6/21/2017 7:17pm
Hi all,
So a couple weeks back I noticed sideways movent in my rear wheel and so after double checking that It was definitely my rear wheel (and not linkages and so on) I set about replacing the cartridge bearings because that seemed what would be causing the problem. I did the job properly and used a bearing press to fit the new ones which went in nice and straight. I then put everything back together, properly tightening the cassete, the axle etc only to get back on it and still feel the sideways play!! I am properly stumped.... It is also worth saying that this is a nukeproof hub with a "3 in 1" thru axle design.
Thanks to any responses in advance.
Fin
Fin
Also, try to isolate the movement. Is it between the hub-cones and your dropouts? Between the freehub and the hub shell? Between the cones and the axle?
Of course, I'm just guess here. If you post pictures and the specific hub model, etc... that you have it'll be more helpful to us as we can actually see what you're working with.
Here are a few pics of parts of the hub
So on the axle casing or housing if if you know what i mean there is one end where the locknut thing is screwed on then it is just a seal then a bearing (sorry for my terrible discriptions), hopefully yyou can see what I mean by the attached pictures.
I had a bit of an investigation and it feels like the axle housing is moving slightly which I supose would be kind of amplified by the size of the wheel? I tightened it up quite alot but without putting excessive force on it cos that is never good...
cheers for the response.
Also, make sure you're torquing down your frame axle properly. If it's too loose it'll cause play as well.
Also when you say replicate it by hand, I can kind of hold both locknut things and feel a bit of movent that way (of the axle)
Think il try head in to my LBS
Post a reply to: Sideways rear wheel movement...
