Swap Fox 32 SC for Fox 34 SC?
Edited Date/Time 6/21/2018 6:18am
Im riding a Canyon Exceed hardtail with Fox 32 SC Performance forks and want to upgrade to the Fox 34 SC Factory. The 32s are 100mm travel the 34s 120mm. Will this work? I already know Canyon will void the warranty just want to know if it is a worthy upgrade. Already installed a dropper, some beefier forks will turn it in to a weapon. Thanks!
6/21/2018 9:07am
Yes, it will work. Adding 20mm of travel will slacken the head and seat angles by close to a degree, raise your bottom bracket a little bit, and shorten the reach slightly.
Is it a worthy upgrade? If you find yourself at the limit of the 32 often, then yes.
Post a reply to: Swap Fox 32 SC for Fox 34 SC?
