Stripping...Paint Off A Frame
Keene, NH US
Edited Date/Time 2/15/2019 4:00pm
Winter in NH isn't dialed right now, so I have the time to strip a frame of some unwanted paint.
BUT, I cannot find any good suggestions for paint stripper for aluminum frames.
Vital hive mind - what do you suggest for paint removal? And any fun tips?
Feel free to share cool photos of restoration projects or paint jobs too, show off your handy work!
Scrub
Elk Grove/Truckee, CA US
1/10/2019 4:43pm Edited Date/Time 1/10/2019 4:44pm
Use a good quality Aircraft Paint Remover/Stripper with a brush to get in the tight areas. Depending on paint you may have to use a small wire wheel in the tight spots where the paint gets thick. Dremel or drill will work.
EZ-OFF oven cleaner works on Anodized stuff,
Both methods can leave "blotches" on aluminum if you don't apply evenly. Sanding #600+ can help blend the raw finish.
Safety is key to not making an ER visit, both are nasty chemicals.
Good nitryl gloves
Well ventilated area. Remember you're probably gonna hose it down outside too. Don't kill your grass, just saying
Respirator
Safety goggles
Keene, NH US
1/10/2019 8:27pm
Hot damn! Well, that is super helpful, thanks!
1/10/2019 10:32pm Edited Date/Time 1/10/2019 10:34pm
Sometimes forums just work. Other times they end up in pages after pages of arguing. I prefer the working kind. Well done gents. Oh, and an acid dip works too. Santa Cruz had one in the old powder coating facility.
Eric_McNeil
Mammoth Lakes, CA US
1/13/2019 2:12pm
Aircraft stripper has a tendency to evaporate quickly. Apply it a bit heavy with a brush and then quickly wrap it with Saran Wrap. It will give the stripper more time to work, then Hose it off in a safe place. Rinse and repeat until it’s gone. Use that stuff outside because it’s some nasty stuff.
1/13/2019 5:45pm
Aircraft stripper has a tendency to evaporate quickly. Apply it a bit heavy with a brush and then quickly wrap it with Saran Wrap. It will...
I've always wondered about the "Hose it off in a safe place." part. Isn't that stuff super toxic to the environment? Or does it neutralize with water? Would a shop sink be more appropriate? Would your local water treatment plant worker smack you upside the head if he knew you did that? Anyone?
1/14/2019 8:35am
for fun i looked up acid dipping prices. here's some random sheet out of oregon. if you're into the process and doing it yourself, ignore. if you want it done professionally and easily, seems like a good option considering how gnarly the chemicals are. $100-200 for a bike based on these prices maybe? not cheap, but not huffing fumes
http://www.metaldipping.com/prices.php
LukeD
Andover, MA US
1/14/2019 8:50am Edited Date/Time 1/14/2019 8:51am
for fun i looked up acid dipping prices. here's some random sheet out of oregon. if you're into the process and doing it yourself, ignore. if...
@Scrub was dead on with his paint stripping method.
Having painted helmets, motorcycles and frames for 20+ years, I'll say that sending it out is worth way more in piece of mind and hassle than $100-$200, just to not deal with the chemicals. Next one I have to strip, I'm just going to send it out. Smile
Skerby
Ellensburg, WA US
1/17/2019 9:12am
Anyone have any experience with media blasting? Seems like it would work pretty well with the right blast media.
Im considering this as I have a local PC/blasting shop and I want to make my frame raw. I don't think acid dip is an option in my area.
1/17/2019 10:55pm
Media can be many things, from crushed walnut husks and pure baking soda to the coarsest sand. A light sand blasting with all of the appropriate surfaces masked would work great with paint, but powder coat is basically a coat of plastic around your frame and would rather bounce that shit off. That being said, I've never personally laid into a powder coated frame with sand.
1/17/2019 11:00pm
Most of my media blasting experience is with bead blasting (With tiny glass beads.) of aluminum motorcycle parts.
Roy
Nashua, NH US
2/12/2019 2:33pm
Hey everyone!
I just finished restoring a 2005 Turner DHR. I went with sand blasting the frame-set. I couldn't find a super safe aluminum paint stripper and was affraid of the acid pitting or worst, weaking the aluminum. I used glass media and it worked out really well. I'll post some pictures of my DHR project.
2/12/2019 7:55pm
Nice blue. Is that Honda red or Ducati red in the second photo?
Roy
Nashua, NH US
2/13/2019 1:03pm
Thanks! That red belongs to my Ducati 996.
Post a reply to: Stripping...Paint Off A Frame
