Philipsburg, PA
I am picking up a 2017 Beast of the East 3 on Sunday. It comes with 2.8" tires, and the bike is very geared towards being somewhat a fat tire bike. I'm wondering if it would be able to accommodate a more traditional sized tire as well (2.25, 2.35). I ride a lot on roads and do a lot of hill climbing on roads, and although the 2.8" will be very fun to have on trails. I do intend on later switching to something thinner. Just want to confirm the possibility of doing so, as i know the rims are made around fitting larger tires.
If I'm reading the specs correctly, the rim have a 50mm width. While your frame will accommodate smaller tires, rims much wider than ~30mm will square off many smaller width 2.3/2.5-inch tires. A 2.6 is the most narrow you'd likely want to go with the stock rims.
Post a reply to: Cannondale Tire fittings
