Thanks to my incredible MTB coach - I have started using my dropper post “as much as my gears”
This has highlighted the budget nature of my “Giant Brand” post on the bike I ride half the time.
The bike I ride for the other half of my life came with a Rockshock Reverb (Hydraulic) which is far superior.
I’ll be buying a new post.
Probably just get a new one for the “work” bike.
Another option would be “upgrade” the home bike (if that’s possible) and fit the reverb to the “second bike” Assuming it is the correct dimensions - can’t check till I’m on the other side of this wide brown land.
How does the Reverb rate?
Any other suggestions or info?
Thanks
Thanks
Random story. YEARS ago I bought the first adjustable seat post that I saw on the market. It was marketed by Price Point in their paper catalog. The first ride was mint! All the joys of your Reverb (Aside from it not having a remote lever.) By the second ride a few days later it had transformed into a suspension seat post. And the next issue of the catalog changed it's description accordingly.
Funny story!
Also, costs a lot less than a new post.
Can I adjust the air pressure? (No - replacement air cartridges available.)
(I’ll google it) - googled - https://youtu.be/3Dy6lukV8Bc
I’d like to do that.
I think I’ll fit a One Up lever and new cable and see how I like that before buying a new post at this stage.
Edited after Googling.
Good luck.
Planning a new post.
My frame is a little restrictive for length of post installed.
I can only get 100mm drop with the original Giant, or the likely replacement a Fox transfer “Factory”.
“One Up” make a 120mm post that should fit.
Anyone got any experience with the One Up droppers?
It's absolutely smooth (I'd say the smoothest one out there, bar none) and has a low stack height, which allows a short guy like me (5'6") to be able to use a 160mm travel dropper post. It also doesn't use an IFP (Internal Floating Piston) which makes it more reliable. Another feature that I like was that it also comes with a release valve if any unwanted air gets in, which can happen with any dropper post. You don't have to take the post out and the the dropper will feel as good as new.
The weather in my part of the world is either: very rainy/muddy or very hot. I've never had to service the dropper post nor even need to use the release valve. Mine is over a year old now and it is as smooth as when I got it in 2018.
Bear in mind this was before we tested the OneUp droppers, we have now done so and this feature will need to be updated accordingly. The OneUp will charge into the top 5 here for sure, it's a great product (available at a great price too).
I’ve ordered a 120mm One Up post and lever.
(The extra 20mm was a deciding factor.)
I’ll report back.
I have had no issues with this seat post bought in June 2017
The ordering, communication and delivery (to Australia) were A1
The Post action is great. The lever seems a tiny bit “notchy” to release with my weight on the seat. Not when returning the seat. The extra 20mm travel in the short post is great.
My experience is with 4 dropper posts:
Giant (x2) Works OK. Limited life. Lever a little horrible.
One Up - great
Rockshock reverb hyd- better.
So, no surprise - the more you pay, the better you get.
One Up is probably the standout value proposition, depending on service life. Yet to be tested.
I’ve also heard great things about the PNW Loam Lever.
The One Up lever seems pretty good.
The “notchiness” is felt at the lever when releasing with my fat ass on the seat.
Not felt when releasing the seat back up.
Think is originates at the seat post mechanism. Might “break in”.
Not bad, but not at the level of the more expensive hydraulic reverb.
I’ve tweaked the lever position and ridden a bit more on the new post.
What I described as “notchy” is in fact a noticeably higher “break away” force when my full weight is on the seat,
Not terrible, but if I take a little weight off the seat, the lever is easier to operate. Like it is when returning the seat to the up position.
It’s working great. I’m really happy with it.
Post a reply to: Dropper Post recommendation (or warning)
