Ashland, OR
I'm on my first MTB, been running with tubes for the last 3 years, and have wondered about going tubeless when I upgrade to a newer better bike. Thing is, in 3 years of riding, I've rarely had punctures (3? 4?), and they were from goat-heads or a nail riding downtown. So why would I want to take on all the extra hassle of tubeless? sealant, valves, core - all that extra expense & maintenance!
I've also heard that tubeless allows you to run lower pressures, but I'm curious what people actually run. I'm 200lbs and I'm running my tubed tyres at 24-26psi ... would I go much lower with tubeless, and how much benefit would I get?
From the media and marketing, I get the sense that tubeless is just 'better' and the way to go, but I'm curious what the reality is. Are there many people who went tubeless and then switched back? Is tubeless good for some people (and their respective terrain) but not others? Thought I'd throw these questions out to the forum ....
I rode tubes longer than many for reasons similar to what you listed. Once I switched to tubeless tires, I did find I could run lower pressures without pinch-flatting, and this improved the grip of my tires as well as the overall ride quality.
Tire sealant is not infallible but it has saved me from small goathead-type punctures more than a few times.
Less rotating weight is a small advantage, too--although depending on what tires/casings you choose, this may not be very relevant.
With practice, the "extra hassle" of tubeless is very minimal. Changing tires is a little messier, but unless you are changing tires frequently it's hardly a big deal.
All that said, if it ain't broke, don't fix it, right? If you're having fun on a bike with tubes then don't worry about it. You mentioned that you're considering a bike upgrade. There's a good chance a newer bike will come with tubeless tires already installed. When that happens, you can try them for yourself--keeping in mind, of course, that tire tread, casing, size, etc. are also going to affect what you feel--and decide if it's worth it for you.
I occasionally put tubes back into previously tubeless tires at the request of customers when I was working as a shop mechanic. It's not super common, but to each their own.
I would commonly gets flats with tubes. On a typical ride, I would often pick up 5, 6, or 7 goat heads and I'd be lucky if they were in knobbies or not quite deep enough to puncture the tube. Sure enough, I'd suit up for a ride, or plan to take my bike to work for an after work session, only to find one (or both) tires flat in the garage. I got sick of it and finally moved over to tubeless for good. It was a hassle for a while, but no problems now that I have the right valves figured out.
@Falcon - goat heads are brutally effective! Thankfully my local trails are free of them, but I've occasionally picked some up around town.
Post a reply to: Who DOESN'T need tubeless?
