Cable Routing - What do riders want?
Edited Date/Time 10/16/2022 11:03pm
It's been several years since internal cable routing was the latest and greatest feature to hit mountain biking. There were a few growing pains along the way, highlighted by excessive rattling and nearly impossible-to-route frame designs that were both (mostly) solved by internally guided routing. Nowadays, it appears most riders just expect frames to feature internal routing and are much more occupied with whether a bike is mixed-wheel compatible or has frame storage.
But do riders really care or want internally routed cables?
I know, the question you've been dying to have answered. But after working at a shop and spending too much time fishing cables through intricate frames, then riding bikes with external cables that are easy to maintain, and finally witnessing the commotion stirred by headset cable routing, I began to wonder if riders really care for internal routing in the first place. I do appreciate the look of a nude frame with cables tucked away inside, but I also know some bikes continue to use external routing and look mighty sexy, too.
Here is my two cents: Mechanical cables can live inside my frame, no problem, as long as they're silent. If there is oil inside the hose, stick that on the outside of my frame, and I'm a happy camper. If oil is in the dropper line, that must not be my bike.
Poll
What is your opinion on internal cable routing?
Choices
10/13/2022 7:13pm
Not brakeless single speed. That's silly. Front brake Only single speed is where it's at!
10/13/2022 7:52pm
I can live with internal shift and dropper cables.. Better have the internal tubes so everything goes easily.. If not, external done right is just fine by me..
10/13/2022 8:30pm
I'm fine with internal routing as long as there are ports on both sides of the head tube.
LookinForIt
280th
10/13/2022 8:39pm
The only internal I care for is to have my dropper enter at the bottom of the seattube (no collar-mounted actuators please)
pinkrobe
Revelstoke, BC CA
10/13/2022 8:46pm
I almost voted for "All cables ran external, just like the good ol days", but then I remembered all the crusty, corroded cables and housing from exposed cables running every which way on bikes. "All lines external [except droppers] in full-length housing" might have got a vote.
Karabuka
3114th
10/14/2022 12:10am
Anything that does not go through headset!
Craw
10/14/2022 7:07am
There needs to be an option for: everything external except dropper.
10/14/2022 7:14am Edited Date/Time 10/14/2022 7:15am
If it’s internal, all guided. No excuse if it’s carbon (Looking at you Pivot!) If it’s external, do something slick like GT’s Groove Tube or GG’s hatch. Though I’m not the biggest fan of the dropper entering the same side.
Also, routing cables under the BB needs to stop. Like 10 years ago.
10/14/2022 7:40am
Definitely for the dropper, not too fussed about the others being external as long as it's not under the top tube where I want to grab when I lift my bike.
10/14/2022 8:09am
All external all the time.
But the industry is going wireless and completely internal for brake hoses. I wouldn't be surprised to see bikes coming out in the near future that don't have any routing for the shifter and dropper.
2320th
10/14/2022 8:11am Edited Date/Time 10/14/2022 8:15am
I've made my opinion on this pretty clear in the past, but....
As a bike shop mechanic, I'm fine with properly routed, internally guided routing that actually improve how the bike works. Yeti, SC, Intense and many other brands have had this for years and it makes for extremely clean, effortless routing, save for Yeti's bullshit dropper routing that pops up in front of the 90 degree corner and catches easy on the frame. There are other brands that offer simple routing that pops out easily and don't take long to sort as well that's not bad. This type of internal routing keeps easy serviceability while keeping cable and housing out of harm's way.
External for cheaper bikes with full length housing is ideal for more.entry lever bikes, routed along the top tube keep things out of most contact points and avoid any severe bends which keep things moving smoothly.
Anything that interferes with basic maintenance, causes parts to wear out before their usual time or causes simple tasks to take hours like replacing a cable needing to remove the entire bar and stem combo and need a complete re-hose and cable of the bike just to add 10mm to a stem or slightly wider bars is bad engineering. Saving 5-10 watts at race pace overall on a production bike is silly at the expense of serviceability is just shitty. On a LeMans car? Or a race moto? Sure, but they don't sell those, they're just trying to make them UCI legal by selling 45 year old's that have a 2.4 watt/kg ftp a nearly non-servicable bike for someone that can't actually take advantage of it's abilities. The amount of people who have bought a "through the headset/stem/bar/some sort of combo" bike and then been floored it costs 200$ to do a stem swap because of the brake hoses, they wish they'd never bought the thing. Now imagine clipping a derailleur cable or brake hose on a road trip.
One of my faves recently was a cervelo that had an over engineered way of routing the brake hoses through the headset and stem.... But had the dropper and shift cable enter the top tube externally. It's obviously set up for electric shifting instead of mechanical, but still....
There's so many internally but open cable in frame frames out there that have an additional internal block that needs to be removed to run a single cable, but both cables have to be removed to take it out, usually meaning both cables need to be replaced and both derailleurs re-tuned for absolutely no reason, a full run of housing and a housing tunnel under the bb would work fine and save time. This is also usually a point of water and dirt ingress that I've seen cause major build up in frames.
10/14/2022 8:33am
Fully external routing: fine.
Internal routing, guided: fine.
Internal routing, unguided, with large entrance and exit ports: also generally fine.
Internal routing, unguided, with small entrance and exit ports: not fine.
Through the headset: fuck all the way off.
25
10/14/2022 9:40am Edited Date/Time 10/14/2022 10:32am
The only time cables should be routed through the headset is on a commuter bike that runs an internal hub and has a fully enclosed belt drive system that needs maintenance fairly rarely
Eoin
42nd
10/14/2022 10:28am
I like the idea of a cable cover for cables going above or below the downtube.
Really surprised companies have not found a clean way to route the cables on ebikes through the battery port (or along the top of the downtube into the motor area) for a best of both worlds internal yet easily accessible solution.
nancynancy
Woburn, MA US
10/14/2022 11:05am
For the love of god no cables through the headset/stem..
idkmtb
Tilton, NH US
10/14/2022 11:09am
how about when all shifters/droppers are electronic, master cylinders are in the bars, no cables are seen. Then the only thing routed thru the headset is the brake line which you wont touch for 5 years? That may not be too bad...
lickmycrinkle
Beverly Hills, CA US
10/14/2022 11:18am
Nothing beats the previous gen Torque and Spectral for routing. Replaceable downtube protection and the look of internal routing, without actually being internal? Canyon dropped the ball by dropping it in the most recent gen.
371st
10/14/2022 12:00pm Edited Date/Time 10/14/2022 3:27pm
This a friendly reminder that there's a lot of horrible external cable routing, too. I've had noisy and rattly hoses and housing, I've had a rock chop my downtube-routed external brakeline in half on a road trip ($70 for a replacement Shimano hose from an LBS, ouch), I've had crazy rubbing and paint wear from cables, I've had below the BB routing (booooo), I've had a bird's nest of cables at the headtube, and I've had 10 foot long derailleur housing because the cable is seemingly routed on every tube of the frame before it arrives at the rear derailleur.
So let's just state broadly: bad cable housing is bad. Manufacturers, please think about the end user when you design your cable housing instead of just slapping it on (or in) there last minute. And please, please, please don't put aesthetics first when you're designing cable routing. It's beautiful if it works.
schwaaa31
Clinton, MA US
737th
10/14/2022 12:25pm
Nothing beats the previous gen Torque and Spectral for routing. Replaceable downtube protection and the look of internal routing, without actually being internal? Canyon dropped the...
Agreed. It's that way on my 19 Sender. Perfect solution IMO.
Aksel_Lfft
Plaisance-du-Touch FR
10/14/2022 2:24pm Edited Date/Time 10/14/2022 2:26pm
Man I was thinking exactly the same !! I have a 2018 spectral and that is in my opinion the easiest, cleanest and cheapest option for the cable routing (GT one is also clean and easy, a bit less integrated maybe). Clean look without the mess of internal routing installation/maintenance. Seriously, who in his/her right mind like to bleed his/her brakes every time you need to take apart your bike for cleaning/maintenance ?
In many industries/technical products with hydraulic lines, mandatory bleeds to maintain/clean the overall product and/or to manipulate the hydraulic system would be a hard No Go...
For me the minimum (or the maximum depending) is internal guided routing for cables (derailleur, dropper) and the rest is external, or a integrated solution to hide the cables behind a cover with easy access
10/14/2022 2:43pm
Eoin wrote:
I like the idea of a cable cover for cables going above or below the downtube. Really surprised companies have not found a clean way to...
"Really surprised companies have not found a clean way to route the cables on ebikes through the battery port (or along the top of the downtube into the motor area) for a best of both worlds internal yet easily accessible solution."
If I remember correctly, Spec does it that way. And in my experience, it doesn't make it any easier to deal with.
2320th
10/14/2022 3:47pm
idkmtb wrote:
how about when all shifters/droppers are electronic, master cylinders are in the bars, no cables are seen. Then the only thing routed thru the headset is...
First, what serious cyclist doesn't need to service their headset within 5 years? Hell, I have to do mine one every 5 months due to dirt ingress in semi desert like conditions after some good smashing. Also, if anything goes wrong with that brake system you're totally fucked. Smash your bar? Brakes are fucked. Have a crash and cut your line when the headset spins around to far? Brakes are fucked. Road trip you've spent a bunch of money on? No way a shop can fit it in quick to get you going again because it's an hours long job to reinstall your master cylinders and lines into your new bars.no compatible bars on stock? Too bad. Nor can you fix it with basic tools in a parking lot because you basically need a clean room to avoid getting dirt where it doesn't belong. There's zero advantage to that system for 99.9% of cyclists other than they think it's neat, and something being neat doesn't get you far. If you think it's some marvel of engineering or an advantage, you're the person marketing teams dream of trying to push bullshit you don't need. Not sorry.
Also, doing a proper fork service, you need to take the fork off the bike, and if you haven't fought putting a steerer tube up a headset with a brake hose through it yet, you don't want to and you likely don't want to pay the extra shops are starting to properly charge for the time it takes to deal with this shit. Also, in these systems, there's very little slack in the cables/hoses so you'll likely need to disconnect something, somewhere to remove the bar/stem from the bike if everything's internally routed. That means again, destination fucked. To service your fork you need full brake bleeds as well. Good luck getting it all back together in the 30mins/1hr it would usually take to do a quick fork service. You're well into 2h+.
10/14/2022 5:16pm
external but hidden like the GT Fury. So a nice cover with a couple of bolts that easily gives access to all cables.
Dropper obviously internal.
Moreno Valley, CA US
168th
10/14/2022 7:08pm
Single speed coaster brake.
10/14/2022 10:12pm
I have some stick-on cable guides ready to take my brake line external this winter when the frame gets a rebuild. Shifter cable will stay internal because it's the least worst way to get through a crowded BB area.
10/14/2022 10:31pm
I have some stick-on cable guides ready to take my brake line external this winter when the frame gets a rebuild. Shifter cable will stay internal...
Which cable guides did you get?
10/14/2022 11:30pm
external under the downtube but then have the now common downtube protection over it.... 2 birds 1 stone.
10/15/2022 12:13am
Where’s the option for: I want everything wireless, even my brakes! #MakeItHappen
10/15/2022 12:20am
"Really surprised companies have not found a clean way to route the cables on ebikes through the battery port (or along the top of the downtube...
Why are ebikes not using gearbox motors yet? With electric or wireless shifting? Seems like a no brainer… extra drag is overcome by the motor, less maintenance, better suspension performance etc etc
Post a reply to: Cable Routing - What do riders want?
