Are you taking about the the two washers that go on top of the caliper before the bolt head? Technically no but helpful if you brake tabs are perfectly faced. The allow for sligh misalignment.
Are you taking about the the two washers that go on top of the caliper before the bolt head? Technically no but helpful if you brake...
Not quite right. Those cup and cone washers are necessary when you are using a post-mount to post-mount adapter between the brake caliper and the frame, because the adapter rotates the caliper slightly and thus puts the bolt heads out of plane with the caliper's tabs.
Here is an illustration:
But I still don't know if those are the "caliper mounting spacers" that janchondo was referring to, or if he was thinking of something else.
Better go tell pro team mechanics. Is it better to have them if you don’t have everything perfectly faces YES. Can it work without the and not perfectly faced brake tabs yes, but not optimal.
It's not a question of facing or not facing the tabs. It's about whether or not the adapter rotates/angles the caliper relative to the plane of the frame mounting tabs. Most post-to-post adapters (e.g. from PM160 to PM180) do. The photo you posted appears to be a non-standard adapter which does not rotate the caliper, thus the cup and cone washers are not required. You'll notice the team are not using standard-issue Shimano bolts on that caliper.
Sorry for the upload/response delay. Here are the pics of the cup/cone washers sitting on top of the mounting bracket. So technically they are not spacers, but alignment washers? Fitted on 2021 Fox 38 PERFORMANCE elite fork, and to 2021 Intense Carbine rear. Many thanks ahead of time for all of your time and consideration. 👍
Post a reply to: SHIMANO Caliper mounting spacers neccessary?
