How do I remove this freehub?
Edited Date/Time 2/1/2019 10:58pm
I'm trying to resurrect an old rear wheel for a pump track bike. The freehub feels like it could do with a clean out and lube up but I can't figure out how to get the blimin thing off.
I've tried to pull it off, like a modern hope hub...nope.
I've also tried to lock something into the two notches on the inside to spin it off, either its extremely tight or I'm doing it wrong.
Does anyone have any experience with these? Its a pretty generic wheelset off a 2010 Scott Voltage 0.3. The rims are Alex Rims dp20, no branding on the hub.
2/1/2019 9:14pm
Try a 12 or 15mm Allen key on the non driveside
Scrub
Elk Grove/Truckee, CA US
2/1/2019 10:58pm
If you have an axle with a shoulder on it with similar diameter to the black sleeve put it in the non drive side and hit it with a hammer.
If not, give the old RideMonkey trick-Try It Now
2/4/2019 12:55am
Bang on lads, 12mm allen key (didnt have one so used a 10mm + 2mm) in through drive side and unscrew. Sorted...cheers!
Post a reply to: How do I remove this freehub?
