How do you guys store your bikes?
Edited Date/Time 7/7/2021 10:06am
I'm gonna reorganize my garage soon to make it a more functional shop space for working on bikes. Curious what you guys are using for bike storage. Currently I'm using a Home Depot DIY sawhorse to store the bikes, but it's getting unstable and it's not the easiest thing in the world to get bikes on and off once it gets crowded.
Here's an example on what I'm talking about:
I've seen some people make some pretty rad, inexpensive and more convenient ideas, like this PVC stand.
Looking to build something that fits 5 bikes with easy access, curious what you guys are using?
11/16/2015 5:10pm
I always used to use bike hooks on the wall at about six feet off the ground. That way they take up less floor space. Right now they're just lined up in my parents chicken coup. Maybe you just need a chicken coup?
Masjo
Ancaster CA
2287th
11/16/2015 5:38pm
I used to have a combo of the PVC style rack and bike hooks: I would rack the MTBs and put the lighter road bikes on hooks in between. Our bike rack was made of wood though and just held the rear tire so it didn't stick out far from the wall. Currently in my apartment I'm using what is essentially a burlesque pole I got from MEC (Canadian equivalent of the American REI) by Swagman to hold two bikes on a post, which works great if you have enough wall space. It's either space across a wall or in front of it that you lose, it's up to you to decide which fits the area best.
kidwoo
Grass Hut, FM US
11/16/2015 7:43pm
I own shimano brakes on all of mine so I try to store them anyway possible that's not straight up.
That way when I roll out into the street and realize my brakes need to be pumped 20 times before they work, it makes it a lot more exciting in traffic.
11/17/2015 8:51am
kidwoo wrote:
I own shimano brakes on all of mine so I try to store them anyway possible that's not straight up. That way when I roll out...
I've never had that issue with my Shimano brakes. Air bubbles?
FCP
Blacksburg, VA US
11/17/2015 8:51am
Prop palettes on wall
back rear tire into slots
profit!
11/17/2015 9:01am
I've got all the road bikes and clunkers that don't get ridden often hanging on hooks, in addition to the bikes that get used regularly on that sawhorse. It's actually a decent setup, but I think I can make something more compact that would be cleaner (and more stable).
Palettes might be a good call, FCP. I've got a nook in the corner that's pretty useless and just collects car parts and used oil currently, might be able to just throw a palette in there w/ some planks removed.
It'd be rad to build something like this, more compact though:
But it'd probably end up looking like a wooden version of this:
I've also considered just biting the bullet and buying four of five scorpion stands, or these things:
Oz_Taylor
2988th
11/17/2015 9:13am
Here's my setup. Plywood board screwed to the wall joists to secure the hooks to. The hooks are staggered so I can fit 7 bikes in a fairly tight space. It's easy to unhook each one individually. Was pretty cheap too, about $60 all together. Just need to paint the plywood board so it blends in to the wall.
KiloMike
Santa Cruz, CA US
1048th
11/17/2015 9:27am
Oz, what spacing/staggering are you using (vertical/horizontal)? I'm trying a similar setup but handlebars are all running into each other.
66th
11/17/2015 9:49am
Oz_Taylor wrote:
Here's my setup. Plywood board screwed to the wall joists to secure the hooks to. The hooks are staggered so I can fit 7 bikes in...
this ^^^
iceman2058
IL
146th
11/17/2015 10:01am
I just pile mine in a corner. I'm trying to figure out the optimal formula to make sure the one I need is NEVER at the front. I'm pretty close to nailing it.
And to finish off my storage masterpiece, I also have the "Bike of Damocles" hanging over my head. I'm hoping all those helmets might help break the fall if it does come down on me one day.
Oz_Taylor
2988th
11/17/2015 10:06am Edited Date/Time 11/17/2015 10:24am
Horizontal spacing is 70cm and vertical roughly 50cm. You do get some overlap of the bars with wider bars but different head angle and bar heights mean that the bikes still hang properly. You might have problems if all your bikes have a similar bar height and have 750mm+ bars, but you could always stagger the hooks on each row by 10cm vertically to solve that.
I have the bikes with wide bars on the top row and road/xc bikes on the bottom row. The bikes on the top row can be removed in between the bikes on the bottom row. The bikes on the bottom row drop down after being unhooked so it's no problem getting them out.
Another good thing about hanging them is that the bikes can drip dry and/or any mud that drops off them is easy to sweep up without having to move all your bikes.
bigguns8431
plymouth GB
11/17/2015 10:14am
Got some Clug wall mounts working well for the time being big bike one is a bit stiff when u lock it in but dose not move
Masjo
Ancaster CA
2287th
11/17/2015 10:17am
I don't know how to add a link/photo to an old post so I am unfortunately posting again.
The bike pole from Swagman that I got a MEC. Not this one doesn't require any screws going into the wall, you just expand the pole until it squeezes itself against the floor/ceiling: Bike Pole
And the multi-bike wall storage. We used the spacing of the width of your road bike at its widest point (cranks+pedals usually) to make sure there was enough room for the bike to hang: Wall storage
phobospwns
Buffalo, NY US
11/17/2015 10:18am
You could just hang half by the back wheel?
610th
11/17/2015 10:24am
I use SteadyRacks (https://steadyrack.com/) they're expensive but worth it to me, the swiveling part alone is great, and I like that they hold bikes by the wheel and not the rim.
ARK65
Colorado Springs, CO US
11/17/2015 11:04am
I welded up a little stand for my bike to reside in the garage. It's small and easily moved. I also bring it on trips so I can do post ride maintenance. It has some anti slip sick on pads on the bottom. You can see where I had to add an extra brace for a 27.5" wheel.
tgoose15
Moro, IL US
11/17/2015 11:11am
[/img]
Mine was under $50 and holds four bikes in less than 6 feet of wall space. They swivel which is nice. The only thing I need to add is an S hook so hanging them up and taking them down is easier. If I had more space, it would be easy to get a few more bikes in.
I also put a plywood shelf on top where I keep my helmets and other bike-related stuff.
bigguns8431
plymouth GB
11/17/2015 12:34pm
ARK65 wrote:
[img]https://p.vitalmtb.com/photos/forums/2015/11/17/2709/s1200_image.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2015/11/17/2710/s1200_image.jpg[/img] I welded up a little stand for my bike to reside in the garage. It's small and easily moved. I also bring it on...
that is bad ass haha
Gnarnia420
In the clouds...., CA US
11/17/2015 4:15pm
Psh, you guys put way to much effort into this. My garage (they're bikes, they're gonna get scratched anyways):
Luke_Lu
TW
11/17/2015 5:03pm
tire warmers are great for keeping the wall clean.... XD
11/17/2015 5:35pm
Nice! Welding your own stuff is Fun. That's my new word.
11/17/2015 5:38pm
Luke_Lu wrote:
tire warmers are great for keeping the wall clean.... XD [img]https://p.vitalmtb.com/photos/forums/2015/11/17/2744/s1200_10710669_10154905409070026_7854944316392035795_n.jpg[/img] [img]https://p.vitalmtb.com/photos/forums/2015/11/17/2745/s1200_10353565_10154885498335026_3224301872209684175_n.jpg[/img]
Those exist?
Luke_Lu
TW
11/17/2015 5:49pm
Those exist?
I had them custom made. Other than the fact that it doesn't heat up the tires, the only problem is they didn't make it according to my measurement and came up a bit too short... XD
Yuroshek
Ledgewood, NJ US
11/17/2015 7:13pm Edited Date/Time 11/17/2015 7:16pm
No tire warmers here... Please excuse the mess. I have a few more bikes hanging on the opposite wall and a couple BMX bikes in the living room on display. My "man cave" extends through out the house. #bachelorpad
11/18/2015 12:04am
I was considering this, but don´t want my forks to be levelled the wrong way as it will dry out all the seals and stuff over winter..
Oz_Taylor
2988th
11/18/2015 12:26am
JBSDesigns wrote:
I was considering this, but don´t want my forks to be levelled the wrong way as it will dry out all the seals and stuff over...
Most modern forks have sealed dampers with only a small amount of oil to lubricate the upper seals and bushings. The seals are at the top of the forks, so if anything there is likely to be more oil sitting against the upper seals with the forks stored this way.
is this really a common problem? I've never experienced it and the winters are long here.
Post a reply to: How do you guys store your bikes?
