fluid VLT Carbon e-bike trail mountain bike.
$7500
Size 3
Taken on a couple of rides, in great shape! A few little marks from use, otherwise looks new.
150mm front, 140mm rear travel. 29" front, 27.5" rear wheel.
Bosch Performance Line SX with 400Wh battery. 55nm and 600 watt of peak power. Fully wireless setup with TPU on top tube, wireless controller on left side of the handle bar, & wireless magnet on rear valve stem.
Bosch battery charger, and AXS battery charger included.
MSRP $9,999
Frame Carbon Front Triangle, SS & CS. 140mm Travel, UDH
Fork Fox 36 Performance Elite, 29", 150mm Travel, 44mm Offset Rear Shock Fox FLOAT X2 Performance Elite, 185x55mm Trunnion
Rear Shifter SRAM Pod Ultimate Controller
Rear Der SRAM X0 Eagle AXS T-Type
Crankset Praxis Carbon Bosch, 165mm
Cassette SRAM 1295 T-Type, 10-52T
Chain SRAM XO Eagle T-Type
Brakes SRAM Code Silver Stealth, 4-Piston, Metallic Pads
Brake Rotor SRAM Centreline, 200mm front, 180mm rear
Brake Levers SRAM Code Silver Stealth 4-Piston
Handlebar One Up Carbon 800mm, 20mm Rise
Stem Norco SL 6061 Alloy 40mm Length, 35mm Clamp
Seatpost One Up Travel Adjust Dropper, 31.6mm, 170mm
Headset FSA No. 57 ZS, Carbon Top Cover
Saddle Fizik Ridon
Grips WTB Wavelength Grip
Front Hub Crank Bros. Synthesis Alloy, 110x15mm, 6-Bolt
Rear Hub Crank Bros. Synthesis Alloy, 148x12mm, Star Ratchet, 6-Bolt, XD
Rims Crank Bros Synthesis Alloy Enduro E-Bike, 27.5" Rear, 29" Front.
Front Tire Continental Kryptotal 29" x 2.4" Trail
Rear Tire Continental Xynotal 27.5" x 2.4" Trail
Drive Unit Bosch Performance Line SX
Battery Bosch CPT 400Wh
Post a reply to: 2024 Norco Fluid VLT C1 carbon e-bike mountain Bosch SX
