Selling my Marzocchi Bomber Air rear shock off my new Ibis Ripmo. Shock works great but I'm a coil guy...
210mm x 55mm
$275
The Bomber Air - offered in a huge range of sizes, with a large volume offset shock reservoir - trail ready, DH rated, easy-to-use, bomber as ever.
Features
Asymmetric reservoir position for improved compression lever ergonomics and versatile frame fitment
Air valve location offers improved frame clearance and pump access
Easy to adjust for all rider weights and riding styles
DH-rated shock pairs well with all Marzocchi forks, from DJ to Z2 to 58
2-position, non-indexed compression sweep adjust means you can set it and forget it
Innovative tunable sweep to adjust the stop to a narrower window
Compatible with FOX bearing mounts on both ends (excluding trunnion)
Post a reply to: 2023 Marzocchi Bomber Air 210 x 55
