eBike hubs....seen this before?
Edited Date/Time 4/26/2022 2:48pm
JRA...
Eoin
11/26/2021 7:51am
Thank you for the upcoming nightmares.
I will say bolts loosening on ebikes is a pain, I need to toque check my rear end after every ride, between the pivot bolts and the rear axle you need to over torque everything to make through a big ride.
11/26/2021 10:22am
That is a RaceFace Vault hub - according to the owner "new" - it sure looked new. Now it is new...and bustified :-)
11/26/2021 11:29am
I'm going to say the bolts were loose and once 4 of them were out the 2 remaining tabs had o chance.
Going by the way those CPS washers have been installed (under the mount instead of the calliper) I don't have a lot of faith that anything was mounted correctly
11/26/2021 4:59pm
Poor bike maintenance sucks when it happens to you.
MOTO13
Elkhorn, WI US
12/22/2021 12:50pm
I am surprised you didn't end up with your teeth rubbing on the front tire. Luckily the rear wheel didn't lock up on you. This is just not paying attention to normal maintenance. The bolts had to have been loose as shit for a while to have this happen. Maybe that was the rattling sound you were hearing for the past 3 rides. Has nothing to do with E-bike hubs. Has to do with the e-bike rider.
Skerby
Ellensburg, WA US
1/5/2022 10:59am
Just switch to rim brakes and call it good.
1/5/2022 4:57pm
Brooklyn Machine Works v-brakes would do the trick.
4/26/2022 2:48pm
Can think of a lot of things to say, but I gues Sram already did that to this pro rider calling them out..
Post a reply to: eBike hubs....seen this before?
