SRAM Eagle Clutch Sticking
Edited Date/Time 5/26/2020 5:18pm
I have a gx eagle derailleur and it is sticking so it's not putting tension on the chain. When I push it forward the is still resistance but the derailleur won't snap back. Does anyone know how to fix this?
tavaenga
HK
5/26/2020 4:12pm
The original 2012 XX1 had clutch issues and I had a hack that helped: remove the clutch cover with an o-ring pick, unfasten the retaining bolt with an 8mm hex, then add a thimble sized amount of chain lube, reinstall the parts in reverse order, and cycle the clutch a few times. A total hack that surely voids the warranty so think before you try it!
Post a reply to: SRAM Eagle Clutch Sticking
