Katy, TX
12/27/2014 8:10am
Ok so, I'm ordering a NS Majesty frame and I need to know what rear axle size I need. I've been looking at a Hope Evo 2 hub from chainreactioncycles.com, but I don't know if it will fit, and I also don't know how to make it singlespeed (if that's even possible). I'm aiming for a single speed ratio of anywhere from 9t-11t in the back and 28t-32t in the front. Where can I find a rear hub that will fit the Majesty? (Preferably in purple, and also 32h). I also want it to be disc-brake compatible.
NS Majesty Frame
Hope Pro 2 Evo Rear Hub
NS Majesty Frame
MTB hub spacing (O.L.D 135 x 10mm)
So Hope makes a SS hub which is this here. I believe that would set you up.
http://www.chainreactioncycles.com/us/en/hope-pro-2-evo-rear-hub-single…
This is the single speed version which will require fewer spacers to set up, fit the frame, use disk brakes, and have a firmer grip than the QR version you were looking at.
But so for a cable, I just have to buy any old BMX cable?
If so, where can I get an 11-12 tooth freewheel and how do I instal it on the Hope hub?
Sorry for all the questions.
Also, do you have a recommendation for travel on the forks?
And how long is that cable?
http://www.jensonusa.com/Chris-King-Single-Speed-Stainless-Cog Is this the cog you were talking about? And all I have to do is slide it onto the hub?
Sorry for all the questions again....
Those brake components should all play nice together. I'm not sure how long that cable is and you might be better off trying a standard one from the local bike shop before paying so much for a tandem cable.
Yep, that's the King Cog. But I didn't realize how pricey they are. I guess I was working at a shop at the time, but I used to pay about $20. You'd do just fine with the Shimano ones at the bottom of the page for a lot less. But Pimp is Pimp. And yes the Hope and most MTB hubs have a specific spline to keep all the gears in line. The Hope Single Speed hub just has a shorter one than a standard rear hub. Then it should include spacers for the chain line and a lock ring to keep everything tight.
Post a reply to: Hardtail setup help (dirt jump)
