Boise, ID
5/7/2018 6:19pm
This discussion is really just an excuse to post this Instagram video from FOX haha.
A post shared by FOX (@fox) on Jan 31, 2018 at 10:23pm PST
But seriously, understanding bikes don't have motors and throttle for propulsion, do modern DH and long-travel enduro bikes under-utilize deeper sag and negative travel for traction? Maybe it's not even applicable to consider bicycle suspension in a way like off-road racing, but holy crap that video is unreal.
I'll just leave this here, discuss.
http://www.naild.it/r3act/
We can run 50% sag on our current bikes, we just don't because it would suck. Try running one spring-rate too soft some time. AMAZING traction over small bumps and at speed in a straight line, but un-fucking-rideable where terrain undulations and rider inputs come into play.
Future Spomer forum questions: "What if we put little shocks in our spokes?" or "What if our tires were filled with nacho cheese?" or "What if we rode bikes in outer space?"
That said, for a newer (older) rider riding rough terrain, I do think letting them run more travel and run it soft with the right (progressive) frame is an excellent idea to help them build confidence. (this is what most bike parks should be renting...lots of travel, soft, slow rebound) Its just a crazy muted ride where your input doesn't do a whole lot. Your good rider would hate it. Maybe it'd work better in terms of giving the rider control, but I'm not sure it'd be faster.
I've been playing with negative travel a lot on my sled through whoops. Its pretty crazy how good I can get my snowmobile to track in these situations with negative travel. Its paramount to pounding through stuff like this. But my sled weighs 2.5x what I do. I only bring up the analogy as its somewhere in between a trophy truck and a bike. I can pump and jump doubles, but not nearly as quickly or as easily as I can on a bike (and I try!)
I like these questions. I also think its winter...and if you are into bikes, this is the time to chew on random shit.
i only bring up this topic b/c i've heard it discussed recently by some "names" on "the circuit." sure 50% sag may suck on bikes we have now, but what if everything was designed around that much sag? is that R3ACT design on the marin/polygon mentioned above designed around a bunch of sag? i'm not a tech dork, but i get turned on by desert trucks going through 22 inches of travel at 90mph. you can't tell me that desert truck has too low a spring rate just b/c it's super sagged. it's designed around all that sag right? what if bikes were too? AND i did mention at the very beginning, maybe this can't apply to bikes at all. didn't you ride a V10?
nacho cheese in tires has been done (le system) and also too late for shock spokes (super bummed, total shark tank gold...we could have partnered up)
i wish you'd post here more and lurk less! you're entertaining and i like that.
Was this fast? Probably not. I think we really liked it because it made our headtube angles slack and lowered our uber tall bbs. Plus, those bikes only had about 7" of travel.
Either way, its been done, I just don't think its fast in the world of bike riding...
here's the FFR bike you're talking about
https://www.vitalmtb.com/photos/features/2014-Sea-Otter-Classic-Pit-Bit…
The new Foes FFR downhill bike prototype was the highlight of our Day 1 stroll through the pits. Like all Foes bikes, the FFR was handmade in California. What makes it truly unique isn't the 27.5-inch wheels, but rather the suspension design, which is unlike anything we've seen before.
Speaking with Brent Foes, he told us that the goal of the system is to increase negative travel, helping to keep the rear wheel on the ground more often. This will, in theory, provide more traction and better braking. Much like the trophy trucks with ample negative travel that Brent has spent plenty of time working on, the rear wheel should be able to follow the contours of the ground much better with this design.
Brent achieved this by incorporating two shocks into the linkage - a traditional Cane Creek DBair and a custom made 1-inch stroke shock that is only active when the Cane Creek is fully extended. The bike has 8 or 9-inches of travel via the DBair and the single pivot linkage PLUS and additional 3-inches of bonus travel that comes via the second shock. The second shock is actuated by a few small links connected to the swing arm. Accessing the full 12-inches of travel is only possible when the bike is unweighted and the rear wheel can drop down.
Lets you run more sag and does feel trophy truck-esque when you are bombing in a straight line. I can still pump it through features pretty well though and it corners amazingly. Maybe not the most efficient rig around to pedal though...
Would love to try out that Foes on a proper DH track!
It would require a different riding style and suspension setup. Think Danny Hart vs Loic Bruni at Andorra last season. Danny looked like he was riding an angry bull down the hill. Loic looked like he was riding down to the shops for milk! I reckon Ohlins is running more sag as well as better controlled damping.....
You could run the same spring weight with both; the 10" position had about 5" sag and the 8" position had about 3" sag. So both felt similar after you'd gotten past the sag.
There may have been some extra traction in the 10" mode, but overall the 8" just felt better pretty much everywhere. Hence why Santa Cruz eventually did away with the option of 10"
I'm going to join Spomer on the side of, "This footage is sublime and I can't stop watching it…"
Since first seeing the introduction of Chain Smoke 2, I've had a mild obsession with Trophy Trucks - they just boggle the mind in terms of what they can do, from a mechanical standpoint.
The reason why it's difficult to compare a TT to an MTB is a laundry list of points:
Weight and the distribution of it
Approach angles of obstacles
Speeds/Forces
Chassis size and balance
Torsional forces
Mixed Materials
General terrain of uses
How momentum is generated
Inertia of vehicle
Static vehicle with no input outside of throttle, steering, and objects/undulations v. rider input
Etc.
In MTB, the rider is heavier than the "machine"; the overall ratio of size and weight of the bike v. rider is significant, as is the ratio then of the bike to the objects it's impacting. There are only two wheels, and fewer forces to account for (on a relative scale, mechanically speaking). The bike is heavily controlled by the rider's input, and thus the suspension has less to work to do when compared to the truck, as there are no extra limbs to act as shock absorbers or downward forces from a body to create non-weight oriented negative sag.
Then, it needs to be noted that the suspension systems on the TT v. a MTB are laughably more complex and insanely adjustable. With that much more control due to volume, it's no wonder TT can perform as they do. It is also by in MTB Ohlins are so heavy - they have more going on inside as to better control the forces. They eschewed the industry "light is fast" mantra and followed the path of "correct engineering is fast".
Better to learn and appreciate in this case than compare because at the end of the day, to get a bicycle to ride like a TT would be a fool's errand due to the fact that the applications are vastly different and the way they each need to interact and function with their respective pilots is not even remotely similar.
For reference, TT suspension.
More reading on TT suspension.
Post a reply to: Sag and Negative Travel - Discuss
